メインコンテンツにスキップ
MacBook Pro 13" Unibody Late 2011 Feet Replacement
必要な工具と部品
  1. MacBook Pro 13" Unibody Late 2011 Feet Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 2、 2の画像 1 MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 2、 2の画像 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
  3. MacBook Pro 13" Unibody Late 2011 Feet Replacement, Feet: 手順 3、 3の画像 1 MacBook Pro 13" Unibody Late 2011 Feet Replacement, Feet: 手順 3、 3の画像 2 MacBook Pro 13" Unibody Late 2011 Feet Replacement, Feet: 手順 3、 3の画像 3
    • Remove any broken or damaged feet.
    • Remove any pieces from the old foot that may have broken off in the foot hole.
    • Use tweezers to peel up and remove the old adhesive tape from the foot pad.
  4. MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 4、 1の画像 1
    • Scrub the foot pad with adhesive remover to remove any remaining adhesive.
  5. MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 5、 1の画像 1
    • Wipe the foot pad with an alcohol prep pad to remove any residue left by the cleaner.
  6. MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 6、 1の画像 1
    • Peel a replacement foot from the plastic backing.
  7. MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 7、 3の画像 1 MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 7、 3の画像 2 MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 7、 3の画像 3
    • Align the new foot inside the foot pad.
    • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the lower case. Use tweezers to slide the alignment nub so it lines up with the hole.
  8. MacBook Pro 13" Unibody Late 2011 Feet Replacement: 手順 8、 1の画像 1
    • Press the new foot down firmly with your finger and maintain pressure for 30 seconds to set the pressure sensitive adhesive. Support the other side of the cover while you press the foot down.
    • Repeat the last six steps for any broken or damaged feet.
終わりに
29 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,299 ポイント
416のガイドは作成済み
コメント 1 件
Fine tutorial !
I have an ecological proposal: no need of adhesive remover, an alcohol prep on a dish towel is enough to remove any remaining adhesive or residue. Less wastes !
Clément Llobet - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 31
今までの合計 5,675
