メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
MacBook Pro 13" Unibody Mid 2010 のバッテリーを交換するためのガイドです。バッテリーが膨張した場合、適切な予防処置をとってください
  1. MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
  2. 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
  3. 上部ケースにバッテリーを取り付けている次のトライポイントネジを外します。
    • 上部ケースにバッテリーを取り付けている次のトライポイントネジを外します。
    • 5.5 mm トライポイントネジ 1本
    • 13.5 mm トライポイントネジ 1本
    Mine does not have triwing screws.... They have 5 points but none of my torx stuff works? What is it? I have one of your sets of 20 or so pieces and nothing works.....
    Chris Babcock - 返信
    pentalobe. its an apple specific driver to keep you out. The bottoms of the airs use this as well. You can fid one on eBay
    ryan rochford -
    Where in the world can I find a tri-point screw bit?
    Mason Darien - 返信
  4. スパッジャーの平面側の先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    • スパッジャーの平面側の先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    use two spudgers, one of each side of the connector.
    Sebastien CHAPUIS - 返信
    I was able to use 1 spudger. Just wiggled a little on each of the 3 free sides of the connector, and kept going around until the connector freed up.
    Brian - 返信
  5. 上部ケースからバッテリーを持ち上げます。
    • 上部ケースからバッテリーを持ち上げます。
    • この修理ガイドを完成したら、新しく装着したバッテリーのカリブレーションを行なってください。
    • 100%になるまで充電します。充電後も最低2時間はプラグを繋げたままにします。それからプラグを外して、通常通り使用しながら、自然に放電させます。バッテリー残量小のサインが表示されたら、これまでの作業を保存して、スリープ状態になるまで放置してください。スリープ状態に入ったら、少なくとも5時間置きます。それから一気に100%まで充電します。
    • 新しいバッテリーを装着後、通常通り作動しない場合は、MacBook ProのSMCをリセットしなければならない可能性があります。
    Did everything correctly, but now the battery doesn't charge. Do I have to do something in particular to make it work now that's installed? Thanks
    Olivier - 返信
    I am answering a 2 year old post but this is for those who may have the same or similar issue in the future.
    When I was putting the battery connector back on that it didn't sit flat against the board before I put pressure on the top of the connecter to press it back into its socket. I then took time to examine the battery connector socket and saw it consisted of long thin vertical pins. I deduced that if the battery connector was not aligned correctly to the pins on the motherboard then it may be very easy to bend one or more of the pins in a way that they wouldn't mate up with the opposing female part on the connector. That sure would cause a battery charging issue. If you feel too much resistance when pressing the connector back into the socket then stop and make sure it is all aligned correctly. I know, not easy with the size, the black connector and black socket. A spudger can be used on the battery side of the connector to raise it to a level position prior to applying pressure to the top of it.
    Joseph King -
    I too encountered the same problem. After resetting the SMC (http://support.apple.com/en-us/HT201295), it resolved the problem.
    2CentsNoneTheRicher - 返信
    I put the battery in ok, then placed it on charge and tried to start it. It didn't like this at all, letting out evenly spaced unfamiliar beeps. I felt sure i had done something terrible. I held down the start button and turned it off. Half an hour later I turned it back on, upon which it sprung back to life, much to my relief. The battery needed to be charged before starting it seems.
    Guy Wishart - 返信
終わりに
再度組み立てる時は、分解した順番と逆の順番で組み立ててください。
642 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
Walter Galan
658,068 ポイント
1,203のガイドは作成済み
18 件のコメント
You guys are awesome! My granddaughter spilled a whole coke on the Mac and it went fizz! After some weeks I took it to the Apple store where it was declared it dead. They offered me a refurbished machine for $800, but insteaed I came home, took the disk out and hooked it via a USB carrier to another Mac which proved that the disk had not been harmed. I put it back in the machine and booted up at which point it became obvious that the battery was dead. One pass at Google turned up IFixIt where I found the battery and the correct, goofy tri-point screwdriver. The battery arrived a bit ago and the Mac is up and running as if nothing happened . . . a tidy savings of $650!
Thanks so much1
amzbay - 返信
This was a total life saver! A few weeks ago my house was hit by lightning and even though my computer wasn't plugged in (thank God!) my charger was completely fried. I ordered a new charger but my computer still wasn't working- Apple said my computer was done for. A friend said it was probably my battery and told me about ifixit.com. I was able to buy a new battery and change it myself (it was so easy!!!). Saved me from spending a bunch of $$ at the Apple store. I move out of the Country in a few weeks and didn't know what I was going to do without a computer. Thanks ifixit!!!
talithab - 返信
When I followed this exactly, I booted up my MacBook to see that my battery had an x through it with the no battery availible popping up when I scrolled over it. I (stupidly) left the computer on while I browsed for a solution. The whole time my charger showed a green light. Suddenly the computer turned off and hasn't been able to be turned back on since despite switching to another battery and another charger. The charger still shows a green light, which means the battery is either fully charged or installed incorrectly. I don't understand how it can be installed incorrectly when the only part to put it into the computer is the plug in. Please someone help me, I have no idea how to fix it and have made multiple forums on here asking for help, to no avail.
Jack Roche - 返信
I think you are SOL. I had same problem a few days ago. I have attempted everything I could find from online resources. Bottom Line: ship it to an Apple authorized repair shop or an Apple Store. Battery replacement Cost is now only $130, which isn't much more than iFixIt cost.
gkofga -
Your connector or socket may have broken. Open the Mac and check if you missed something.
TheYootz Media Group -
Don´t bother ordering a battery from anywhere other than iFixit. Their batteries are actually OEM parts and they include a warranty for 1 Year (most batteries from other places, like amazon, typically have 30, 90, 180 day warranties. After installing, make sure to FULLY charge the computer (don´t use it during the first charge!) to make sure your battery life is prolonged to its fullest lifespan.
Everett Whiteman - 返信
iFixIt batteries do not work if you are running OS 10.11.2. Tried 2 iFixIt batteries and received guidance from iFixIt customer support.... Same result, it didn't work. Just spend a few dollars more and take it to an Apple Store.
gkofga - 返信
So what was the reason given by Apple as to why the battery replacement did not work? I just replaced mine 2010 mbp, running 10.11.5 seemingly no issues.
Jack -
Great guide. When I saw how simple these instructions looked, I made up my mind: instead of leaving my MacBook Pro for a week at the local Apple Service Provider (why should they have to keep it so long?), I would change the battery myself at about a third of the cost. Working slowly and carefully, the whole thing took less than 10 minutes.
I would add just one thing: those 3 mm Phillips screws are really, really tiny. Do be careful where you put them down!
michaelcook - 返信
How long does battery keep off power? Also, further above are reports of issues with 10.11.2. I am on 10.11.4. Does it work? Thanks
iangrech - 返信
I have a 2010 mbp running 10.11.5, just swapped in the battery yesterday, seems to run fine. system shows the battery info including age of battery and number of charge cycles (up to 2 now!).
Jack -
Just received my replacement battery today, and it was so so easy to put in - everything worked exactly how they described it would!! my battery is charging normally again and it says the battery condition is normal (before it said: replace now) and its charging well so far. This was one of the easiest cost effective things I've ever done. Save yourself time and money, and use this site to fix your battery.
Roseann Harmon - 返信
Tip tope Anleitung. Teure Reparatur im Apple Store für meinen Opa gespart. Vielen lieben Dank. Diese Anleitung hat mir Mut gemacht und ich dachte schon, ich könnte unter Umständen mein MacBook Pro auf den Müll schmeissen. Vielen lieben Dank dem Autor. Ich bin begeistert.
Alice Obrist - 返信
Thank you fixit.com
I bought the three tools and battery on your web site.
Followed your straightforward instructions.
Now my computer works again.
Horrible apple company telling me a 2010 machine is too old to fix.
Is that their idea of recycling.
Is that how proud they are of their production, that I should have thrown a perfectly healthy seven year old laptop away.
REPAIR IS NOBLE !!!
Jonathan Baines - 返信
OWC, also a reputable source of Mac stuff, sells a replacement battery and has a video showing how to remove the old one and install the new one (https://eshop.macsales.com/item/NewerTec...). At the beginning of the video the viewer is warned that the battery will have to be calibrated for best results, that the procedure will be demonstrated at the end of the video, and it should not be skipped. Basically, the procedure involves charging the battery until it is full, completely discharging it, then recharging it. I suspect the calibration might apply to the iFixit replacement battery as well.
Regarding that battery and a report that it doesn't work for OS X 10.11.2: What about later versions? I have 10.11.6.
Thanks.
Richard Liu - 返信
The battery in my old MBP (2010) was swollen to the point of not being able to use the touchpad. I received my new battery from you today and replaced it. Works wonderfully! I’m sooooo happy I went this route and didn’t pay a local shop $200 for the battery and less than 10 minutes of labor! Thank you!!!
Clarisa Marcee - 返信
After nine years of faithful service suddenly last week my MacBook Pro 13’s battery wouldn’t charge. I strongly considered taking it to an authorized center, but instead after some research on the internet, bit the bullet, crossed my fingers and bought a new battery off of Amazon. Even after it arrived I was still hesitant to undertake the operation myself, but thanks to your fantastic tutorial the removal/install worked without a hitch. Thank you!
William Campbell - 返信
Great Fix! I did this in 2018, my MacBook battery life had dropped to 0, and I had to constantly keep the computer plugged in. Eventually it just shut off and even keeping it plugged in wouldn’t work. Did this change and now have a very functional battery 2+ years later. Source of the battery was iFixit.
Alan Sulpizio - 返信
コメントを追加
統計データを表示:
過去 24時間: 48
過去 7 日: 360
過去 30 日: 1,776
今までの合計 564,449
