メインコンテンツにスキップ
MacBook Pro 15インチ Retinaディスプレイゴム足の交換
必要な工具と部品
  1. MacBook Pro 15インチ Retinaディスプレイゴム足の交換, 下部ケース: 手順 1、 1の画像 1
    • MacBook Proに固定された下部ケースから次のP5 ペンターブネジを取り外します。
    • 3.1 mm−8本
    • 2.3 mm−2本
    The number of screws listed here is wrong on my model. I had four of the smaller size.
    anonymous 1286 - 返信
    Just to add to my comment above (I can't edit it because it's anonymous), my MacBook Pro is a mid-2015 15in model 2.8GHz (A1398; EMC2881). For the bottom case it uses six 3.1mm screws, and four 2.3mm screws at the clutch/hinge side of the MacBook Pro. I tried using a 3.1mm screw at the clutch/hinge end, as described in the main article, and they don't fit. It has to be four 2.3mm screws.
    anonymous 1286 - 返信
    agreed with above 1286...
    I have the Mid 2015/A1398/EMC 2909. the hinge end and two middle side screws used a 1.2x50mm screwdriver while the 'opening' end 4 screws used the T3 screwdriver. I guess different builds used different sized screws!!
    Tj Bennett -
    The instructions below have you basically taking ALL of the guts out of case. I’ve been doing my own apple repairs since before ifixit was a thing and this one is a handful. My battery was swelling and I wanted to remove it before it burst or bent the case so I took it out without having a replacement and it occurs to me that aside from using the solvent (liquid) to remove the adhesive, you could probably do this only taking the trackpad ribbon out. I have mine reassembled now and will research the best battery to buy but I think installation will take about 5 minutes. See if you can slip a plastic gift card under the battery and wag/saw the adhesive out without the solvent before you go through all of this. It might work. Note, don’t bend or put too much stress on the battery and certainly don’t puncture it…
    br1ansk - 返信
    Battery Recall for 15-inch MacBook Pro Retina mid-2015. Check Apple’s site for recalls, and put in your serial number. They replaced my swelling battery for free, regardless of warranty.
    Steve -
    As we are only replacing the battery, you can safely skip steps 6-26 and 28-48, no need to disassemble the computer to pull out the battery. Use nail polisher remover I was able to pull a super bloated battery out, without disassembling my MacBook.
    John Sikking -
    I qualified for the recall. These bloated batteries are dangerous! DO NOT, UNDER ANY CIRCUMSTANCES, PUNCTURE THE BATTERIES!
    Thanks for the heads-up on the recall.
    Datajockeys -
    For battery replacement, I also chose NOT to remove everything, and NOT to use the solvent. I used an iFixit heating tube (from the iPad kits) to soften the adhesive from the keyboard face… NOT the battery itself! Used the iFixit cards. I have four, so the real work is possible BETWEEN two other cards — reduces the chance of puncturing the battery. Worked fine, took a little while, but no problems.
    Steve -
    I’m having a problem trying to get the screws off. I have a set of pentalobe screwdriver set. I found one screwdriver that fits perfectly on one set of screws, but I am unable to unscrew it. I tried using some force pushing the screwdriver into the screw, but nothing happens. Any suggestions?
    henry_k_wong - 返信
    All the screws on mine are the same length for some reason.
    ccfman2004 - 返信
    I would recommend the first step is: Run the battery down to ZERO before doing any next step. This reduces risk to you, people nearby, to the MBP and greatly reduces the risk of fire. Step 2 should be: Double-check that the battery is at zero.
    I like others listed below and on YouTube, disagree with these full tear down 70+ steps being the only focus. I get that I have to be careful not to get the acetone solvent near the speakers. I skipped 25+ steps by: tilting the MBP away from the speakers and using very little acetone solvent. More pressure with the plastic cards and only a few drops of solvent. While giving the full set of instructions is fine it should be very clear that you can (at the user’s own risk) do this.
    Kenneth Schleede - 返信
    As above—I consider full disassembly to be far riskier to fragile cables and connectors than the risk for solvent spillage. I did steps 1-5 and 46-74. No issues. I HIGHLY recommend the iFixit magnetic Project Mat. It’s a white marker board surface gridded into squares and invaluable for labeling part sizes/steps in disassembly.
    philtrit - 返信
    As above too. I benefitted from the advice. From step 51 onwards, I found a easier way using tip from China battery seller. Use a 2” width plastic scraper/plastic paint scraper to poke under the battery. Use moderate strength to poke and avoid rough handling of the battery so as not to puncture it. There is no need to pry the battery to avoid stressing it, just use a firm poking action under the battery and the double sided tape adhesive will yield. After 5 min of such poking, the entire battery pack can be removed without the hassle of pouring the adhesive remover from step 51 onwards. Get a scraper with a stronger handle so that it is more comfortable to poke.
    https://www.aliexpress.com/item/32889670...
    Emma Pn - 返信
    Heads up as you go…we (husband/wife team) had a notebook that when screws/covers were removed, we marked the step # and actually taped the screws into the notebook noted by the step number. This was very helpful on reassembly and we knew we would be using the exact screw into the original screw hole.
    Ann Brainard - 返信
    After replacing the batteries myself, I wouldn’t even consider doing it again. Not that it’s difficult to do—that’s not the issue. The issue is aftermarket batteries. I’ve been using notebooks for well over 30 years, and never had satisfaction with aftermarket batteries.
    Modern lithium batteries are an amazing technological feat, but a dangerous one. So even putting aside that I’ve never found any aftermarket batteries with quality anywhere near original, I learned “cheap” aftermarket lithium batteries are downright dangerous.
    After doing research into what’s involved with manufacturing lithium batteries, I know there are so many corners to cut, you’ll end up with junk regardless of what you pay.
    A week after replacing my batteries with those from iFixit, they showed clear signs of failure. Thank goodness iFixit refunded my money.
    After having Apple replace my batteries, everything is back to like-new. For my $199, I got not only excellent batteries, but a new keyboard and trackpad as well. That’s it’s done!!!
    AnnoniMoose - 返信
    Which of the following companies make their own LiIon cells, Apple, Dell, DeWalt, Milwaukee, Tesla, Trek? Ans: NONE OF THEM. All these companies buy their LiIon cells from companies that will sell to iFixit or any other legitimate company. If you want quality, either do the research or pay through the nose for OEM. And note the Apple battery recall. Apple messes up too.
    Bartwick -
    I found an Apple Support link that said MBP battery replacement was $199, but the 2 Apple Stores near my house would not provide any appointments. Instead, I scheduled an appointment with and “Apple Authorized Service Provider” & that repair center quoted about $750 to replace the battery.
    I refused, went home, & opened a chat with Apple Support.
    After a lengthy & painful chat session where the Apple tech didn’t want to provide a battery replacement quote (he feared other issues with the MBPr), he finally gave me an Apple price of just under $650 to replace the battery.
    Did you go into an Apple store, or mail it in? I’m struggling to reconcile a price of $199 to get a battery + keyboard + trackpad against what I was just quoted 2 weeks ago. The new track pad & keyboard might have been due to repair tech error. i.e. they trashed those repairing your batter & had to toss them in.
    Bartt.Shelton@gmail.com - 返信
    I took mine in after being quoted for a $199 replacement of battery and keyboard, only to have the repair refused as they found a "water sensor" triggered and now I'm left with my AUD$5,000 laptop with messed up keys. Shame on me for not getting this repaired during COVID while under warranty. This is the first time I've truly been disappointed in Apple, but suppose it was bound to happen someday. I was quoted US$ 1479 to replace the battery and keyboard and the sensor (likely the logic board is replaced as well) if I were to send it in to the US repair center. Any chance these sensors can be triggered by humidity?
    C0RT - 返信
    I 1000% recommend watching this video and performing the battery replacement without all these steps from this guide and without using the acetone solvent. https://www.youtube.com/watch?v=ImonCWcc... (15" inch Retina MacBook Pro A1398 Mid 2015 Disassembly Battery Replacement Repair)
    The video is narrated well and the guy goes slow and zooms in where appropriate. Instead of removing all components, he simply removes the track pad cable, battery cable, and unscrews two of the speaker screws on each side. From there, you can lift up the speaker arms where the video guy uses a thin pry tool to push through the sticky tape. No solvent is needed except for residual sticky stuff leftover.
    Instead of the thin pry tool, I just used the plastic cards that came with this ifixit kit. It takes a little force and wiggle/jiggle so take your time using the corner of the card to start.
    This method makes a difficult 2-3hr job into a much easier 1hr job.
    Spencer - 返信
    +1 for this approach! I watched the video that Spencer mentioned. It took me a little over an hour, and it was stress-free. https://youtu.be/ImonCWcc1xk
    Chris Wicklas -
    Another +1 - I followed the video pretty exactly (after having already gone through steps 1-5 here). I'm not sure it's necessary to clean off the adhesive residue as thoroughly as he demonstrates in the video, but the instructions were clear and the end results were good - trackpad still working fine and new battery already charged to 50%.
    Jeff Zinn -
    Glad I read these comments before plunging into the iFixit instructions.
    +1 for skipping the iFixit instructions and using the youtube video linked by Spencer.
    I followed the instructions and had my battery replacement done succesfully.
    Instead of the metal spatula like thing he used - I used the plastic ifixit credit card things that came with my battery kit.
    It took about 15 minutes of wiggling under the battery to free it from the adhesive but it wasn't too bad.
    I did remove the residual adhesive as he indicated with isopropyl alcohol - but after finishing my installation I realized it was completely unnecessary. You can install the new battery over the residual gunk and skip that step.
    picardo -
    Yes! This YouTube tutorial works great and it was really easy to replace the battery. I needed about 75 minutes.
    Perform steps 1-5,
    Then skip to step 41.
    In 41 + 43 do not unscrew the red marked screws.
    In 42 an 45 just lift the speakers, do not remove them.
    Skip 44
    Up from 53, I did not use the glue remover, the plastic cards were enough.
    In step 63 watch out to start from the middle. This prevents you from peeling up the lower „platform“.
    Great job :-)
    weekendiac -
    It’s now February 2024, and the batteries Apple installed have all swelled up just like the originals. Doing a bit of research on the manufacturer, Simplo, I no longer trust them either. Microsoft used Simplo in their tablets, with countless users complaining about bad batteries. A few days ago, I read a post saying Apple now charges $250 instead of the $200 I paid less than three years ago. WOW! Even if Apple would replace my batteries, there’s no way I’m going that route again. Too bad my MacBook won’t boot without batteries. I don’t need them; I don’t want them. I also don’t want a newer MacBook. What to do???
    AnnoniMoose - 返信
  2. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 2、 2の画像 1 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 2、 2の画像 2
    • クラッチカバーに最も近い端から持ち上げて、MacBook Proの底面ケースを持ち上げます。
    If you buy the entire kit, make sure you use the opening tool! I cut both of my index fingers trying to slide it off.
    Catherine Nath - 返信
    Additionally, this is an “opportunity” to clean the cooling fans - and any other obvious dust magnets - with a can of compressed air. On the laptop I worked on, the cooling fans had sufficient dust to not “spin” freely - showing signs of “drag”. After blasting each cooling fan with compressed air (including from the exhaust vent side, as hitting the fins alone wasn’t adequate), they both spin freely now. No obvious signs of battery swelling on mine, but lack of adequate airflow could have been a factor with original battery aging/failure.
    Zathras - 返信
    Good opportunity to give a good clean out. Air duster and small clean paint brush on plastic surfaces to clean up essential vents and fans. You can load fan monitor and control software to see what your your system is doing and how it improves with a clean up.
    Robin Razzell - 返信
  3. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 3、 3の画像 1 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 3、 3の画像 2 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 3、 3の画像 3
    • 底面ケースには、上部ケース(オレンジ色)のプラスチッククリップに収まるプラスチック製の2つのペグ(赤色)があります。
    • 再組立中に、底面ケースの中心を静かに押し下げて、2つのプラスチッククリップにケースを再び取り付けます。
    pretty hard to put it back, so I just remove the clips on the upper case....
    jamiegan835 - 返信
    The trick to putting it back on is to guide your fingers to the same level as the clips, and then when you put the case down move your hand from the left side of the case to the right side of the case; applying pressure when you reach the area where the clips are.
    Aaron Freidus - 返信
    Impossible to put those peds into the upper case clips! It just does not hold there, it fits but just does the ‘click’ sound and goes back. Is it possible to buy those clips as spare part? Thank you for help.
    Lopez Loku - 返信
    Same for me. It just never clips, regardless of the precision and the amount of force I apply.
    Vadym Borodin - 返信
    I also think I stripped the screws holding the clips in place. Does anyone know what screw characteristics should I look for as a replacement?
    Vadym Borodin - 返信
    Bloated battery had already popped my clips.
    jecottrell65 - 返信
  4. MacBook Pro 15インチ Retinaディスプレイゴム足の交換, フットパッド: 手順 4、 2の画像 1 MacBook Pro 15インチ Retinaディスプレイゴム足の交換, フットパッド: 手順 4、 2の画像 2
    • 交換するフットパッドがついているリアケースの裏側からパッドを剥がします。
    • ここで剥がすパッド用シールは再利用できない場合がほとんどです。それでも大丈夫です!これ自体はMacBookの機能に影響しないからです。
    If you take an exact knife or similar and trace out a section around the feet, you can leave the rest of the sticker in tact. I found it easier to remove a small section of the sticker as it was fairly well adhered.
    Stephen Chan - 返信
    @Stephan Chan - Your suggestion was perfect. Cutting away the small section of sticker where the feet go is definitely the way to do it.
    seattlehudson -
    I agree with you @gusto5 (Stephen Chan) - cutting out a small circle in the sticker with a craft knife is much easier. Just to be on the safe side, since it did expose a little of the aluminum of the case, after I’d stuck the replacement foot and held it in place for 30 seconds, I put a small piece of Scotch tape over the hole I’d cut in the sticker on the back.
    Owen Edwards - 返信
    Received a quicker delivery of the feet replacement kit. Followed the suggestion and was quicker and boots (feet) flashed fit on bottom case.
    Albert Evangelista - 返信
    If, like mine, all your feet have sheared off, you may be able to pry the center bit of plastic left in the lid at each foot out with tweezers. Obviously don't go digging deep or forcing things, but if you are lucky like I was then you don't need to remove all the screws and the lid. My new feet went in well and seem really well stuck. Make sure you clean the surface of the aluminium extremely well.
    I didn't find any need to cut the plastic backing. I found that each foot easily came off the backing and I grabbed it with the tweezers.
    I put a pencil mark on the lid showing the position of the little "key" nub and made a mark on the foot too, showing its position. This allowed me to align the "key" nub with it's hole easily.
    frostyfriday - 返信
    After pealing away any feet, be sure to remove the clear film after applying the adhesive remover. I found this easiest to do with my finger name and then double checked that all four feet recessed areas were free of the clear plastic adhesive backing from the prior removed feet.
    Frank Dries - 返信
    The black stickers are for electrical insulation. I patched mine with black insulating electrical tape.
    Steve Lamb - 返信
    Does removing all the black stickers hurt the MacBook in any way?
    luisshr - 返信
    The adhesive actually peels off quite easy. I didn't need the adhesive remover, it peeled off like a thin plastic film.
    Francisco Daza - 返信
  5. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 5、 2の画像 1 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 5、 2の画像 2
    • ダメージが入ったり裂けたパッドを取り出します。
    • 交換するパッドにまだダメージが入っていない場合は、ピンセットを使って内側から押し出せます。
    • 古いパッドが剥がしにくい場合は、ヘアドライヤーやヒートガンを使って該当エリアを温めて、接着剤を柔らかくしてください。
    There are large black stickers in the way of removing this little piece on my A1502 Early 2015 MBP. How do we proceed from here?
    Jason Protzman - 返信
    Hey Jason! You can remove those stickers entirely, or just peel them back enough to remove the foot and then cut away the peeled part of the sticker.
    Taylor Dixon -
    Is the larger feet shown in picture 1 of this section for the MacBook Pro. I am assuming the second picture refers to the Retina MacBook Pro?
    Khushal Varsani - 返信
    All the pictures and text in this guide refer to the Retina MacBook Pro! The The Unibody MacBook Pro has its own feet replacement guide.
    Taylor Dixon -
    I think what Khushal meant was that picture 1 doesn’t represent the lower case foot hole of the Retina model, the hole left after the removal of the foot is too big. While the 2nd picture seems indeed accurate.
    fbianchife -
    Can the macbook walk? 🤣
    Yanny 57 - 返信
  6. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 6、 1の画像 1
    • 接着剤用リムーバーを使って、残りの接着剤をこすって綺麗に取り除きます。
    The adhesive is on both sides of a clear plastic sheet that sits in the foot cavity. It is easily missed but appears shiny when holding the case up to light after removing the rubber foot. If you look at the image in Step 9 below you can also see the sheet on the case side of the rubber foot (note this is not the same thing as the plastic sheet that the feet are attached to, this one is very thin and has adhesive on both sides). I applied adhesive remover twice and let it sit for a few minutes to dissolve the adhesive under the pad, then scrubbed with a bit of pressure to get that clear sheet removed from the foot cavity, but am glad I did.
    James - 返信
    For me, the adhesive remover was not strong enough, but I was able to apply acetone nail polish remover to remove the remaining adhesive before wiping it down with alcohol.
    Joseph Wilk - 返信
    Thank you so much, James, for mentioning the clear adhesive! I would’ve completely missed it had I not seen your comment!!
    Tina Nakai - 返信
    My adhesive remover didn't work, but what did work was gently scraping with a knife. This is for the clear adhesive mentioned by James.
    olive long - 返信
  7. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 7、 1の画像 1
    • イソプロピルアルコールのパッドで、フット部分の汚れを綺麗に拭き取ります。新しいフットを取り付けるため、このエリアに残っている古い接着剤を除去してください。
    I used a paper towel (or a tissue would work) to mop up the bulk of the adhesive remover first. And then I went back with the alcohol swap to get any remaining adhesive remover and let the area air dry.
    Frank Dries - 返信
  8. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 8、 1の画像 1
    • プラスチックのフィルムから交換用フットを剥がします。
    • 接着剤はかなり強力です。プラスチックのフィルムから完全に外れているか確認してください。
  9. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 9、 3の画像 1 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 9、 3の画像 2 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 9、 3の画像 3
    • 新しい交換用フットをくぼみの内側に揃えます。
    • フット部分にある位置合わせ用のナブが、パッドの中心にある小さな穴と合わさっているか確認してください。
    • 位置が揃っているか確認しながら、フットを被せます。
    • ケース内側から正しい位置に装着できているか確認してください。位置合わせ用のナブは、合わせ用の穴からわずかに見えるはずです。
    Matching the alignment nub with the small hole is easier if you align the point of the tweezers with the nub. The tweezer tip then acts as a reference point for matching the nub with its hole.
    Paul Jacobson - 返信
  10. MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 10、 2の画像 1 MacBook Pro 15インチ Retinaディスプレイゴム足の交換: 手順 10、 2の画像 2
    • 交換用のフットを指でしっかりと押し込み、ケースの両側から人差指と親指でフットをつまみ、内側に圧力をかけます。
    • 約30秒間押さえて、接着剤をしっかりと固定します。
    • この上記7つの手順を他の壊れたり紛失したフット部分にも、同じ作業を繰り返してください。
終わりに
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
21 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
Taylor Dixon
メンバー登録日: 06/26/18
67,116 ポイント
94のガイドは作成済み
コメント 1 件
Just finished doing the feet replacement (using the iFixit replacement parts) on a late-2013 15 inch Retina MacBook Pro and it was just a perfect result. Thank you for this great guide.
Rafael Pérez - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 138
今までの合計 14,344
