メインコンテンツにスキップ
MacBook Pro 13" Unibody Mid 2010のディスプレイの交換
必要な工具と部品
  1. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換, 下部ケースのネジを外す: 手順 1、 1の画像 1
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I use a magnetic mat and place the screws in order on that :)
    Cary B - 返信
  2. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換, 下部ケースを持ち上げて外す: 手順 2、 1の画像 1
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - 返信
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換, バッテリー: 手順 3、 1の画像 1
    • 作業前の注意点として、放電を防ぐためロジックボードからバッテリーコネクターの接続を外してください。
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    gansodesoyaからの引用:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 返信
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 返信
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 返信
  4. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換, ディスプレイ: 手順 4、 1の画像 1
    • スパッジャーの平面側先端を使って、サブウーファー/右側スピーカーのケーブルコネクタを基板上のソケットから引き抜きます。
    • ワイヤの下から引き上げます。
    Mine had a small piece of insulating material on top of the connector. By removing that first, I could then pry up the connector with less stress on the cable.
    istlota - 返信
    Great tip! Thanks.
    juliet - 返信
  5. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 5、 1の画像 1
    • カメラケーブルのオス側の先端を引っ張って、カメラケーブルの接続を外します。
    • コネクタを基板の表面と並行に、光学ドライブ側に引っ張ってください。ソケットからまっすぐ上向きに引っ張らないでください。
  6. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 6、 1の画像 1
    • カメラのデータケーブルを光学ドライブのチャンネルから巻き戻します。
    for easy dismantle, just remove 2 screw of subwoofer
    Mohamad Faizal Sharudin - 返信
  7. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 7、 2の画像 1 MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 7、 2の画像 2
    • 次のネジを外します。
    • 10 mmプラスネジー2本
    • 3.8 mmプラスネジー1本
    • サブウーファーの下からカメラケーブルのブラケットをスライドして、デバイス本体から取り出します。
  8. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 8、 3の画像 1 MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 8、 3の画像 2 MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 8、 3の画像 3
    • ディスプレイデータケーブルのロックに固定されているプラスチックのプルタブを掴んで、デバイスのDC-In サイドに向けて回転させます。
    • ディスプレイデータケーブルのコネクタをソケットからまっすぐ引っ張ります。
    • コネクタをまっすぐ引っ張り、裏返します。上向きに引っ張らないでください。
  9. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 9、 2の画像 1 MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 9、 2の画像 2
    • 上部ケースにディスプレイデータケーブルのブラケットを固定している次の2本のネジを外します。
    • 8.6 mm プラスネジー1本
    • 5.6 mmプラスネジー1本
    • ディスプレイデータケーブルのブラケットを上部ケースから持ち上げます。
  10. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 10、 1の画像 1
    • もしお持ちのデバイスに付いていれば、ディスプレイデータケーブル付近のディスプレイ用ネジに留められたフォーム製テープの一片を剥がします。
  11. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 11、 2の画像 1 MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 11、 2の画像 2
    • 上部ケースに2つのディスプレイブラケットを固定している、外側の6.5 mm T8トルクスネジを2本外します。
    You may have to lift/remove a foam tape on the left side as well
    Sebastien CHAPUIS - 返信
  12. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 12、 1の画像 1
    • MacBookを開口します。それからディスプレイを垂直に立てます。
    • 画像のように開口したMacBookをテーブル上に配置します。
    • 左手でディスプレイと上部ケースを固定しながら、下部のディスプレイブラケットから残りの6.5 mm T8トルクスネジを外します。
  13. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 13、 1の画像 1
    • 左手で必ずディスプレイと上部ケース両方を押さえてください。ディスプレイと上部ケースが外れてしまうと落下の原因となり、各コンポーネントに致命的なダメージを与えてしまいます。
    • 上部ケースとディスプレイを固定している最後のT8トルクスネジを外します。
    When reassembling, Careful not to drop your screw, or it may get stuck to the (magnetic) power adapter port. Oops!
    Save yourself some time and don't drop it!
    rowdyferret - 返信
  14. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 14、 2の画像 1 MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 14、 2の画像 2
    • 上部ケースを右手で掴んで、ディスプレイの上部に向けて若干回転させます。すると上部ディスプレイブラケットが上部ケースの先端から外れます。
    • ディスプレイを上部ケースからわずかに外します。
    Make sure you make a 90 degree angle between the keyboard and the display before taking out the screws. If you have less than a 90, you will never get it apart due to the upper display bracket shape. It has to be at the right angle or it won't come out.
    mastover - 返信
    I place it over keyboard side down hanging over a table. This way I know it's at 90 degrees and it also makes it easier to take it off.
    Nick - 返信
  15. MacBook Pro 13" Unibody Mid 2010のディスプレイの交換: 手順 15、 1の画像 1
    • ディスプレイを上部ケースから持ち上げて外します。ブラケットやケーブルが絡まないようにご注意ください。
    As mentioned in the previous step, place it keyboard side down with the edge hanging over a table. This way it's at 90 degrees and it makes it easier to align and get the screws in.
    Josh - 返信
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
78 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Andrew Bookholt
586,185 ポイント
619のガイドは作成済み
5 件のコメント
Awesome guide!! Thank you so much for walking me through this. It was surprisingly easy. Only took me about 30 min to do. Best Buy Canada quoted me $900 to do this repair. Total cost of tools from iFixit and parts from eBay... $280 :) THANK YOU IFIXIT!!!!!
spenczoid - 返信
Thanks for the guide, it was spot on. I dropped my beloved MacBook Pro and it cracked the display. Following the guide was a snap even for my old eyes, the ability to make the pictures full screen is great.
jackpollard - 返信
I found a used complete display unit for sale on ebay. Delivered 50$ and half an hour of work and am up and have a lovely MBP 13 inch mid 2010. Many thanks for the useful and detailed guide.
keithp198 - 返信
Had the standard problem with a loose screen on a MacBook Pro 13in 2010. Followed the guide which is very clear and got to the screws which I could then tighten. Reassembled and on booting could hear the fan but no display aside from a few flashes. Rechecked the screen data cable connection which was slightly mis-aligned. corrected it and it worked fine. That connection is very sensitive!
Saved me $900 quoted by the Macstore - 90 mins work on my own and a few grey hairs. A glass of red wine helps.
Norbert - 返信
Just followed the steps and I successfully reinstalled a new screen/lid assembly. The only problem being was step 4. When gently (underline gently) removed the audio cable, all of the pins fractured and remained in the board so now my onboard audio is highly limited. I have to ask why was that step necessary as the removal/reinstall would have been completely possible without step 4. Greg
gdmenginc - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 25
過去 30 日: 113
今までの合計 85,176
