メインコンテンツにスキップ
MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement
必要な工具と部品
  1. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
  2. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 2、 1の画像 1
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
  3. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Battery Connector: 手順 3、 1の画像 1
    • Peel back the warning label covering the battery connector.
  4. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 4、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 4、 2の画像 2
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
  5. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, AirPort/Camera Cable: 手順 5、 1の画像 1
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
  6. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 6、 1の画像 1
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
  7. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 7、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 7、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 7、 3の画像 3
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
  8. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 8、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 8、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 8、 3の画像 3
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
  9. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Rubber Hinge Covers: 手順 9、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Rubber Hinge Covers: 手順 9、 2の画像 2
    • Use the flat end of a spudger to pry the rubber hinge covers up off the left and right hinges.
  10. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Display Assembly Screws: 手順 10、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Display Assembly Screws: 手順 10、 2の画像 2
    • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
    • Remove the two aluminum hinge brackets from the MacBook Pro.
  11. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, I/O Board Cable: 手順 11、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, I/O Board Cable: 手順 11、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, I/O Board Cable: 手順 11、 3の画像 3
    • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
    • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
    • During reassembly, connect this end first, as it does not flex.
    • In a similar fashion, remove the I/O Board cable connector from its socket on the I/O Board.
    • Remove the I/O Board cable from the MacBook Pro.
  12. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Airport Card: 手順 12、 1の画像 1
    • Remove the single 2.9 mm T5 (sometimes T6) Torx screw securing the AirPort card to the logic board.
  13. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 13、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 13、 2の画像 2
    • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
    • Pull the AirPort card parallel out of its connector on the logic board to remove it.
  14. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 14、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 14、 2の画像 2
    • Use the tip of a spudger to flip up the retaining flap on the right fan ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Starting at the top of the cable, slide a plastic opening tool under the right fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board.
  15. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 15、 1の画像 1
    • Remove the following three screws securing the right fan to the logic board:
    • One 4.4 mm T5 Torx screw
    • One 3.9 mm T5 Wide Head Torx screw
    • One 5.0 mm T5 Torx screw with 2 mm collar
  16. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 16、 1の画像 1
    • Lift and remove the right fan out from the MacBook Pro.
    • When reinstalling the fan, it's easiest connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
  17. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Left Fan: 手順 17、 1の画像 1
    • Use the flat end of a spudger to lift the rubber heat sink cover up off the left fan.
  18. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 18、 1の画像 1
    • Remove the following three screws securing the left fan to the logic board:
    • One 4.4 mm T5 Torx screw with 2 mm collar
    • When reinstalling the fan and its screws, don't fully torque the screws until you've first installed all of them loosely, so that the fan can move a little and position itself properly as you insert the screws into their threaded standoffs.
  19. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 19、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 19、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 19、 3の画像 3
    • Use the tip of a spudger to flip up the retaining flap on the left fan ribbon cable ZIF socket.
    • Starting at the top of the cable, slide a plastic opening tool under the left fan cable to free it from the logic board.
    • Use caution when freeing the cable, as it is strongly adhered to the logic board. If necessary, use an iOpener or hair dryer to heat the cable in order to soften the adhesive and make it easier to remove.
    • Lift the left fan out of the device.
    • When reinstalling the fan, it's easier to connect the fan ribbon cable as you drop the fan in place, rather than after you've installed the three fan screws.
  20. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, SSD: 手順 20、 1の画像 1
    • Remove the single 3.1 mm T5 Torx screw securing the SSD to the logic board.
  21. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 21、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 21、 2の画像 2
    • Slightly lift the rightmost side of the SSD and firmly slide it straight away out of its socket on the logic board.
  22. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, I/O Board: 手順 22、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, I/O Board: 手順 22、 2の画像 2
    • Use the tip of a spudger to flip up the I/O board data cable lock and rotate it toward the battery side of the computer.
    • Use the flat end of a spudger to slide the I/O board data cable straight out of its socket on the logic board.
    • Do not lift up on the I/O board data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  23. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 23、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 23、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 23、 3の画像 3
    • Remove the two 3.1 mm T5 Torx screws securing the I/O board to the logic board.
    • On some models, also removing the silver 3.5 mm T5 Torx screw from the heatsink can aid in I/O board removal.
    • Carefully lift the I/O board and remove it from the lower case.
  24. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Logic Board Removal: 手順 24、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Logic Board Removal: 手順 24、 2の画像 2
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the logic board.
    • Use the tip of a spudger to pry the right speaker connector up and out of its socket on the logic board
    • Be sure to pry on the cable head, and not on the socket itself. Prying on the socket may cause it to separate from the logic board.
  25. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 25、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 25、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 25、 3の画像 3
    • Peel back the tape covering the top of the keyboard ribbon cable connector.
    • Use the flat end of a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
    • Use the flat end of a spudger to push the keyboard ribbon cable out of its socket.
  26. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 26、 1の画像 1
    • Use the flat end of a spudger to pry the trackpad ribbon cable connector up out of its socket.
  27. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 27、 1の画像 1
    • Use the flat end of a spudger to pry the keyboard backlight connector up from its socket on the logic board.
  28. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 28、 1の画像 1
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Pull the microphone ribbon cable out of its socket.
  29. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 29、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 29、 2の画像 2
    • Use the tip of a spudger to flip up the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
  30. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 30、 1の画像 1
    • Use the flat end of a spudger to carefully pry off the rubber screw cap on the raised screw head near the MagSafe 2 connector.
    • The location of this screw may vary between models.
  31. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 31、 1の画像 1
    • Remove the following six screws securing the logic board to to the upper case:
    • One 3.1 mm T5 Torx screw
    • One 2.5 mm T5 Torx screw
    • One 5.5 mm silver, raised-head T5 Torx screw
    • Two 5.7 mm T5 Torx screws
    • One 3.8 mm silver T5 Torx screw
  32. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 32、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 32、 2の画像 2
    • Lifting from the side nearest the battery, rotate the logic board toward the top of the MacBook Pro.
    • You may need to slide the logic board a few millimeters to the left in order to get clearance for the ports along the right edge of the board.
    • Using the flat end of a spudger, carefully push the MagSafe 2 connector out of its socket on the bottom of the logic board.
    • Disconnecting the MagSafe 2 connector can be difficult. If you are only removing the logic board to temporarily get it out of the way, such as for a battery replacement, you may find it easier to simply remove the two 2.5 mm T5 Torx screws securing the MagSafe DC-In board, and then remove the logic board and MagSafe board together.
  33. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 33、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 33、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 33、 3の画像 3
    • Remove the logic board assembly from the MacBook Pro.
    • While the logic board and fans are removed, use a can of compressed air and a soft, non-static brush to remove dust and other debris from the upper case and the logic board, particularly from the fan exhaust openings along the rear edge of the upper case.
    • When reinstalling the motherboard, make sure all cables, and the two rubber heat sink/fan covers, are visible and not trapped under the motherboard.
    • Second photo, clockwise from top: battery, right speaker, keyboard backlight, AirPort/camera, display, microphone, left speaker, keyboard, and trackpad.
  34. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Upper Case Assembly: 手順 34、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Upper Case Assembly: 手順 34、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement, Upper Case Assembly: 手順 34、 3の画像 3
    • Remove the single 2.6 mm T5 Torx screw securing the left rubber hinge cover in place.
    • Slide the hinge cover out of its bezel, then lift it up and out of the device.
    • The screw in the right hinge cover should already have been removed.
    • Slide the right cover out of its bezel, then lift it out of the device.
  35. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 35、 3の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 35、 3の画像 2 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 35、 3の画像 3
    • Insert the edge of a plastic opening tool underneath the upper microphone.
    • Slide the blade of a plastic opening tool along the bottom of the upper microphone, releasing the adhesive.
    • Be careful when releasing the adhesive holding the cable down, as these cables have been known to tear easily.
    • In a similar manner, release the adhesive underneath the lower microphone.
    • Lift the cable out of the device.
  36. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 36、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 36、 2の画像 2
    • Remove the two 4.0 mm T5 Torx screws securing the MagSafe DC-In board to the upper case.
    • Depending on your model, the DC-In board may not be secured to the upper case.
    • Slide the MagSafe DC-In board towards the right to free it from its recess within the upper case.
    • Lift and remove the MagSafe DC-In board out of the upper case assembly.
  37. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 37、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 37、 2の画像 2
    • Remove the following three screws securing the left speaker to the upper case:
    • One 5.6 mm T5 Torx screw
    • One 6.9 mm T5 Torx screw
    • One 2.6 mm T5 Torx screw
    • Lift the left speaker out of the upper case and set it aside.
  38. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 38、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 38、 2の画像 2
    • Remove the following three screws securing the right speaker to the upper case:
    • Remove the right speaker from the MacBook Pro.
  39. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 39、 1の画像 1
    • Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
    • We purposely have you leave two screws attaching the display to the upper case to aid in future steps.
  40. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 40、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 40、 2の画像 2
    • Open the device between 90 and 100 degrees, then rest it on its side.
    • While supporting both halves of the device with one hand, unscrew the upper 5.3 mm T8 Torx screw.
    • Repeat the same process for the identical bottom screw.
    • Be sure to hold the display and upper case together with one hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
  41. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 41、 2の画像 1 MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 41、 2の画像 2
    • Grip both halves of the device. Firmly put one hand on the top center of the upper case (left) and one in the same place on the display assembly (right).
    • While holding the display assembly in place, slowly push forward on the upper case, releasing it from the display assembly.
  42. MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement: 手順 42、 1の画像 1
    • Upper case remains.
終わりに
27 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Galan
691,466 ポイント
1,203のガイドは作成済み
8 件のコメント
I want to replace the trackpad, is it difficult to remove the batteries and how ??? please help
ali suliman - 返信
I am almost positive you cannot replay the track pad for the retina display models they are covered by the battery and everywhere I have looked it means buying a whole new uppercase. cannot find just the track pad part`
maxcasas21 -
Any instructions for replacing the keyboard?
flux1968 - 返信
Great guide! Made it super simple to stay organized and understand what was happening.
One thing I’d like to recommend is that when removing the main board (step 32b), it’s easier to just remove the MagSafe (step 36) at the same time rather than trying to separate the two boards. I understand the separation may have been made to aide in other guides, but if you’re replacing the entire uppercase as I did, it’s definitely easier (and safer) to merge the two.
matheau - 返信
Once again, an excellent guide. I’ve used it in the past to replace the battery. Today I used it to replace the upper case assembly because of a cracked trackpad. The process took around three hours but I saved over $400 compared to a local Mac repair shop, and who knows how much more if Apple had done it.
James - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 95
今までの合計 36,545
