この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Restore sound to your laptop by replacing the speakers.
必要な工具と部品
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Remove the three identical 2mm Phillips screws from the memory door.
Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
Use the flat end of a spudger to disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
Remove the following 15 screws:
One 4.4 mm black Phillips screw to the right of the ram slot.
Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
One 6.2 mm black T6 Torx screw on the right side of the left fan.
Five 9.4 mm silver T6 Torx screws securing the left and right fans.
Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the left fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the left fan up.
Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
Remove the right fan from the computer.
Lift the heat sink out of the computer.
Peel up the left ambient light sensor cable from above the left fan, removing tape as necessary.
Remove the left fan from the computer.
12 の人々がこのガイドを完成させました。
コメント 1 件
I noticed that there were not any actual instructions for the Thermal Paste application as recommended. Other than that the instructions were spot on! - Makes repairs much more affordable when I can do it myself. CERTAINLY invest in the spudger if you don't have one though. There really is no other way you can be careful enough when dealing with the logic board and connections.
One other tip - Print out the instructions - get some clear tape and then tape down each screw to the instructions. That will make it much easier to keep track of where everything is going as well as ensuring you don't lose any of the tiny little screws or get one in the wrong spot.
