はじめに
2番目のハードドライブを追加するとラップトップのスピードを改善したり、容量を増加したり、新しいソフトウェアをインストールした際のトラブルが少なくなります。
必要な工具と部品
光学ドライブケーブルを光学ドライブから引っ張ります。
小サイズのメタル製マウントブラケットに留められた黒色の#0プラスネジ2本を外します。このブラケットを新しい光学ドライブか 内蔵ハードドライブの筐体に移してください。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
354 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
56 件のコメント
Has anyone else noticed their Macbook booting and responding slightly slower with this duel-hard drive setup? I first swapped out my main hard drive for a SSD and the computer felt amazingly quick. I then replaced the optical drive with another SSD for additional storage and backup and ever since then the computer has felt slightly more sluggish in general. I suppose the CPU now has to constantly communicate to the second SSD where it could mostly ignore the optical drive before. Has anyone else noticed this?
Just fixed that issue:
Put the new SSD where the old HD used to be. Put the old HD where the optical drive used to be.
I found that the ports in the motherboard inside the mac have different speeds. The HD port is 6mb/s and the optical drive is 3mb/s.
chicle -
Are you sure its MB/S that would be horribly slow.
Zarkex -
I am seriously considering replacing my old HDD with a SSD instead of using a dual drive. Would you recommend still adding a dual drive with new SSD/ old HDD or just replacing the HDD with an SSD. I like having an optic drive, although not necessary. I am looking from the point of utility and practicality. Cheers!
nshourds -
Zarkex is correct. The transfer speed for SATA 3 is not 6MB/s it is 6GB/s.
