はじめに
This guide will show you how to replace the ExpressCard cage.
必要な工具と部品
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Grab the translucent plastic tab and pull the battery up and out of the Unibody.
If the latch is depressed it will lock the battery in place.
Remove the following eight screws securing the lower case to the chassis:
One 5.4 mm Phillips screw.
Three 14 mm Phillips screws.
Four 3.5 mm Phillips screws.
Remove the following 5 screws securing the mid wall to the upper case:
Three 10.5 mm Phillips screws.
Two 3.7 mm Phillips screws.
Remove the following six screws securing both the right fan and the left fan to the logic board:
Two 3.2 mm Phillips screws.
Remove the following screws securing the ExpressCard Cage to the upper case:
Two 4 mm Phillips screws.
Two 1.9 mm Phillips screws.
Lift the the ExpressCard Cage out of the upper case.
4 の人々がこのガイドを完成させました。
