はじめに
You can again use ExpressCard accessories by replacing a faulty ExpressCard cage.
必要な工具と部品
Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
Disconnect the iSight cable from the logic board by sliding the cable to the left and out of its connector.
Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
ある他の人がこのガイドを完成しました。
