メインコンテンツにスキップ
MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement
必要な工具と部品
  1. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: 手順 2、 2の画像 1 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: 手順 2、 2の画像 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: 手順 3、 3の画像 1 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: 手順 3、 3の画像 2 MacBook Pro 15" Retina Display Mid 2015 Lower Case Replacement: 手順 3、 3の画像 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
終わりに
33 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
503,079 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,298のガイドは作成済み
6 件のコメント
Do we need two different screw drivers for this or is the recommended one enough?
Jamey Rassweiler - 返信
You need the recommended one for the lid an a torx T5 for the screws inside
Oros -
hello i have a 2015 15” macbook pro nut i want them all custom to me so scraped off the paint to be clear back. ive seen many “clear looking stickers but they mostly look $@$*!&. have you herd of any copany selling a clearback housing and can only find stickers do you knaw any sites delling vlear hpusings?. the only other thing i can think of if have a friend #D print in clear and polish it till turns clear any ideas? i also wany yje top case vlrar slso but oe thing at a time
jae.good - 返信
I've had the back off my 2015 15" Retina MBP a few times, without any issues. I bequeathed it to my wife and now without warning there are several screws missing. I don't understand what happened, how can this be? (No, she didn't remove them just to prank me!)
Are new screws likely to stay in place, or is it more likely the screw sockets are damaged or stripped?
groblewis - 返信
I would try some loctite. The screws on mine had a small amount of the "green" version
Richard Peach -
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 73
過去 30 日: 382
今までの合計 62,474
