メインコンテンツにスキップ
MacBook Pro 15インチ Unibody Late 2008/Early 2009 バッテリーの交換
必要な工具と部品
  1. MacBook Pro 15インチ Unibody Late 2008/Early 2009 バッテリーの交換, アクセスドア: 手順 1、 2の画像 1 MacBook Pro 15インチ Unibody Late 2008/Early 2009 バッテリーの交換, アクセスドア: 手順 1、 2の画像 2
    • ケースを閉じた状態で、平らな作業台の上にUnibodyの上部を下側に向けて配置します。
    • アクセスドアの取り外しラッチの溝のある側を押して、飛び出した側の先端を掴んでください。取り出しラッチを垂直になるまで持ち上げます。
    The A1286 has no Access Door.!!
    I actually can see no sign of the battery!...
    aguib - 返信
    aguibからの引用:
    I assume you have the newer model, with the built-in battery. It's still removable with tools, but these are the wrong instructions for that model.
    lgc90 - 返信
    when will there be a guide for the other unibody macbook pro. that does not have an access door?
    irishking - 返信
    Is there a manual to show, how disasembly the display, i mean, after step 5, to check the display between lcd and aluminiun back case?
    Max
    Max - 返信
    On other guides you state the height of the HD that can be supported, e.g. MacBook Pro 15" Core 2 Duo Model A1211 Hard Drive Replacement , I have read ( but have not confirmed ) that the uni-body MacBook Pro can be fitted with the 750GB and 1TB 12mm drive from Western Digital.
    Can you confirm this?
    Many thanks in advance.
    ahothabeth - 返信
    SHerwood Ballからの引用:
    My display and aluminum casing has separated.
    I don't know if it just snaps back together or does it need to be glued.
    I dropped mine on the carpeted stairs and the display still works.
    I'm hoping I can just snap it back together and that no plastic pieces or teeth of the snapping
    portion have been broken........
    SHerwood Ball - 返信
    When you say "left fan" is this "left when looking at the logic board after turning the computer over and looking it up opening it up" or "left when sitting at the computer keyboard and typing on it"?
    thvv - 返信
    We always use left and right in reference to the computer when you're using it.
    Andrew Optimus Goldheart -
    Directions were great and the worn dc in board was replaced. The hardest part of the procedure is disconnecting the data display cable. A better description of step 21 is to slide the connector parallel to the circuit board towards the outside corner. Reconnecting correctly took several tries.
    I used the tip of the spudger to nudge the corners a little at a time to seat the connector.
    The ribbon connector for the keyboard has to be inserted all the way before seating the retaining cap. It took me three tries . First try power button did not work second try numbers keys did not work.
    Thanks for the directions ...could not have done it with out them!!!
    landryd - 返信
    Hola. Poseo un MacBook Pro Late 2008 y debo cambiarle las cornetas. Me sirve unas cornetas de un MBP Late 2011?
    jegonzalez80 - 返信
    Please read the instructions about removing the bluetooth cable - you CAN work around it, and NOT take off the plug.
    kenneth krabat - 返信
  2. MacBook Pro 15インチ Unibody Late 2008/Early 2009 バッテリーの交換: 手順 2、 1の画像 1
    • アクセスドアがUnibodyから十分の高さまで持ち上がるはずです。
  3. MacBook Pro 15インチ Unibody Late 2008/Early 2009 バッテリーの交換, バッテリー: 手順 3、 1の画像 1
    • 次の手順に進む前に、アクセスドアの取り外しラッチが垂直になっているか確認してください。
    • 半透明のプラスチックタブを掴んで、バッテリーをUnibodyから引き上げます。
    • ラッチが押されると、バッテリーが所定の位置にロックされます。
    Do I need to wait for the battery to charge completely before using the computer (while plugged in)?
    Kaila Potts - 返信
    No. You do not need to charge it completely before removing it.
    Titus (#1579) - 返信
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
84 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,573 ポイント
1,203のガイドは作成済み
3 件のコメント
I recently replaced my battery for the macbook pro late 2008 model number A1281, I have a weared problem with that - System shuts down while connected to power when it is Turned On.
I tried NVRAM reset also but no luck, Any help on this would be appreciable.
Thanks
Kamalarajan
Kamalarajan - 返信
Have just received the A1281 replacement battery. However it does not charge. The magsafe light is on green but the battery is not charging. When I put in my old battery the magsafe goes to amber and it starts to charge. Any ideas?
domburton - 返信
I just bought a new battery to replace A1281, and I have the same issue as you : the battery is not charging, power charger light is green.
I've tried to reset SMC, but it didn't solve anything.
Rodac -
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 29
過去 30 日: 118
今までの合計 84,515
