はじめに
MacBook Pro 13" Unibody Late 2011 RAMのRAMをアップグレードします。
排気口(液晶ヒンジ部)付近より、底ケースを指で開けます。
底ケースを取り外します。
Bonjour, alors cela va dépendre du modèle de MacBook Pro Retina concerné. Par exemple, si vous avez un 13 pouces, allez consulter cette page MacBook Pro 13" Retina Display Repair et sélectionnez-y votre modèle. Les Retina 15 pouces se trouvent ici MacBook Pro 15" Retina Display Repair. Sinon cet outil https://fr.ifixit.com/info/ID-your-Mac (pour l’instant seulement disponible en anglais) vous aide à identifier quel modèle vous avez et vous redirige vers la page de votre appareil, où vous trouverez le tutoriel correspondant à votre Retina. Bonne réparation !
Merhaba, trackpad değişimi ve ayarlaması için tornavidaya ihtiyacım var, bu konuda yardımcı olabilir misiniz acaba? Ne tür bir tornavidaya ihtiyacım var ve nereden bulabilirim acaba?
スパッジャーの先端を使って、バッテリーコネクターをロジックボードのソケットから上向きに引き上げます。
yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
khull -
Sooo the track pad is under the battery...you kind of have to remove it to get to the track pad.
This step is not really required. Apple does not recommend it.
My Battery does not get recognized after i disconnected it, screw this site!
Did you properly ground yourself to the case before putting the spudger to the connector/logic board? Did you use a spudger or something else that is non conductive...or did you use a flat blade metal screw driver instead and compound your error by not grounding yourself before touching the logic board? All kinds of variables here but the bottom line is iFixit provided you a guide to fix your computer. Lots of others have followed this guide without trouble. Your battery issues are not their fault. They did say this guide was moderate difficulty...maybe it's just a little beyond your skill level. We should all know our limits!
Don't know what the deal is with the battery, but this IS a necessary step to keep from frying the logic Board if you accidentally touch something and short it out. I did this step every time during my troubleshooting and The battery was ALWAYS recognized by the system the next time I turned the MBP on. So be safe and don't fry your logic board in the process...
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
Installed/upgraded 4gb RAM to the system maximum 16gb and installed a 500 gb SSD today....DID NOT disconnect the battery cable....no issues at all when I powered back up. Then did a clean install of OSX Yosemite....next I used a time machine backup to put all my stuff back on the new HD. From start to finish it took about 4 hours. Macbook boots up right at 16 seconds now.
MacProUser - 返信
Easiest to use two spudgers, one on each short end, I found.
DON'T remove the Battery Cable, you risk the battery NOT being recognised when you start the Mac up again, or breaking it!! More to the point, APPLE DOES NOT RECOMMEND THIS, so don't do it! I Installed 2x 8GB ( 16Gb total) of Crucial Mac RAM at 1333Mhz for my Late 2011 MacBook Pro, and it works beautifully, fully recognised and working well. I followed these instructions, but as Apple didnt recommend disconnecting the battery, I skipped this step, and as well as taking less time, nothing was damaged or broken, and everything works perfectly!!! Just make sure that you DISCHARGE ALL STATIC ELECTRICITY FROM YOUR HANDS, by touching a metal surface in the Mac. Apple recommends the edge of the Optical Disk Drive ( Big silver thing ) before touching any parts. Also, Take care removing the RAM out of its packet, DO NOT touch the Gold connectors, and hold the RAM by the edges. Finally, be PATIENT, GENTLE and it should all go perfectly. I managed it first time, with no technical ability, so follow my advice. Good luck!
Switch off your Mac and continue without disconnecting the battery. Don't know how it will switch on by itself.
Mfernandez - 返信
This comment made me think that disconnecting the battery was no point at all, because really - how would the computer be able to switch on by it self. So... I had my mac flipped around and was fiddling with the last part of the guide when I all of a sudden hear the start up sound! Don't know how and why it did. I turned it around with it guts open and guts hanging out. Screen was on. I forced it to shut down by keeping the power button down. Turned it back and first thing removed the battery cord.
Luckily the computer started up just like normal. But hearing that sound was just too scary.
BTW I had been cautious to de static myself multiple times.
wassberg -
Definitely do this step. It's an easy disconnect anyway and also easy to reconnect later.
I removed the battery cable for the repair. When I plugged in the MagSafe adapter after the repair, the Mac turned on automatically without pressing the power button and I was a bit worried, but after a restart everything worked fine again. I did have to reset date and time in Preferences. The battery was recognized OK.
Okey, I skipped this battery disconnection part. Did not do anything like this before in my life, changing the cable was super easy!
The official Apple guide to replacing the RAM says nothing about disconnecting the battery but it does recommend touching metal inside to discharge static. https://support.apple.com/en-us/HT201165
I always do this when working on MacBooks (over ten years) and it never caused an issue. Don’t worry about this step as removal of the battery connector is simple. This particular connector is pretty much goof-proof as it won’t break. I’m fairly aggressive and just pop it off whenever I’m working on the Macbook Pro.
I have a late 2011 MacBook Pro 13in and did not disconnect the power from the battery. I upgraded from 4gb to 16gb and worked perfectly. Just make sure to power it down and be gentle. It was super easy and quick, and I feel a significant boost in performance. Cant wait to install my 1TB SSD Samsung 860 next!
Be patient on disconnecting this one. It worked for me step by step, little by little.
u can use 16GB DDR3 @ 1600mhz. intel says 16 @ 1333, and apple 8.
apple will solder even the folders to the background for to sell you the “open” or “move to the trash” command. if the battery is not removable, its not a casuality…. u can be sure
Would draining the battery (by using the machine until it runs out of power) do the trick for this? Seems it would be less risky than potentially damaging the connector/cable during disconnection for example.
moshimoshi - 返信
Cannot install any os on new ssd ? Mac is reading it.. please help
バッテリーケーブルをロジックボード上のソケットから外して、わずかに折り曲げておきます。そうすると、作業中にアクシデントで接続することがありません。
What are the changes of it broke when i bend it?, after i disconect it does not work anymore
The guide worked perfectly, as it has in the past (our family has three Mid-2012 Macbook Pros that have been separately upgraded with RAM and SSD).
The PH00 screwdriver fit perfectly.
One note on getting the screws to seat easily and thread perfectly...always turn them gently a couple turns to the left (CCW or Anti-Clockwise) until you hear a small click. That's where the threads will grab. Works with any screw, but when threads are fine, this will help ensure that the screw is at the correct angle and will grab and seat perfectly.
Great guides. Thanks!
Got RAM in but only one slot is working and now I can't remove! The RAM won't pop up like before and tabs don't seem to do anything. Please advise.
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
does the battery connection need to be removed? I only ask as other videos etc have not shown this step.
Très bonnes explications. Concernant le débranchement de la batterie, faute de “smudger”, on peut le faire tout doucement avec le bout des ongles (s’ils ne sont pas coupés trop à ras, LOL), et surtout ne pas tenter de le faire d’un coup: il faut y aller tiers de mm par tiers de mm. Le retrait des anciennes mémoires n’est pas facile non plus, car on a très peu de place pour manœuvrer, là encore il faut y aller petit à petit, avec les plus grandes précautions! La barrette située le plus profond doit être soulevée assez fortement dans sa partie libre pour pouvoir être extraite de son étroite cuvette et ce n’est pas simple. Le remontage est nettement plus simple que le démontage. Il faut surtout faire très attention à ne pas confondre les petites vis à épaulement avec celles qui n’en ont pas. Je conseille, avant de remettre le couvercle de fond du Mac, de faire un essai de redémarrage pendant une minute ou deux pour bien voir si tout est OK.
ソケットからRAMスティックを外します。
After replacing the RAM my macbook did not start anymore. Only if I take out one Ram it works. Does anyone knows why.
joelcroese - 返信
Hello Joelcroese, have you a issue about your problem, because i have actually this problem ? ... Thanks for your feed back.
Make sure both your RAM chips are running at the same speed - don't know about the Macbook but it will cause other machines to not recognize the RAM at all or only pick up one stick -
Is the channel configuration of your ram sticks correct? Mac needs 9-9-9-24 channel configuration. Something like Corsair Mac Memory or the kit that iFixit provides are in the correct channel configuration.
Thank you, Phillip! I have now (just recently) used FOUR of your guides—1) HARD-DRIVE replacement, 2) hard-drive CABLE replacement, 3) BATTERY replacement, and 4) RAM upgrade installation—to successfully refurbish my daughter’s late-2011, 13.3-inch MacBook Pro and, thereby, hopefully, add a few more years to its useful life. Thanks, again!
Sincerely,
Garrick de Demeter
i have 2x8GB kingston KVR16S11/8 in a early 2011 13” i7.
at native 1600mhz
latency 11 cl
works perfectly.
Apple must write a comic instead of intel specs (and intel too)
btw. intel integrated graphic card doesnt support metal, and everyone has mojave installed???
hohohoho apple guys you a really funny. lets smoke everybody!
and SD card is pcie 2,5GTs. apple confused the usb one and used a pci lane. what a confussion!!!!
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
206 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
30 件のコメント
I should have two 4GB memory or 8GB?
You can max out your RAM on any MacBook just about because of the quality of design. I added two sticks of 8 GB of RAM for a total of 16 GB. Apple say my MacBook Pro late 2011 can only support 8GB.
Hello,
I just changed RAM from 4GB to 16GB in a MacBook Pro 13" Unibody Late 2011. Followed all the steps here, nothing broke. I was very careful on the instruction "the edge of a spudger to pry the battery connector upwards from its socket on the logic board", and also to connect it again.
What happens is that my computer works fine except for the battery. On the upper side (next to clock) says that there are no batteries available. It only works with AC adapter connected.
Please, Help me!!!
Saw your post on my original comment. Easy to replace battery, their is a link via I-Fixit battery guide on MacBook Pro 2011. Apple got sued in EU court for not allowing third party batteries. I do not know if you still have MacBook Pro 2011, hope it helps. Sadly, Apple put “end of shelf life” with this machine and High Sierra will NOT upgrade due to Apples “2015” or later MacBook requirement. This is stupid and forced “end of shelf life” so you buy a new machine, even though you meet hardware requirements. I smell another lawsuit.
quite easily done without a spudger. gentle, firm pressure on the sides of the battery plug with fingers, pull up gently, bob's your uncle.
RAM upgrade was successful....continuing to use my mac book pro with upgraded RAM (8 GB)
Hi, So I my Macbook Pro is indeed 13 inch late 2011. On Apples specs page it says this computer has a base memory of 4 GB and a maximum memory of 8 GB. It also says I have two memory slots.
With these specs in mind, I am looking to purchase RAM to max it out at 8 GB. Do these specs mean I already have a 4 GB RAM drive in one of the two slots? If so should I only buy one 4 GB Ram and leave my old one in? Or would it be better to buy 2, 4 GB chips and take the older RAM chip out? Does that old RAM chip get fried? I'm trying to decide whether or not to purchase 1 or 2 (4 GB) RAM chips.
Thanks to whoever answers this!
-Milo
Hi Milo, in my experience, when this computer is configured for 4 GB of RAM from Apple, it will have 2 sticks of 2 GB each. To get 8 GB you'll need to replace those with two 4 GB sticks.
But before you buy anything, it's easy enough to check if you have a small Phillips screwdriver! Once you've removed the back panel you should be able to see what you've got. If both slots are occupied, you have 2 x 2GB. If there's an empty slot, then it's a single 4 GB stick.
I've read the comments and haven't seen anything regarding whether 16GB of RAM will work in MacBook Pro 13" Late 2011. Apple's support page for RAM upgrade on this model states that 8GB (2X4GB chips) is the max RAM expectable . Will the 16GB (2X8GB) RAM work?
Hi Sean,
Better late than never in answering your question. I have a late 2011 MacBook Pro 13" and currently have 16GB RAM in it and it works perfectly. I upgraded it (2x8GB) and it's really easy to do - exactly as the instructions above. When you buy your RAM make sure you spring for the mini tool kit (usually $5-$10) - it makes it so much easier.
Cheers
Kirsty
K Zi -
Hi folks!
Can someone explain why apple wrote max 8gb expandable ram (2x4gb) on its macbook pro 13" late 2011 manual I downloaded from Apple website?
I feel very worried at installing more than they suggested. There should be a reason for that....... :/
Thanks so much!
Hi Mauitux,
You have a manual/old info that probably hasn't been updated in the 5 years since your MBP was built so it doesn't reflect that a 2 x 8 GB upgrade is available now. They're more worried about writing the manual for the newest MBP's.
Jase
Hi guys, it is about time for me to change the RAM on my 13inch MacBook pro to 16 GB. any suggestions on cheap yet effective memory sticks. after i searched i found a brand name that is certified by Apple it is called "Crucial" but it is a bit expensive , any suggestions regarding other brands?
thanks all
does anyone have the knowledge to remove the memory card bracket? I got a ramcard module stuck and want to see if that is a possible way to get it unstuck by removing the bracket. I did try removing the four visible bracket screws, but it seemed still secure, wondering if i need to remove the keyboard to get at screws on the back.
thanks!
I have seen it where any computer and imind you have worked on windows laptops. Most of the time if you have 2 different speeds of ram they won't be recognized. However there are those rare situations where a faster speed ram will throttle be recognized at the slower speed of the other stick of ram. But, for best results buy 2 sticks of ram at the same speed and make sure that your computer will support that speed of ram.
Hi everybody!
I have a macbook pro 2011 13 inches with El Capitan and 4GB ram. I bought 2 Corsair 8GB rams (CMSA8GX3M1A1333C9). I installed them and I noticed my battery charge finish too fast (around 3 hours). Also, when I try to watch the information of a file or extract a USB flash, the computer freeze.
When I re-install the 4GB rams the battery and the problems disappear.
What could be happening?
Any suggestion or idea is helpful.
After replacing memory please try to reset smc and pram. It worked for me. It is always wise to do this after changing any hardware inside your mac. Also run memory test with built-in apple hardware test suite (hold D while booting) or/and memtest. Maybe you just got a bad ram. Happened to me twice!!
I did this and the walkthrough was dead simple. I didn’t run the hardware test suite Janez Ford mentioned since it didn’t seem to have an option to do so. However, I had no issues booting up.
I did notice with 16gb of ram that the battery seems to get used up a little faster. Could this also be due to using 1600 Mhz ram versus the factory 1333MHz ?
A co-worker of my wife’s has asked if I can upgrade the ram in their mac book pro. Looking at this guide its pretty easy and straight forward on the hardware side. Is there anything that needs to be done prior or after the instillation to ensure it boots up and runs like it should. I’ve worked on and built many of my own PCs but never done anything with a mac.
Hey everyone,
I have a 13-inch Macbook Pro (Late 2011) and was thinking of adding an 8GB RAM to one of the already existing 2GB cards, making 10GB total. Has anyone ever done this before? I was thinking maybe it will save some battery life and a bit of money (until I can afford to buy another 8GB card)?
Thanks in advance!
Late model 2011 MBP justremoved the 2 2GB ram chips and installed my 2 8GB chips purchased. After following all the steps to a T the MBP will not boot back on. It gives 3 beeps with a black screen and just keeps doing this. Remove newly purchased ram chips and replace old 4gb (2 2GB chip) and boom working again. Is this possibly because Apple states the max memory for these machines is to be 8GB using 2 4GB chips and this will not support the suggested 16GB max memory upgrade suggest and purchased here? Help, what am I missing? I was really looking forward to my old MBP getting a well deserved boost. Side not, also purchased the max memory kit here from iFixit for my 21.5” iMac, and that 32GB ram upgrade went perfectly! Thanks for all the great information and walk through guides here, just lost on this one and hoping I’m missing somethjng!
Super easy, thanks to you Philip!
Absolutely spot on instructions. Thanks!
Thank you for the instructions! It was super easy, although, I did not use enough force for one of the 4GB modules initially, so it wasn’t registering.
Am I better off running on one 8gig ram chip and not reinstalling the 2gig. Install both I don’t know. Mac book 13in late model 2011
Chris wood - 返信
Do you have to do an increment of 4 GB? Say like if I swap the 2GB with 4GB for a total of 6GB - will that be ok operationally?
hola quisiera saber con certeza si se puede aumentar la memoria RAM a 16 GB en un Macbookpro 2011 late y si es recomendable o puede dañar el equipo.
En caso de ser posible recomiendan alguna marca en especial ??
Can I install SODIMM DDR3 8GB 1333 MHZ KINGSTON (KVR1333D3S9/8G) for my Macbook Pro Late 2011 core i5 2.4GHz? I read that I can install 2 items of 8gb, but there are two different types: 1.5V and 1.35V which one to choose? And the same question with the same memory, but 1600GHz (also 1.5V and 1.35V), I haven’t find any information here: https://support.apple.com/kb/sp645?local...
Does void the warranty?
jfondeur - 返信
No, it does not void the warranty. More specifically: http://eshop.macsales.com/Search/display...
oakdragon12 - 返信
How much weight can I save by removing the optical drive?
gunes314 - 返信
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Also wondering how much weight I'd save by just removing. My drive is broken for ages, but I have not needed it in ages. The HD was already replaced by a cheap SSD (second best thing after upgrading to 8GB), so I'd appreciate losing some weight. I mean, the computer. Although I could lose some too... erm... well, anyway, I guess the lack of the DVD would not interfere with anything, right? Opinions?
Carlos Duarte do Nascimento - 返信
Apple has meticulously balanced the MacBook's weight from left to right, and removing the optical drive may off-balance the Mac.
Seji the veggie -
What so you think that a removing the optical drive which weighs less than a AA battery will unbalance a MBP making it unusable? LOL!
Unless you use the MBP on a high wire (an even then I have my doubts) you'd never notice the weight difference.
pmhparis -
The issue is not one of weight but an issue with the systems cooling and an opening which objects could enter. For a few grams of weight I don’t think its worth it! A better solution would be to swap out the heaver HD for a much lighter SSD, and getting all of the performance benefits of the faster drive as well!
While you might not think it the optical drive also acts as a stiffener so there is less twist in the case. This is because of the size of the hole for the DVD/CD’s so taking it out weakens the case design.
Dan -
I'm thinking you'd probably be OK losing the DVD drive without a problem. Just make sure the optical drive cable is secured or you might hear it rattling in there from time-to-time.
John Adam Wickliffe - 返信
Hey guys,
this website is amazing. I read it to guide me on fixing my mac book pro, but on the video, the girl gives a wrong information.. She says that is not possible replace just the keyboard... But I managed to replace only my keyboard. It is boring because I have to remove approximately 70 screws but it is possible. Thanks a lot! You guys helped me save about US$300 thats because in Brazil some technicians would charge me with that amount!
I posted some pictures on your facebook page..
renatumb - 返信
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - 返信
Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
kschmesk - 返信
Totally agree!! I used the #00 screwhead for 7 out of the 10, but for the remaining tricky ones I used the #0 screwhead and it helped me out. I was so worried I would strip the tiny screw, but this comment saved me!
Juliana Mak -
I tried the PH #00 for the 10 screws that hold the bottom case and it's too big, instead PH #000 works perfectly. Are you sure this screws are #00?
Alex - 返信
The likely problem with your wifi is not the card but the antenna leads that go into the plastic clutch
. Ifixit don't have a guide to change this as it it includes the isight camera so the screen has to be disassembled which is fairly hard
I got round it by using the camera cable from the old set and cutting off the new one
brian whittle - 返信
Hello MacWorld,
Just want to say that this site is a great resource for repairing or upgrading your Mac. I had a bad SATA cable in my MacBook Pro and after ordering a new one from the "IFIXIT" site I received the cable within two days, replaced it and was up and running again in no time. Thanks IFIXIT for you help!
wer 10/5/15
tayseer999 - 返信
I have found that my MacBook Pro 13 Late 2011 has five shouldered screws and not four. I am not sure exactly where it goes but I have put it in the top left corner of the picture as it is the odd one out.
ForumHermit - 返信
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - 返信
iFixit sells a kit: MacBook Pro Unibody Lower Case Screw Set
Darrell Johnson -
on my device the #00 screwdriver was a bit too small. a #0 was the perfect one
Maximilian Klotz - 返信
I found with mine that the shouldered and un-shouldered screws were reversed (the three un-shouldered screws going where the orange colour indicates). Also, I found that the front four screws went in at an angle.
gilded yak - 返信
Are you sure the short screws are different? The set sold here just says “Seven 3 mm Phillips #00 screws.”
Jack - 返信
I have the same question. What is the difference between shouldered and not? So hard to see any difference…
Michael Wilkens -
I’ll second that. I could never find them being different.
otetz -
Same here… I could not notice hte difference. Anyone at iFix would like to comment?
LDS -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - 返信
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
I used 3 eggcups to hold the screws ;>) They are very fiddly and easy to drop on floor so keep the MacBook away from the edge of the surface you are using to avoid accidentally dropping a screw off the edge of a table, etc.
Stephen Smith - 返信
A screw does not come out, how can I get it out? Many thanks in advance for your help
Wilder Torres - 返信
Since you’ll be removing many screws it’s best to plan ahead. I found it especially helpful to have a small plastic tray with about a dozen separate compartments to hold screws. As I removed screws I kept them in one compartment for each item removed. For example: The lower case removal involves the removal of ten screws. I kept them all in the first tray compartment and set the lid aside. Also, I put a post-it note identifying this compartment as “Lower case” and noted that the top right-most screws were the long ones. I continued with this methodology as a removed the next item, and the next, etc. Disassembly notes included for each compartment. This helped SIGNIFICANTLY as I was able to reassemble the Macbook easily by simply going from one compartment to the next (in reverse order). This guide is rated “Difficult” which it really isn’t when you plan ahead in this way. It saves time in the long run.
airshack - 返信
when putting the macbook pro back together, the middle screw on the right side (if the computer is upside down and you have the hinge furthest away from you) requires a bracket that was not included with my new upper case. i had to remove it from my old case and transfer it over - if you don’t do this, that screw will have nothing to attach to.
this was one of the many additional parts i needed to transfer from my old case to the new one that aren’t mentioned in this guide…i’m adding comments on each step to try to help others…i wish i had thought to take pictures.
Matt - 返信
It seems to me the yellow and orange screws are the same
Luca Giancarli - 返信
If you look closely, the four front screws (with the yellow circles) have a short unthreaded section under the head. The orange keyed screws are threaded all the way up.
Raymond Ives -
The screws used on all Retina models, as well as about everything Apple has made since the iPhone 4, uses “PENTALOBULAR” not Phillips screws. These look like a TORX driver, but it has 5 concave sides. I believe the size you want is a P4 or T4. (1.2mm).
Don Cely - 返信
Two screw types:
______________________________
Shouldered Unshouldered
xxxxxxx……….xxxxxxx
..xxxxx……..….…….x…….
…..x……..…...……….x…….
…..x…………....……..x…….
El Crashitan - 返信
If you are following this guide to upgrade to a better drive and want to keep your system and data intact I highly recommend first following the guide to Clone an Existing Drive using the recommended free SuperDuper!. That process was a breeze and gives you confidence that the new drive will come up looking exactly the way it did when you started.
Patrick Langvardt - 返信
My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
jeremyyoung - 返信
I did this last weekend, and definitely, a Phillips #000 screwdriver is required (not a Phillips #00!)
Javier Campos Delgado - 返信
WIll this card be good with MacBookPro 17 inch 2011
Zafar Ali - 返信
I just followed this guide and it really helped me install a replacement cable and a new Samsung 860 EVO 500gb SSD in my aging MacBook Pro 13 A1278 MID 2012. It’s performing like a new machine now! The guide worked fine, but I’m curious why this HD cable costs €45 on Ifixit’s webshop, and only €13 on Amazon.de (I live in Europe)? The Amazon purchase also included two screwdrivers and a spudger.
Jeff Baker - 返信
I found out that one way to reduce the chance to loose screws is to leave them in their holes of the lower case right after unscrewing them. In fact, you can put the lower case back in place with all but one screws in place. The only one that I ever needed to put apart was the long one at the top right in the picture (the one that goes close to the display data cable underneath the lower case). Hope this help others! and you stop wondering about shouldered versus not shouldered short (3.5mm) ones :-)
LDS - 返信
For a MBP 2011, I’m not able to unscrew one of the 14.4 mm in the lower back. Can I know how can I get that done?. Thank you..
Rajesh Rajasekharan - 返信
very nice '''artical keep it up'''
fxxxman - 返信
