はじめに
Replace the subwoofer & right speaker in your MacBook Pro 13" Unibody Mid 2010.
必要な工具と部品
Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Remove the soft padding that may be on top and gently pull the connector up out of its socket on the logic board.
Peel back the small piece of black tape covering the right speaker cable.
52 の人々がこのガイドを完成させました。
3 件のコメント
Hello, I've just brought a MacBook Pro 8,1 to life with an SSD. It works great but unfortunately no sound. There is no output listed in sound window. I tried cmd+opt+P+R without success. Would replacing the speaker assembly solve the problem or is this a hardware problem? Thanx
PS- I also restarted cord...something in processes that didn't work either.
