おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
はじめに
手順 1 に進む ↓スクリーンに亀裂がはいってしまい、スクリーンが見にくい状態ですか?このガイドを使ってディスプレイを交換しましょう。
必要な工具と部品
この手順で使用する道具:Tweezers$4.99
スパッジャーやピンセットを使って、3本のAirPortアンテナケーブルをAirPortボード上のソケットを持ち上げて接続を外します。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
82 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
13件のガイドコメント
Do yourself a favor and order the tools along with your display. I made the mistake thinking the bottom case was a standard torx and was surprised. The tools were not available in the local stores. I ended up ordering all the tools by clicking on the link where you goto order the display where it adds all of them to the cart. The tools are high quality and include the convenient finger tip end that allows the screw to be turned while keeping the screw steady and pointed in the correct angle. I am very happy with the tools and the display. I broke my screen when it dropped 2 feet from a chair to a carpeted floor and broke the bottom left corner 2 months after the retina first came out. It was fine except the screen was black till midway between the apple menu icon and the first pull down menu in apps until the display started to flicker lately and turn all white periodically.
How about replacing only the lcd/screen, not the entire display - is there a guide for that? How difficult is it?
Albert Braae - 返信 共有
