メインコンテンツにスキップ
MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement
必要な工具と部品
  1. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.1 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 2、 2の画像 1 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 2、 2の画像 2
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
  3. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 3、 3の画像 1 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 3、 3の画像 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 3、 3の画像 3
    • The lower case has two plastic pegs (red) that fit into plastic clips in the upper case (orange).
    • During reassembly, gently push down the center of the lower case to reattach the case to its two plastic clips.
  4. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, Battery Connector: 手順 4、 1の画像 1
    • Peel back the sticker covering the battery connector.
  5. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 5、 3の画像 1 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 5、 3の画像 2 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 5、 3の画像 3
    • Gently lift each side of the battery connector to pry the connector out of its socket on the logic board.
    • Bend the connector back toward the battery, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  6. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement, I/O Board Cable (Top): 手順 6、 1の画像 1
    • Remove the four 2.2 mm T5 Torx screws securing the I/O board cable connector covers.
  7. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 7、 2の画像 1 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 7、 2の画像 2
    • Remove the left connector cover.
    • Use the flat end of a spudger to pry the left end of the I/O board cable up from its socket on the logic board.
  8. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 8、 2の画像 1 MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 8、 2の画像 2
    • Remove the right connector cover.
    • Use the flat end of a spudger to pry the right end of the I/O board cable up from its socket on the logic board.
  9. MacBook Pro 15" Retina Display Mid 2015 I/O Board Cable (Top) Replacement: 手順 9、 1の画像 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    • Remove the cable.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,810 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 99
今までの合計 8,953
