メインコンテンツにスキップ
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement
必要な工具と部品
  1. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, Battery: 手順 1、 3の画像 1 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, Battery: 手順 1、 3の画像 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, Battery: 手順 1、 3の画像 3
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, RAM Shield: 手順 2、 2の画像 1 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, RAM Shield: 手順 2、 2の画像 2
    • Remove the three identical 2mm Phillips screws from the memory door.
    • Lift the memory door up enough to grip it and slide it toward you, pulling it away from the casing.
  3. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, Upper Case: 手順 3、 1の画像 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  4. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 4、 1の画像 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  5. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 5、 1の画像 1
    • Remove the four 3.2 mm PH00 Phillips screws on the port side of the computer.
  6. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 6、 1の画像 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  7. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 7、 1の画像 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  8. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 8、 3の画像 1 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 8、 3の画像 2 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 8、 3の画像 3
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
    • There are four plastic clips above the DVD slot, and another above and to the left of the IR sensor. These clips can be very difficult to disengage without prying. They can also be difficult to re-engage during reassembly.
    • Reassembly Tip: Press down firmly on the tip of the top case above the location of each clip until you hear a snap to reseat them in their slots.
    • Reassembly Tip: The two center DVD clips will rarely snap back into place properly without help, and downward pressure will instead simply deform the frame around the DVD slot. Support the frame by inserting a plastic spudger into the DVD slot directly under the clip location until it is snug, then press down until you hear the snap.
  9. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 9、 2の画像 1 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 9、 2の画像 2
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Note: It is possible to replace the hard drive without disconnecting the keyboard from the chassis, but it will need to be held upright to keep it out of the way, while still allowing you both hands to work on the drive removal.
    • Be careful when removing the keyboard-trackpad ribbon cable to ensure that the rear of the upper case is disengaged from the area near the hinge. It is easy to accidentally bend the screw receivers on either side of the keyboard.
    • Remove the upper case.
  10. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, Optical Drive: 手順 10、 1の画像 1
    • Use the flat end of a spudger to disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  11. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 11、 2の画像 1 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement: 手順 11、 2の画像 2
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive.
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
    • Lift the optical drive up and out of the computer.
  12. MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, PRAM Battery: 手順 12、 2の画像 1 MacBook Pro 15" Core 2 Duo Models A1226 and A1260 PRAM Battery Replacement, PRAM Battery: 手順 12、 2の画像 2
    • Disconnect the PRAM battery cable from the bottom right corner of the logic board.
    • Use a spudger to pry up the PRAM battery from the lower case.
    • Lift the PRAM battery out of the computer.
終わりに
22 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Galan
696,119 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 32
過去 30 日: 125
今までの合計 41,740
