はじめに
このガイドを参照して、AirPort/Bluetoothケーブルの交換をします。
必要な工具と部品
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
16 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
5 件のコメント
I’d call this an easy replacement to be honest. Pulling the tape back is the hardest part. I didn’t disconnect the battery for mine (as some reviews said that could cause shorts as much as not disconnecting it), and things went just fine. All together, replacement took me less than 10 minutes from start to end, and things work great now!
This was an easy fix. I bought the cable & the bt/wifi card, but turned out only the cable was faulty.
WARNING :
Be really careful both while installing the cable : I did a replacement a few weeks ago, which turned to be a real failure, there was so much stress applied between both the board and the cable, that it started to extend and so, ripped the micro wires inside, and so wifi on my Mac was completely screwed up.
Be also aware of the different cables existing for this model. Just bought one form eBay, it was way too long for my mid-2012, I managed to make it work anyway using some tape, hopefully this fix will last.
