はじめに
このガイドを使って壊れたディスプレイアセンブリを交換します。
パーツ
スパッジャーの先端を使って、バッテリーコネクターをロジックボードのソケットから上向きに引き上げます。
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
Be patient on disconnecting this one. It worked for me step by step, little by little.
I used the nails of thumb and pointer finger simultaneously - worked pretty fine
バッテリーケーブルをロジックボード上のソケットから外して、わずかに折り曲げておきます。そうすると、作業中にアクシデントで接続することがありません。
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
Great tip, I did that too
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
On my MacBook Pro, the connector seems to be an integral part of the battery.
I suspect it’s just like the special screwdriver required for seatbelts on cars – to discourage regular consumers from attempting repairs. Of course, this only encourages consumers to use the wrong tool to attempt to repairs
スパッジャーの平面側先端を使って、AirPort/Bluetoothリボンケーブルのコネクターをロジックボード上のソケットから上向きにして引き上げます。
N.B! Thank you very much all you here on iFixit! Some IMPORTANT notes. Be very careful BEFORE prying the connectors up and down. They are very fragile and the picture could actually be seen as showing a bending loading in their weakest direction, AROUND its slender axis. The connector is slender and inserted on the logic board, so the gentle "walking" up and down should be done ALONG their slender direction and WITHOUT touching the adjacent connectors. If bending is done around its axis the soldering comes apart and the cable is done and gone. Just happened. These flat cables are one of the weakest design spots in my experience. They are a major time, money and geist consuming reason for malfunction like Wi-Fi connection problems, HDD, SSD not found internally but externally from USB issues et al being found on different forums. Thanks again and again.
丁寧にロジックボード上のソケットからカメラケーブルを引き上げます。
My cable is broken, have the part number or code to buy?
I found there was plenty of length in the camera cable (as it goes around two sides of the optical drive) so does not need to be disconnected - just ease it out of the slot alongside the drive and lay it diagonally across.
丁寧にAirPort/Bluetooth リボンケーブルを作業の邪魔にならない位置に動かします。それからサブウーファーとAirPort/Bluetoothブラケットに留められた接着剤を剥がしてカメラケーブルを取り出していきます。
AirPort/Bluetoothブラケットの中に型どられている固定用フィンガの下からカメラケーブルを逆戻しに回して外します。
前の手順に書かれた方法を使って、残りのアンテナコネクターの接続を外します。
AirPort/Bluetoothブラケットに切り込まれた溝からケーブルを巻き戻します。
I found re-attaching these antennae connectors the trickiest bit by far as they appear very delicate and seating them correctly was fiddly. In the end lighting them from the side with a small torch helped to check their position before gently pushing them down. The first one made a clicking sound as it connected, the other two went on silently. MBP wifi working perfectly now. I’m fairly sure that was at least £100 of labour had I taken it in for repair so thanks ifixit for saving me money and for the warm glow of accomplishment!
Actually, on my repair attempt, one antenna cable broke (on the image the bottom right one in the red square), I’m not sure whether it broke already before or was morbid somehow. Fact is. suddenly I had this cable in my fingers, and was sure I completely broke the macbook and need to find a new display now.
But as it turned out: the Mac is still fully working, including WIFI, BT, Camera etc. So apart from my huge relief, I want to address that these cables may break easily at their connection with the display. And that one antenna might be not mandatory for WIFI to work.
ディスプレイデータケーブルロックに留められたプラスチック製のプルタブを掴んでコンピューターのDC-In側に向けて回します。
ディスプレイデータケーブルをロジックボードのソケットからまっすぐ引っ張ります。
This was the hardest part for me. It took me a bit to figure out what parts were the socket and which was the cable and where were they going to separate. What I did was gently twist the pull tab on the cable in a clockwise direction. This allowed me to see a small separation between the socket and cable. At that point I knew what side of the pull tab I had to use a little pressure on, to continue to wiggle the cable free.
Eric Olson - 返信
次の2本のネジを外します。
8.6 mmプラスネジー1本
5.5 mm プラスネジー1本
上部ケースからディスプレイデータケーブルのケージを取り出します。
When putting the display case back together, I found it MUCH easier to reinsert the display cable before screwing back in the data cable retainer. It did require me angling my screwdriver to get the rightmost screw in, but it was not too difficult. It certainly made it much easier to reinsert the display cable since I had more freedom to maneuver it back into position. Hope this help others. God Bless!
ディスプレイが上部ケースに対して直角になるようにMacBook Proを開きます。
MacBook Proを開いたまま、画像にあるようにテーブルに置きます。
左手でディスプレイと上部ケースを一緒に持ちながら、下側のディスプレイブラケットから最後のT8 トルクスネジを外します。
I have found that keeping the MacBook more open than you’d think is the key to getting this step right. Initially I opened the lid only about 50º or so, but couldn’t free the hinges from the case even after removing the final two screws. Opening the lid to about 90º has made this much easier, and means the hinges come free without catching on the rest of the body of the Mac.
上部ケースを右側で押さえて、ディスプレイの上部を少し回転させます。すると上部のディスプレイブラケットが上部ケースの端から外れます。
ディスプレイをわずかに上部ケースから回して外します。
ブラケットやケーブルが絡まっていないか、邪魔になっていないか注意しながらディスプレイを上部ケースから持ち上げて外します。
I used this guide to tighten the hinges; screen was all wobbly because the four screws that hold the screen in place had worked themselves loose. Surprised that getting at the screws required the full removal of the display. One thing that's helpful in putting it all together is in regard to adjusting the position of the hinges; with the screws loose, there is a lot of play in the hinges, and if you just torque them down, the lid won't fit right. I snugged up the screws then put the display back in place on the body & inserted one screw into each side, then loosened the hinge screws to align the screen. That has to happen before replacing the black plastic cover over the bottom edge of the display.
My Macbook Pro developed a severe wobble in the display so I took it in to the Genius bar to see what could be done. They told me that fixing it would involve replacing the whole display because the problem is due to a piece of plastic inside breaking off. I suspected it just needed to have the hinge screws tightened so I brought my laptop home and gave it a go using this guide. Well, it turns out I was right! The Torx screws joining the hinges to the the display had come loose at both sides. To fix this, I got the hinges lined up straight on the display and tightened them down. To attatch the hinges to the body, I tightened one screw on each side half way and closed the display to line it up with the body. I then proceeded then to tighten all of the Torx screws on the body. Thank you for the great guide, Philip! I love this site!
gilded yak - 返信
Might be a dumb question but can I swap screens from a broken MacBook Pro to the my working one (both same model)
Yes, you can
When separating the display, be crazy careful with those tiny WiFi antenna wires you undid in step 9. One of mine came apart with almost no force whatsoever. If you do break one, reroute them when reassembling so that ports J0 and J2 on the Airport card have good connections. That’ll retain your laptop’s ability to connect to 5GHz WiFi if you’re unable to replace the entire antenna assembly.
I’ve made the replacement following each step, everything went well except when I turn on the Mac, I can see light in the screen it actually starts all clear in white light, but then it gets dark. The computer is working well I use a external monitor connected with a HDMI adaptor, but the Macbook monitor just doesn’t work, I checked the Flex cable, it is working good, camera, sound, wifi, everything.
I don’t know what else to try. Could it be possible I just broke the mother board connection with the LCD?? Please help!
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
236 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
24 件のコメント
No the connector in the logic board/video cable is slightly different.
Correct that the LVDS connectors are slightly different but you can modify them to fit using nail clippers if you are very careful!
Yeah! I did it. I had to use two different guides todo thelcd screen.but my MacBook is clear and no giant black crack. The mid 2012 "glass". Is plastic...just saying.
Can you give us a link to the two other guides?
My replacement display for this fix came with the display in a closed folded position, any suggestions for rotating the display clutches on the newly purchased screen so that I can manage to work it into place?
Stick a screwdriver through the holes in the mounting brackets to give you enough leverage to twist them when the screen is removed.
Technically the screen should work: both are driven via LVDS connector that look identical, both use the intel 4000 graphics chip.
However, the hinges screw position are in different positions. So, unless someone finds a way to fit the mid-2012 hinges onto the late-2012 screen assembly, then the next step would be to manually dismantle the screens and graft the late-2012 matrix inside the mid-2012 enclosure. Great to try if you have a few hundred bucks to burn.
My girlfriend just bought a 2012 macbook pro and the little plastic on the bottom seems to pop out of place slightly and it’s a little annoying does anyone know a fix for this seems simple but i don’t wanna touch the computer till i’m sure
If you’re referring to the plastic bezel on the bottom of the display, the bezel is attached to the display assembly so if it is loose you’ll likely need to pop the display off the main chassis and reseat the bezel. You may be able to reseat the bezel without doing this but it will be a lot easier to fix it if you take the display out. Just follow the guide on replacing the display and then once you have the display removed you have better access to the bezel and can then lock it in better. If you need help reseating it just look online for info on reinstalling the bezel on the display.
Just wanted to say thanks! Bought a display assembly from you kind folks and had my mac up in running in less than an hour!
Works Perfectly Thanks Andrew! Your Awesome, and to all the guys at fix it you guys rock
An easy-to-follow, pretty much stress-free repair guide! With the step-by-step breakdown, I can pause for lunch if I want to, then get back to my repair at the correct step. Thank you SO much, AOG❣️
The screens from MacBook Pro 13 mid 2012 and 2011 are COMPATIBLE 100%, I already did replacement - you need to open up just a little bit the females’s connector by the sides - 0.01mm (or something). I put 2011 screen on 2012 logic board. Write me for fotos, if interested.
I’m curious. I am having a “double image” issue on my 2012 MacBook Pro 13” (unibody). Would replacing the display solve this issue?
Double image: There is an exact copy of whatever is on the screen appearing just below the “real” image. A ghost, or shadow image if you will. When I connect an external monitor to the laptop no double image is seen upon the external monitor, but still is prevalent on the MacBook screen.
I would probably first check to make sure the cable that’s connecting your Macbook display to the main board is seated properly before exploring the expensive display replacement. You may be just looking at a faulty connection between the board and the display. Worst case scenario, the connector itself on the main board is damaged in some way resulting in the bad connection. Which would be an expensive replacement. If the cable on the display itself is damaged, you’ll need a whole new display. But determining any of this is going to require testing on your part. I’d also consider the possibility the display panel itself is damaged as well.
I took my screen off my macbook to tighten the hinges because it became loose. After I reassembled and turned on the machine, the screen no longer works. One mistake I made during disassembly was not disconnecting the power cable and I accidentally hit the power button while working on the machine. I don’t know if that has anything to do with it.
Hi
I have a MacBook Pro 13-Inch "Core i5" 2.5 Mid-2012 Specs.
Recently I changed my default HDD to the SDD and also replaced one of the default 2GB rams with an 8GB ram. (now the system totally have 10GB )
after turning up the laptop I saw some light which known as “stage light”.
Also, I tried to reconnect the LVDS cable, which is located between the fan and the edged of the body, however, “stage lights” are still there
Gracias, realíce el cambio de la batería y me quedo increíble, gracias
anywhere suggestions where to buy replacement screen (model A1278) in EU?
What if I only need to replace the glass, not the display?
Bonjour,
Merci pour vos tutoriels, toujours bien faits et explicites.
Pour le modèle mentionnée, j’aurais 2 questions:
- est-il possible de changer la dalle ou la vitre uniquement ?
- où acheter un écran complet ?
Merci d’avance de vos réponses.
Valentino
How much weight can I save by removing the optical drive?
gunes314 - 返信
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - 返信
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - 返信
iFixit sells a kit: MacBook Pro Unibody Lower Case Screw Set
Darrell Johnson -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - 返信
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
We have a guide for that!
ネジ山が潰れたネジを取り出す方法
Sam Omiotek -
My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
jeremyyoung - 返信
A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
Iain Boyd - 返信
I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
cam2000deluxe -
Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
Patrick Langvardt - 返信
That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
Gary Register -
Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
Degeorges - 返信
Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
Claire Miesch -
Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
Moritz - 返信
