メインコンテンツにスキップ
MacBook Pro 15" Touch Bar 2018 Trackpad Replacement
必要な工具と部品
  1. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: 手順 1、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: 手順 1、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Disable Auto Boot: 手順 1、 3の画像 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Lower Case: 手順 2、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Lower Case: 手順 2、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 4.7 mm screws
    • Two 6.6 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 3、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 3、 2の画像 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
  4. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 4、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 4、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 4、 3の画像 3
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 5、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 5、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 5、 3の画像 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 6、 1の画像 1
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 7、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 7、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 7、 3の画像 3
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  8. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 8、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 8、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 8、 3の画像 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
  9. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Battery Connector: 手順 9、 1の画像 1
    • Peel up and remove the insulating sticker covering the battery board, on the edge of the logic board nearest the battery.
    • If the cover doesn't peel up easily, apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive underneath, and try again.
    • If the cover doesn't seat securely during reassembly, try rotating it 180 degrees. It must be oriented correctly in order for the adhesive pads underneath to contact the board screws.
  10. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 10、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 10、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 10、 3の画像 3
    • Peel back any tape covering the battery board data cable connector.
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  11. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 11、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 11、 2の画像 2
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 12、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 12、 2の画像 2
    • Pry up and disconnect the locking flap on the connector at the opposite end of the battery board data cable.
  13. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 13、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 13、 2の画像 2
    • Slide the battery board data cable out of its socket on the battery board, and remove it completely.
    • Take care not to install this cable backwards or upside-down. When installed correctly, the white liquid indicator sticker should face up, positioned directly over the battery power connector screw.
  14. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 14、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 14、 2の画像 2
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 15、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 15、 2の画像 2
    • Use a spudger to lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough to keep it separated from its socket while you work. If it accidentally makes contact, it could damage your MacBook Pro.
  16. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Trackpad Assembly: 手順 16、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Trackpad Assembly: 手順 16、 2の画像 2
    • Use a T3 Torx driver to remove the two 1.9 mm screws securing the cover bracket for the keyboard and trackpad cable connectors.
    • Remove the bracket.
  17. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 17、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 17、 2の画像 2
    • Use a spudger to disconnect the trackpad cable by prying its connector straight up from the logic board.
  18. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 18、 1の画像 1
    • Apply mild heat to the trackpad ribbon cable to soften the adhesive securing it to the battery.
    • You can use an iOpener, hair dryer, or heat gun, but be careful not to overheat the battery. The cable should be warm, but not too hot to touch.
  19. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 19、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 19、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 19、 3の画像 3
    • Carefully peel the trackpad cable up off the battery, and push it out of the way.
    • Don't crease or tear the cable. If you have trouble, don't force it—apply more heat and try again.
  20. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 20、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 20、 2の画像 2
    • Use a T5 Torx driver to remove the 13 screws securing the trackpad assembly:
    • Nine 5.8 mm screws
    • Four 4.9 mm screws
    • These screws all look similar—be careful not to mix them up.
    • Adding a little blue threadlocker to the screw threads during reassembly can help prevent the screws from working themselves loose over time.
    • Install the screws loosely at first, and then check the trackpad alignment before tightening them down.
  21. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 21、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 21、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 21、 3の画像 3
    • Swing the display open slightly, but keep the MacBook upside-down. The trackpad assembly should separate and lay flat on the display.
    • Carefully feed the trackpad's ribbon cable through its slot in the chassis.
  22. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 22、 3の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 22、 3の画像 2 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 22、 3の画像 3
    • As you remove the trackpad assembly, be very careful not to lose the nine small metal washers resting on the screw posts. (They will fly off and get lost with very little provocation.)
    • Remove the trackpad assembly.
  23. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement, Trackpad: 手順 23、 1の画像 1
    • If your new trackpad didn't come with a ribbon cable, use the following three steps to remove and transfer the old ribbon cable to the new trackpad.
    • Use a spudger to pry up the retaining flap on the trackpad ribbon cable's ZIF connector.
  24. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 24、 1の画像 1
    • Apply mild heat with an iOpener, hair dryer, or heat gun to soften the adhesive holding the end of the ribbon cable to the trackpad.
  25. MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 25、 2の画像 1 MacBook Pro 15" Touch Bar 2018 Trackpad Replacement: 手順 25、 2の画像 2
    • Carefully slide the edge of a halberd spudger or opening pick underneath the ribbon cable, and work the tool back and forth to separate the cable from the trackpad.
    • Use minimal force, and apply more heat if needed.
    • Slide the ribbon cable out of its socket and remove it from the trackpad.
終わりに
9 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jeff Suovanen
メンバー登録日: 08/06/13
428,098 ポイント
259のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
5 件のコメント
where can I buy the trackpad?
k4ss487 - 返信
Did you manage to buy it somewhere?
Patrick Steiger -
Parts list with links to buy them is right at the top of the guide…
Jeff Suovanen -
Just replaced my trackpad, really easy to do! Thanks again guys!
Dimitri Prokas - 返信
There are washers on these trackpad. If you lose one by accident, does it matter?
Wow - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 38
過去 30 日: 137
今までの合計 15,094
