メインコンテンツにスキップ
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのMacBook Pro 13" Unibody Mid 2009を修理する際は、iFixitの修理ガイドをご利用ください。
  1. MacBook Pro 13" Unibody Mid 2009 Teardown, MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 1、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown, MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 1、 2の画像 2
    • This just in: the new MacBook Pro 13" Unibody!
    • We'll be comparing it to the MacBook Unibody throughout the teardown.
    • We have a feeling it will be very similar in most regards.
    • Would you like to write teardowns like this? Show the world what's inside your gadgets with our new user-contributed teardown platform!
  2. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 2、 1の画像 1
    • Contents of the box:
    • User's manual
    • Restore DVDs
    • 60-watt AC adapter
    • AC adapter extension cable
    • Cleaning cloth
    • No video adapter, as usual.
  3. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 3、 3の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 3、 3の画像 2 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 3、 3の画像 3
    • Some comparisons to the MacBook Unibody:
    • No access door for the battery on the bottom.
    • The addition of an SD card slot (and the omission of digital/mic port) is readily apparent.
    • FireWire is back!
    • Computer lock is now on the other side.
    • The SD card sticks out almost .5"! This is a cheeseball design for a MacBook "Pro" if you ask us.
  4. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 4、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 4、 2の画像 2
    • Let's get down to business.
    • There's no door latch, going along with the "not user-serviceable battery" theme.
    • We had to dig out a Phillips screwdriver for this step.
    • A quick flip of the lid and...
  5. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 5、 3の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 5、 3の画像 2 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 5、 3の画像 3
    • ...It's almost exactly the same as our old, "lesser" MacBook Unibody.
    • The battery compartment is identical to the one we uncovered in the MacBook Pro 17" Teardown. We'll venture a guess that it looks the same in the updated 15" Pro as well.
    • Remove two tri-wing screws and the battery is suddenly replaceable. The sticker comes right off, just as in the 17" Pro -- because it's adhered to just the battery and midwall, not to the optical drive.
  6. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 6、 3の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 6、 3の画像 2 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 6、 3の画像 3
    • 7-hour battery specifications:
    • Model A1322
    • 10.95V
    • 60Wh
    • "This battery contains no mercury (Hg)."
    • When working on all machines that have internal batteries, disconnect the battery first to cut off power to the entire device.
    • Apple does offer battery replacement service for $129. If you're not near an Apple Store or service provider, you'll be without your machine 3-4 business days.
    • Although the batteries look similar, they're definitely not interchangeable. The MacBook Pro's battery is too large (and different in shape) to fit into the older MacBook Unibody.
  7. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 7、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 7、 2の画像 2
    • Removing the hard drive...
    • It's still considered user-replaceable by Apple, but replacement does require removing 10 more screws than on the MacBook Unibody.
    • First thing we'd do is replace the 160 GB Hitachi with something more meaty.
  8. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 8、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 8、 2の画像 2
    • The subwoofer comes off after removing two screws.
  9. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 9、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 9、 2の画像 2
    • The optical drive is attached via three Phillips screws.
    • The brackets and screw layout are identical to the older MacBook Unibody.
  10. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 10、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 10、 2の画像 2
    • Removing the optical drive exposes the right speaker.
    • It's held in place by adhesive. A quick pry with the spudger will loosen it.
  11. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 11、 3の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 11、 3の画像 2 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 11、 3の画像 3
    • A connector, three Phillips screws, and bam -- the fan's out!
  12. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 12、 3の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 12、 3の画像 2 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 12、 3の画像 3
    • Disconnect the LVDS connector.
    • Remove 7 motherboard screws.
    • Remove 2 DC-in screws.
    • Disconnect trackpad, keyboard, and battery level indicator cables.
    • Remove LVDS cable retaining bracket.
    • And the logic board is almost out...
  13. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 13、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 13、 2の画像 2
    • Pop out the microphone from its cave.
    • The logic board is finally free!
  14. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 14、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 14、 2の画像 2
    • A couple of images of the logic board, before we strip it naked...
    • Like the MacBook Unibody, the heat sink comes out along with the logic board.
  15. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 15、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 15、 2の画像 2
    • Both sides of the logic board.
  16. MacBook Pro 13" Unibody Mid 2009 Teardown: 手順 16、 1の画像 1
    • And here's the whole enchilada for you to enjoy.
作成者
8人の作成者と共同で作成されました。
Miroslav Djuric
158,300 ポイント
144のガイドは作成済み
10 件のコメント
Hi. AMAZING walkthrough and I really love your website. I need HELP!
I bought a refurbished MBP 13-inch 2.26 GHz and I don't think it came with a wireless card (I think I got ripped!). Bluetooth is working but my airport says "No Airport card installed".
Anyway - is it possible to check if the wireless card is in there? If not, is it possible to replace it? Any help and advice would be greatly appreciated!!!
James McGrath - 返信
The AirPort card is hidden in the display. We don't have a guide specifically for it, but you can follow the display guide to remove the display and then use the clutch cover guide to access the AirPort card (you don't have to remove the front display glass to access the card; the clutch cover guide was part of another guide for the LCD but the steps are generally the same).
Andrew Bookholt -
HELP, how I need to know the difficulty of replacing a LVDS cable. Make screen is fadeing to white and freezes when the screen moves.
acmilanav - 返信
great guidelines.... I have a macbook pro mid2009 A1278. buzzing sounds coming out when I play any music. is there any fix?
Ehsun Newaz - 返信
Hi, I have a macbook pro Mid 2009, now it very slow. can it upgrade? If it must upgrade What I I do for it?
Give me some your opinion, Thank you very much!
Sicerely
Tao Nguyen
nnhattao@yahoo.com
TAO NGUYEN - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 41
過去 30 日: 165
今までの合計 825,581
