メインコンテンツにスキップ
MacBook Pro 13" Unibody Mid 2010 Key Cap Removal
  1. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Identify the Keyboard Key: 手順 1、 1の画像 1
    • The small lug that holds the button's hinge pin is clearly visible in the circled area, and the other half of the pair is pointed to by the arrow.
    • The video demonstrates how to insert the blade of a knife carefully behind the lug and push it in far enough for the pin to clear the lug.
    • Depending on the tool you use, be careful not to damage the plastic of the keys or the key's hinge mechanism.
  2. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Remove the Key: 手順 3、 2の画像 1 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Remove the Key: 手順 3、 2の画像 2
    • Once the key is freed from the left side mechanism, it is still connected on the right side.
    • Release the key by rotating it counterclockwise with a tool or your fingers.
  3. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal: 手順 4、 1の画像 1
    • Unclip the lever arm by carefully inserting a spatula or a knife (be careful, the metal can damage the fingerboard).
    • Detach the white part of the key. Take this opportunity to clean any dust or debris from the key or the hinge mechanism.
  4. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Reassembling the Hinge Mechanism: 手順 5、 3の画像 1 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Reassembling the Hinge Mechanism: 手順 5、 3の画像 2 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Reassembling the Hinge Mechanism: 手順 5、 3の画像 3
    • Insert the hinge (framed in the photo) into the metal slot in the keyboard as shown in the second photo.
    • The third photo shows the hinge mechanism properly in place.
  5. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Insert the Hinge Pins: 手順 6、 2の画像 1 MacBook Pro 13" Unibody Mid 2010 Key Cap Removal, Insert the Hinge Pins: 手順 6、 2の画像 2
    • As shown in the photo, reinsert the hinge's pin into the metal lug on both sides.
  6. MacBook Pro 13" Unibody Mid 2010 Key Cap Removal: 手順 7、 1の画像 1
    • The final step is to place the key on the hinge mechanism and press hard on it so that the key clicks into place; the sound of the clips locking will be perceptible. There are four clips holding the key cap.
終わりに
Congratulations; you can now remove and replace most any key on the keyboard.
6 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
fr en
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Alexandra Lem
メンバー登録日: 03/11/20
486 ポイント
1ガイドが承認済み
1件のガイドコメント
Y en un MacBook pro retina mid 2014? La pieza que engancha es completa de plastico y tengo miedo de tirar de más
Sergio Manzanero - 返信
コメントを追加
統計データ:
過去 24時間: 19
過去 7 日: 159
過去 30 日: 627
今までの合計 13,063
