はじめに
MacBook Proの右側がミュート状態ですか?このガイドを使って、サブウーファーと右側スピーカーを交換しましょう。
  1. MacBook Pro 13" Unibodyに留められた底ケースから次のネジを10本外します。
    • MacBook Pro 13" Unibodyに留められた底ケースから次のネジを10本外します。
      • 3 mmプラスネジー7本
      • 13.5 mmプラスネジー3本
    It looks like you need a Phillips #000 screwdriver for the 10 bottom screws. I tried the #00 and it's too big. Good thing I bought a 23 piece precision screwdriver set or else I would have been screwed.
    scott523 - 返信
    The 10 screws that hold tha bottom case take a #00 Phillips driver, if yours doesnt fit it's probably because it's cheaply made & not precise enough. The only thing that I needed a #000 driver for was the keyboard screws. They're so small they look like specks of dirt or sand. I stripped out 4 of them & now will need to grind the heads off with a Dremel/rotary tool. The other thing that sucks is iFixit doesn't have a tutorial for keyboard replacement!
    iphonetechtips -
    A true Phillips head screw's slots are rounded at their inner corners, to allow the screwdriver to "cam out" (pop out) of the screw head before you apply too much torque and strip the threads in the part that you're torqueing the screw into. However, the screws used in the Macbook don't have those rounded inner corners, so they're not Phillips. Instead, they may be a Japanese standard known as JIS B 1012, or a Frearson (also known as a Reed & Prince), but that's a less common design. Maybe technically these non-Phillips screws should be used with a screwdriver that was specifically designed for them, but they can be properly removed and reinstalled using a truly precision-made Phillips #00 (some people find a #000 sometimes works even better) whose tip comes to a sharp point--not the lousy fake "precision" screwdrivers that are sold in too many places. See my next comment for more.
    johnsawyercjs -
    Many screwdriver manufacturers get away with marketing fake "precision" screwdrivers because, in the words of the Wikipedia article at https://en.wikipedia.org/wiki/List_of_sc...: "Most heads come in a range of sizes, typically distinguished by a number, such as "Phillips #00" or "Torx T5." These sizes do not necessarily describe a particular dimension of the drive shape, but are often arbitrary designations in the same sense as a "Size 8" dress."
    In other words, the quality of many "precision" screwdrivers is poor. In my experience, one of the biggest problems with many fake "precision" Phillips screwdrivers is that the four blades at the tip are often too wide, and their width may even vary on the same screwdriver (they're not supposed to). So just because a screwdriver is marketed as a "precision screwdriver", it may not be, and many that are labeled as #00, or even #000, will not work for a Macbook's screws. See my next comment for still more.
    johnsawyercjs -
    One of the best manufacturers of precision screwdrivers is Wiha (http://www.wihatools.com/tech-tools/prec... cost more, but they're worth it. Or buy screwdrivers from iFixit, who seem to be selling JIS screwdrivers.
    Another article with some good info on screw and screwdriver types:
    http://www.instructables.com/id/When-a-P...
    Also keep in mind that some screws are tougher to remove and reinstall because they have a thread-locking compound on them, which is usually blue.
    johnsawyercjs -
    Phillips #00 is the correct screwdriver for the lower case. Maybe the one you have is worn or badly made.
    David Fear -
    Perfect man!Many thanks!:)
    wertaerte - 返信
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    twisk - 返信
    thanks twisk, I wish i would have read your tip before I finished putting the bottom of my laptop back together. I managed to get all screws in somehow, but one was in fact too-tight.
    BTW, big big thanks to the Author: Andrew Bookholt. Just used this guide and my trackpad now works again.
    xitxit2 -
    i too need a #000 for the bottom of the case -- i got the recommended screwdriver (#00) and unfortunately it's too big
    plins718 - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    The colours you used for these circles are indistinguishable for colour-blind people. Please consider using something like the palette suggested by visibone: http://www.visibone.com/colorblind/
    Eric Sorenson - 返信
    Squares, Circles, Triangles (you get the idea) would work as well to distinguish the different screws.
    danzeitlin -
    I'd use a Phillips #000 screwdriver also. The #00 can work, but if the screws are in really tight, it doesn't get far enough down into the screws to get purchase, so it will start to strip (and I agree that the screws are pretty soft). On mine, the screws for the fan were really tight, started to strip with #00, needed a #000 and quite a bit of pressure to get them to move.
    jonathanmorgan - 返信
    I thought it took a 000 as well. However, I tried both and realized the 00 works best.
    john - 返信
    Hi i was wondering if you can add 16gb to this model? or is 8 the maximum?
    Igor - 返信
    The Mid 2010 MacBook Pro 13" does support 16 GB RAM, but it is very picky about the type of RAM. OWC sells a 16 GB kit (2x 8 GB). I think it's got to be 1066 (aka 1067) MHz RAM. A lot of 8 GB modules on the market now are faster than 1066 MHz, and reports I've read say people start getting kernel panics if they use the wrong RAM.
    Some info here:
    http://www.everymac.com/systems/apple/ma...
    "1066 MHz PC3-8500 DDR3 SDRAM"
    "*Originally, both the official and actual maximum RAM was 8 GB. However, as confirmed by site sponsor OWC, if running OS X 10.7.5 or higher, updated with the latest EFI, and equipped with proper specification memory modules, this model can support up to 16 GB of RAM."
    Our Mid 2010 already had "the latest EFI" (i.e. Boot ROM version in System Profiler), so the reference to updating it may not be relevant.
    Winston -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I had the same problem. The #00 screwdriver worked for some of the screws but some others were too tight and I had to use a #000. Maybe it was because the cover had slightly bent because the battery inside had basically doubled its width, but I still found that the #000 was a much better fit for these screws. Even the ones that came out with the #00 came out much easier with the #000. I would suggest updating this guide to suggest using a #000.
    tarriojuan - 返信
    Had no idea they were so expensive.
    Franklin - 返信
    Phillips #00 is the right tool for all the steps (Except the 4 HD T6 screws). Maybe there is dirt in the notch.
    Luis Soto - 返信
    There is any chance to use the Toshiba MQ01ABD 1 TB 2.5" Internal Hard Drive MQ01ABD100 , it has7200 rpm , shuold it work?
    Luis - 返信
    If you are running OS X 10.11.2 or newer, battery provided by iFixIt will not work. I've already tried 2 batteries from iFixIt and neither worked. iFixIt needs to come clean on this unfortunate situation. I've already put 8 hours into this futile effort when it should have taken me 45 minutes.
    gkofga - 返信
    What was your solution? I'm using 10.11.3 OS X. I may need a battery replacement very soon too.
    John Doe -
    <i>The 10 screws that hold that bottom case take a #00 Phillips driver, if yours doesn't fit it's probably because it's cheaply made & not precise enough.</I>
    I purchased the IFixIt 54 bit Driver Kit and their Phillips #00 are <b>NOT</b> the appropriate size for the bottom screws on this MacBook Pro. This manual needs to have the tools changed to Phillips #000 Screwdriver. Until then I shall not click the "Give the author +30 points" button. Apart from that, the rest of the manual is very good. It would also be an idea to make a comment about making sure the battery connector is in the correct position when plugging the battery back in. One poster commented that their battery will not charge anymore. My guess is a pin(s) was/were bent due to the connection not being in the vertical orientation when being pressed back together. :-)
    THANK YOU for writing and generously supplying this guide for our use. It is much appreciated. +30 point coming when the Phillips #000 size is changed or added.
    Joseph King - 返信
    It would be nice to remind fixers which length screws go back in which holes, in case they get mixed up...
    Mike - 返信
    Wonderful guide
    Freda - 返信
  2. 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    • 作業前の注意点として、放電を防ぐためロジックボードからバッテリーコネクターの接続を外してください。
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    why is step 3 necessary?
    gansodesoya - 返信
    Quote from gansodesoya:
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 返信
    Removes the possibility of any current flow. This is especially important if you are trying to mitigate the damage to the circuitry due to a spill on a keyboard.
    amiller770 - 返信
    I'm thinking of ordering the spudger. I was thinking of order the heavy duty spudger... or should I just order the normal. Will either of the spudgers work for this DIY?
    shockaaa - 返信
    Once you have a set of spudgers, you will wonder how you ever went without them. :-)
    Brian -
    $@$@. Don't use an non-isolated screwdriver for this. I just shorted-out my battery :(
    Lukas Besch - 返信
    You are absolutely right, never use a screwdriver on the logic board or any connector! Delicate use of fingernails or a credit card will get you through most situations if you lack a spudger.
    Logan Bean -
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 返信
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    Would it not be advisable to drain the battery completely before attempting to repair, if you want to be sure you don't get a spark when removing the battery connector?
    Berlugana
    bduault - 返信
    Disconnecting the battery connector is not that different from simply unplugging a battery from an older model MacBook with a removable battery. You're not trying to protect yourself from a "spark", but the internal circuitry when taking the MacBook apart.
    amiller770 -
    I neglected step 3 and now my computer won't turn on. Could I have shorted out my logic board?
    Plamen - 返信
    I had the same problem , my macbook doesn't switch on working
    marioluiggi -
    A very easy and fast update indeed! Using this guide and the tools indicated on top I replaced the two RAM cards (2GB each) with two 8GB RAM cards from OWC for a total of 16GB RAM in my MBP Middle 2010 Core 2 Duo (Officially not supported according to Apple).
    Make sure you select RAM with these specs: 16GB DDR3 PC8500 1066MHz Kit (8GBx2)
    Apps open much faster and I can run a virtual machine at a decent speed.
    Luis Soto - 返信
    Removing the battery is not required, but in some instances can make installing ram much easier. If you plan on upgrading from 4GB (2X 2GB) to 8GB (2X 4GB) Removing the battery would be better. There are two levels of ram. If you are replacing both levels, then remove the battery. If you are just replacing the top, dont bother. Removing the battery for very long or even at all (depending on the CMOS battery age and health) could possibly reset settings, the clock, saved wifi passwords, and more.
    Everett Whiteman - 返信
    It is beneficial to remove the battery at this stage.
    Knox Karima - 返信
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 返信
    Guys I just used my index finger nail. It’s the most useful nail to let grow a little bit for this type of procedure. Came off pretty easy when using both my right hand index and left hand index together to lift the plug up out. Found some plastic folded it and place it right over the socket so the plug would go back in and now the plug holds the plastic in place so I can focus on the main work.
    clsmithj - 返信
    • スパッジャーの平面側先端を使って基板から右側スピーカー/サブウーファーケーブルコネクタをまっすぐ引き抜きます。ソケットを持ち上げないようにご注意ください。コネクタを光学ドライブ側に引っ張ります。
    • ワイヤの下から持ち上げます。
    Step 4 is clearly wrong! You MUST NOT pry the right speaker/subwoofer cable connector straight up off the logic board! You must pull it toward the optical drive!!!
    I followed your manual, pried it upwards and broke off the socket!
    Jan - 返信
    how have you repaired it then?
    Antonio Minnici -
    Step 4 is correct as stated (pull up, not slide out). You'll definitely see this when you put it back in place, pushing down in socket not sliding in. Just be careful and use spudger (gently!) underneath wires as shown.
    jgcolt - 返信
    I broke the socket, what can I do now? Can it be solded back?
    borjadp1punto0 - 返信
    Finally I had that socket solded back and the speaker is working again.
    I think this cable is long enough and it could be possible to do this repair without the risk of pulling this socket.
    borjadp1punto0 -
    How to solid back the connector? I broken mine too.....
    sonymd0204 -
    I'm REALLY upset about this step. I put the optical drive in the computer in about fifteen minutes and have spent nearly THREE HOURS trying to get this right speaker connected to the motherboard--and to NO AVAIL. BYPASS THIS STEP UNLESS YOU'VE GOT SOLDERING EXPERIENCE.
    LaMont Golden - 返信
    I was able to skip both steps 4 and 5 and still replace the optical drive. The subwoofer didn't come entirely free as described in step 9, obviously, so it was a little fiddly, but it worked.
    Nate Cook - 返信
    I was also able to skip both of these steps without any problem. Glad I did with all the horror stories I'm seeing here
    Thomas Overstreet -
    how do you fix if you took the socket down? i did trying to unplug it. now my speaker won't sound
    dukezsq - 返信
    this step should be deleted. do not PRY anything.
    I snapped mine off too and now I am in the middle of epoxying the f**cking thing directly to the motherboard
    Steven mah - 返信
    • カメラケーブルの接続を外す前に、基板に接着剤で留められた小さな透明のプラスチックのケーブルリテイナー(赤く囲まれた箇所)をスライドしてください。基板から外す際にカメラケーブルコネクタからリテイナーをスライドするため、他のコンポーネントにダメージを与えないようご注意ください。
    • カメラケーブルコネクタを光学ドライブ側に向けて引っ張り、基板から接続を外します。
    • このソケットはメタル製で簡単に曲がってしまいます。コネクタを基板上のソケットに取り付ける前に、装着位置が揃っているか確認してください。
    When you put the Mac back together after this entire procedure, it's virtually impossible to get the camera cable reconnected because there is a small piece of plastic glued to the board to keep it from coming unplugged. An Apple store tech explained the piece of plastic and said it won't break anything if I pry it off the board. I did and then the cable connected easily.
    karenz - 返信
    The retainer for the camera cable may be black as well as clear. It is much easier to remove and reinstall the retainer if the DVD drive cable is removed first.
    MikeG - 返信
    Nate Cook - 返信
    me too!... definitely a better decision to skip steps 4 and 5.
    Felipe Lyon -
    In step 5 I made a mistake and now i have no WIFI, Bluetooth and iSight. Please be careful.
    hannsim - 返信
    I couldn't reconnect this cable correctly, so my camera is not working anymore.
    It doesn't matter to me, I didn't used the camera that often...
    But the Ambient Light Sensor uses the camera to control keyboard lighting, so I wasn't able to see my keyboard in the dark anymore... :(
    If you have the same problem, after a couple of google hits I've found this app: https://www.macupdate.com/app/mac/22151/...
    Problem solved! YAY!
    PS: be careful because WIFI passes through this cable as well!!!!
    simbass - 返信
  3. Fixmasのスピリットを広めましょう
    クーポンコードFIXMAS12を使えば、50ドル以上のお買い上げで12ドル割引となります。
    Fixmasのスピリットを広めましょう
    • スパッジャーの平面側先端を使って、基板から光学ドライバーのコネクタをまっすぐ引き上げます。
    コメントを追加する
    • スパッジャーの平面側先端を使って、基板からハードドライブのコネクタをまっすぐ引き抜きます。
    コメントを追加する
    • サブウーファーを上部ケースに固定している2本のプラスネジを外します。右側が5 mm、左側は3.9 mmです。
    • 2本のネジのうち長いのは右側の方です。
    What's the exact length of those screws?
    Martin - 返信
    For step 8, I found I had to use a Phillips #0 screwdriver to remove the two screws. I'm not sure if mine were just over-tightened, but I couldn't get the two screws off with a cheapo Radioshack #00 screwdriver or a nice Wiha one for the life of me without coming close to stripping them. Tried the #0 and they popped right out. Hope this helps.
    Aaron B - 返信
    • サブウーファーはまだ右側のスピーカーに繋がっています。まだ完全に取り外さないでください。
    • サブウーファーを光学ドライブから持ち上げて、コンピューターの上側に置きます。
    コメントを追加する
    • カメラケーブルのブラケットと上部ケースを固定している8.4 mm プラスネジを2本外します。
    • 右側ネジはカメラケーブルに固定されたままです。
    • 上部ケースからカメラケーブルのブラケットを持ち上げます。
    There's another type of bridge, black, with an extra piece of metal to hold the cable. You don't have to remove this bridge to unmount the optical drive.
    Martin - 返信
    • 上部ケースに光学ドライブを固定している2.5 mmプラスネジを3本外します。
    • 光学ドライブを右側端から持ち上げて、デバイスから取り出します。
    コメントを追加する
    • 右側スピーカーのケーブルを覆っている黒色のテープの一片を剥がします。
    • このテープの下に直接パワーボタンリボンケーブルがあるため、作業には注意してください。
    コメントを追加する
    • スパッジャーの先端を使って、上部ケースに右側スピーカーを固定している接着剤を剥がします。
    I recommend you to use for this step an opening tool instead the spudger. The jimmy is a good option
    Toni - 返信
    • 上部ケースからサブウーファーと右側スピーカーのアセンブリを持ち上げます。
    コメントを追加する
まとめ
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
27 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
Midori Doiさんは世界中で修理する私たちを助けてくれています! 貢献してみませんか?
翻訳を始める ›
Walter Galan
572,473 ポイント
1,203のガイドは作成済み
Thanks ifixit for the super guide. I followed the steps and now my mac works properly again!
Toni - 返信
Thank you iFixit!
I too snapped the right speaker/subwoofer cable connector right off the mother board, but with patience and a little research, I learned how to solder the thing back on. How about a Warning!!!!! inserted at that step.? I only saw that there were comments AFTER I gingerly tried to pry the connector as instructed. It would help to show how the parts fit together as is done with the fan cable connector. Those instructions (the fan cable connector instructions), helped me better understand what I was prying apart and gave me an idea of how best to do it, and how the speaker/subwoofer cable connector connected to the board, as well as how to position the “pads.”
So, I learned from my mistake, which is a good thing. Nonetheless, I would have preferred to learn BEFORE I snapped off the cable connector, LOL!
Thanks Again for this incredible site.
Leslie L. Gordon - 返信
コメントを追加する
統計データを表示:
過去 24時間: 5
過去 7 日: 59
過去 30 日: 290
今までの合計 40,030
