メインコンテンツにスキップ
MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換
必要な工具と部品
  1. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換, 下部ケースのネジを外す: 手順 1、 1の画像 1
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I use a magnetic mat and place the screws in order on that :)
    Cary B - 返信
  2. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換, 下部ケースを持ち上げて外す: 手順 2、 1の画像 1
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - 返信
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換, バッテリー: 手順 3、 1の画像 1
    • 作業前の注意点として、放電を防ぐためロジックボードからバッテリーコネクターの接続を外してください。
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    gansodesoyaからの引用:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 返信
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 返信
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 返信
  4. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換, 光学ドライブ: 手順 4、 1の画像 1
    • スパッジャーの平面側先端を使って基板から右側スピーカー/サブウーファーケーブルコネクタをまっすぐ引き抜きます。ソケットを持ち上げないようにご注意ください。コネクタを光学ドライブ側に引っ張ります。
    • ワイヤの下から持ち上げます。
    Step 4 is correct as stated (pull up, not slide out). You'll definitely see this when you put it back in place, pushing down in socket not sliding in. Just be careful and use spudger (gently!) underneath wires as shown.
    jgcolt - 返信
    What is the best way to solder this back onto the board? I did it once 5 years ago, but that was my first and only time soldering. I know there is a soldering guide, and I have read it. Could someone tell me please the best way to reconnect the right speaker/subwoofer cable to the board, referencing the soldering guide?
    Leslie L. Gordon - 返信
  5. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 5、 1の画像 1
    • カメラケーブルの接続を外す前に、基板に接着剤で留められた小さな透明のプラスチックのケーブルリテイナー(赤く囲まれた箇所)をスライドしてください。基板から外す際にカメラケーブルコネクタからリテイナーをスライドするため、他のコンポーネントにダメージを与えないようご注意ください。
    • カメラケーブルコネクタを光学ドライブ側に向けて引っ張り、基板から接続を外します。
    • このソケットはメタル製で簡単に曲がってしまいます。コネクタを基板上のソケットに取り付ける前に、装着位置が揃っているか確認してください。
    When you put the Mac back together after this entire procedure, it's virtually impossible to get the camera cable reconnected because there is a small piece of plastic glued to the board to keep it from coming unplugged. An Apple store tech explained the piece of plastic and said it won't break anything if I pry it off the board. I did and then the cable connected easily.
    karenz - 返信
    The retainer for the camera cable may be black as well as clear. It is much easier to remove and reinstall the retainer if the DVD drive cable is removed first.
    MikeG - 返信
  6. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 6、 1の画像 1
    • スパッジャーの平面側先端を使って、基板から光学ドライバーのコネクタをまっすぐ引き上げます。
  7. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 7、 1の画像 1
    • スパッジャーの平面側先端を使って、基板からハードドライブのコネクタをまっすぐ引き抜きます。
  8. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 8、 1の画像 1
    • サブウーファーを上部ケースに固定している2本のプラスネジを外します。右側が5 mm、左側は3.9 mmです。
    • 2本のネジのうち長いのは右側の方です。
    For step 8, I found I had to use a Phillips #0 screwdriver to remove the two screws. I'm not sure if mine were just over-tightened, but I couldn't get the two screws off with a cheapo Radioshack #00 screwdriver or a nice Wiha one for the life of me without coming close to stripping them. Tried the #0 and they popped right out. Hope this helps.
    Aaron B - 返信
  9. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 9、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 9、 2の画像 2
    • サブウーファーはまだ右側のスピーカーに繋がっています。まだ完全に取り外さないでください。
    • サブウーファーを光学ドライブから持ち上げて、コンピューターの上側に置きます。
  10. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 10、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 10、 2の画像 2
    • カメラケーブルのブラケットと上部ケースを固定している8.4 mm プラスネジを2本外します。
    • 右側ネジはカメラケーブルに固定されたままです。
    • 上部ケースからカメラケーブルのブラケットを持ち上げます。
    There's another type of bridge, black, with an extra piece of metal to hold the cable. You don't have to remove this bridge to unmount the optical drive.
    Martin - 返信
  11. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 11、 2の画像 1 MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 11、 2の画像 2
    • 上部ケースに光学ドライブを固定している2.5 mmプラスネジを3本外します。
    • 光学ドライブを右側端から持ち上げて、デバイスから取り出します。
  12. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換, 光学ドライブ: 手順 12、 1の画像 1
    • 光学ドライブからまっすぐ引き抜いて光学ドライブケーブルを取り出します。
    • このコネクターはとりわけ深い位置に搭載されています。そのため、コネクタの中央部分からドライブを引き抜いてください。
    • 光学ドライブにCDや他の何かが詰まってしまった場合は、光学ドライブの修理ガイドを参照してください。
  13. MacBook Pro 13" Unibody Mid 2009 光学ドライブの交換: 手順 13、 1の画像 1
    • 小サイズのメタル製取り付け用ブラケットを固定された2本の黒色の#0プラスネジを外します。このブラケットを新しい光学ドライブもしくはハードドライブ筺体に移植してください。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
103 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,676 ポイント
1,203のガイドは作成済み
2 件のコメント
iFixit rocks! Got a stuck CD out of my wife's superdrive this way. Many thanks!!!
Steve Folberg - 返信
I just took mine apart and found a piece of tape in it. Smh. Works perfect now.
Dana Kimble - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 91
今までの合計 154,790
