はじめに
2番目のハードドライブをラップトップに追加することで、稼働スピードの増加や容量の増大、新しいソフトウェアをインストールした時の問題を軽減できるなど、多くの利点があります。このガイドを参照して、光学ドライブを2番目のハードドライブもしくはSSDに交換しましょう。
必要な工具と部品
光学ドライブから光学ドライブケーブルを引き抜きます。
小さなメタル製マウンティングブラケットに固定された、2本の黒色#0プラスネジを外します。このブラケットを新しい光学ドライブやハードドライブの筐体に移してください。
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
122 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
13 件のコメント
great guide!
I had problems initialising the SDD drive in the optical bay. But have placed it in HD bay and it works fine.
My old Hard drive is a really snug fit in the caddy (its a 9.5mm drive) - when installed in the HD bay it sits on rubber shock absorbers and has air around it.
With a HD in the optical bay, I expect there to be some overheating or shock problems in the future.
!! Hard drive !! The Harddrive with the OS X on it for booting, has to be to be in the Harddisk bay and not the optical bay!
The System does only startup regularly on the SATA connector meant for the Harddrive, not the SATA connector of the former optical drive! (Even for MID 2012)
So, cause the most of us will add a SSD and want to run the System from it, we have to change the old Harddisk to the Optical bay where it is mounted without the anti shock rubbers.
In my case it did´t die there for over a year yet, so, not the big deal it seems at the first look ;-) lucky
I have a mid-2012 MBP. I just replaced the superdrive with a Samsung Evo 840 1TB SSD. My mac will boot from this drive when it is in the primary bay, and also if it is connected externally with a USB3/SATA cable. However it will not boot from the optical drive bay.
Also, if I install my original drive (Seagate Momentus XT 750GB hybrid) in the optical drive bay it will not boot.
If however I install an old 5400 HDD in to the optical drive bay, it WILL boot.
All three of the above mentioned drives have the same cloned OS on them. When the hybrid or the SSD are installed in the optical drive bay I can see them in the system profiler; both read a negotiated link speed of 6g.
Am I missing something...?
Crumbs :
Yes you are missing something… MPB MI2012 have just ONE Sata3 to read SSD… The sata for optical drive bay is on sata2.. So it can’t read SSD drive. Put your DD5400 on the optical drive bay, and boot with your SSD (install on the primary bay) and everything will be okay ;)!
Micke -
