メインコンテンツにスキップ
MacBook Pro 15" Retina Display Mid 2015 SSD Replacement
必要な工具と部品
  1. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 2、 2の画像 1 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 2、 2の画像 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 3、 3の画像 1 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 3、 3の画像 2 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 3、 3の画像 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, Battery Connector: 手順 4、 1の画像 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 5、 3の画像 1 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 5、 3の画像 2 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 5、 3の画像 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement, SSD: 手順 6、 1の画像 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  7. MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 7、 3の画像 1 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 7、 3の画像 2 MacBook Pro 15" Retina Display Mid 2015 SSD Replacement: 手順 7、 3の画像 3
    • Lift the end of the SSD up enough to pass over the speaker directly behind it.
    • Do not lift the SSD too high, or you could damage the contacts or socket.
    • Pull the SSD straight out of its socket on the logic board.
終わりに
293 の人々がこのガイドを完成させました。
作成者
11人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,762 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
82 件のコメント
So guys, I got a couple of questions:
1. Is this model (MBP Retina Mid 2015/MacBookPro11,4 ) really upgradable? https://www.datenreise.de/en/macbook-pro... says otherwise.
2. Samsung 850 EVO or Samsung 850 PRO would work with the model mentioned above?
Eduardo Delai Correa - 返信
Yes, it is upgradeable. At the time that article was published there was no drive on the market that would work. Now there is. No the Samsung 850 EVO or Pro would not work. As far as I know OWC is the only one that produces an after market drive that is compatible.
Chris Matlock -
I couldn't find the SSD that Chris mentioned. Would you please point out the exact model?
Jerry Zhong -
It’s the OWC Aura Pro X2, you can get it all the up to 2TB.
Stephen Agnew -
I think you could purchase a pcie to M2 adapter and fit a Samsung 950 Pro in there. 960 Pro is coming out soon though with higher performance.
tonynca7 - 返信
コメントを追加
統計データ:
過去 24時間: 128
過去 7 日: 706
過去 30 日: 3,225
今までの合計 488,345
