メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
動作を著しく早くするにはRAMをアップグレードしましょう。
  1. 次のネジを10本外します。
    • 次のネジを10本外します。
    • 14.4 mm #00プラスネジー3本
    • 3.5 mm #00プラスネジー3本
    • 3.5 mm #00 肩付きプラスネジー4本
    • 小さなネジを交換する際は、ケースのわずかに湾曲した部分に対し、垂直にネジを揃えてください。
    How much weight can I save by removing the optical drive?
    gunes314 - 返信
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - 返信
    Great tutorial. I found that using a Phillips #0 in lieu of the #00 worked much better.
    kschmesk - 返信
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - 返信
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - 返信
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - 返信
    A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
    Iain Boyd - 返信
  2. 排気口(液晶ヒンジ部)付近より、底ケースを指で開けます。 底ケースを取り外します。
    • 排気口(液晶ヒンジ部)付近より、底ケースを指で開けます。
    • 底ケースを取り外します。
  3. スパッジャーの先端を使って、バッテリーコネクターをロジックボードのソケットから上向きに引き上げます。 ソケットからバッテリーコネクターを外す際に、両側の短いサイドから上向きに引き上げると作業がしやすいです。コネクターの角に気をつけてください。簡単に壊れてしまいます。
    • スパッジャーの先端を使って、バッテリーコネクターをロジックボードのソケットから上向きに引き上げます。
    • ソケットからバッテリーコネクターを外す際に、両側の短いサイドから上向きに引き上げると作業がしやすいです。コネクターの角に気をつけてください。簡単に壊れてしまいます。
    Is this step of removing the battery connector required?
    manodh - 返信
    yes - as with disassembly of any electronic component you have to remove any power source. You don't want to accidentally turn the Mac on
    khull -
    Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
    aekinaka - 返信
    Be patient on disconnecting this one. It worked for me step by step, little by little.
    Phil Wagner - 返信
  4. バッテリーケーブルをロジックボード上のソケットから外して、わずかに折り曲げておきます。そうすると、作業中にアクシデントで接続することがありません。
    • バッテリーケーブルをロジックボード上のソケットから外して、わずかに折り曲げておきます。そうすると、作業中にアクシデントで接続することがありません。
    I put some tape between the connector and socket while working on the drive.
    Stephen Smith - 返信
    That's a good tip
    Anrothan -
    One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
    lelandjordon - 返信
    Wouldn't it make life easier to fully remove the battery for this whole process? I mean, compared to the next steps it's a piece of cake and create a bit more space
    Andrea Pastore - 返信
    On my MacBook Pro, the connector seems to be an integral part of the battery.
    Jerry South - 返信
  5. RAMチップの中央から2つのRAM固定アームを引っ張ります。 RAMチップはソケットからわずかに”飛び出す”はずです。
    • RAMチップの中央から2つのRAM固定アームを引っ張ります。
    • RAMチップはソケットからわずかに”飛び出す”はずです。
    Hi, I bent over the plastic levers of memory fixation and I broken them. you know where I can buy the piece?
    Marco - 返信
  6. ソケットからRAMスティックを外します。
    • ソケットからRAMスティックを外します。
    • 2番目のチップに対しても同じ手順を繰り返して取り出します。
    After replacing the RAM my macbook did not start anymore. Only if I take out one Ram it works. Does anyone knows why.
    joelcroese - 返信
    Hello Joelcroese, have you a issue about your problem, because i have actually this problem ? ... Thanks for your feed back.
    Remy Duprat -
    Make sure both your RAM chips are running at the same speed - don't know about the Macbook but it will cause other machines to not recognize the RAM at all or only pick up one stick -
    melindaruth -
    I am afraid of this too!
    ingwis - 返信
    Is the channel configuration of your ram sticks correct? Mac needs 9-9-9-24 channel configuration. Something like Corsair Mac Memory or the kit that iFixit provides are in the correct channel configuration.
    Seji the veggie - 返信
    Just to point out:
    1. Do not press again the locker.
    2. Changed the bottom RAM first.
    3. Put nicely, gently to the slot. Cue for you. You must see the label of the manufacture.
    4. Close everything.
    5. Switch the Mac and check "Finder>About my Mac" show the correct RAM.
    Jay Nandu - 返信
    Thank you, Phillip! I have now (just recently) used FOUR of your guides—1) HARD-DRIVE replacement, 2) hard-drive CABLE replacement, 3) BATTERY replacement, and 4) RAM upgrade installation—to successfully refurbish my daughter’s late-2011, 13.3-inch MacBook Pro and, thereby, hopefully, add a few more years to its useful life. Thanks, again!
    Sincerely,
    Garrick de Demeter
    gdedemet - 返信
    What type of Ram does the 2011 macbook pro run ?
    Louis06 - 返信
    i have 2x8GB kingston KVR16S11/8 in a early 2011 13” i7.
    at native 1600mhz
    latency 11 cl
    works perfectly.
    Apple must write a comic instead of intel specs (and intel too)
    btw. intel integrated graphic card doesnt support metal, and everyone has mojave installed???
    hohohoho apple guys you a really funny. lets smoke everybody!
    Oscar Sanchez - 返信
    and SD card is pcie 2,5GTs. apple confused the usb one and used a pci lane. what a confussion!!!!
    Oscar Sanchez - 返信
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
324 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
Andrew Bookholt
552,803 ポイント
618のガイドは作成済み
21 件のコメント
What kind of ram should I buy? DDR2 or DDR3?
Jason Moon - 返信
It takes only DDR-3 RAM.
oakdragon12 -
Is a 8gb early 2011 macbook pro maxed out, or can I upgrade to 16?
I'm asking because I read in http://www.crucial.com/store/mpartspecs.... that it can actually take 16gb. Thanks!
C Eyzag - 返信
Yup! I upgraded to a 16 GB DDR3 Corsair mac memory kit from Newegg and it works like a charm. I got this kit: https://www.newegg.com/Product/Product.a...
screenshots below:
http://i.imgur.com/IqEbFES.jpg
http://i.imgur.com/a2azyuV.jpg
Drew Dittmann -
Is there any difference or problem with the clock speed 1333 mhz or 1600 mhz?
Nasim - 返信
Question - my MBP currently has 4GB RAM. Is there a 2nd RAM slot that will allow me to increase my RAM by adding 4GB or 8GB. Or do I need to replace the current 4GB with a new 8GB module?
Steve K - 返信
Your MBP will have two chip slots that are stacked on top of each other. When you remove the top chip, you'll see the second chip sitting below it. It is best practice to replace both chips with the same amount of memory. So your current computer should have 2 - 2gb chips, so if you want 8gb total, you would install 2 - 4gb chips. Or for 16gb total, 2 - 8 gb chips.
Drew Davis -
I want to upgrade the RAM in my MBP. It now has 4GB. Are there 2 RAM slots that will allow me to add a 2nd 4GB RAM module - or - do I need to replace the 4GB with a 8GB?
Steve K - 返信
I have a late-2011 MBP. It now has 4GB RAM. Is there a 2nd slot for me to add RAM - or - do I need to replace the current 4GB with a 8GB module?
Steve K - 返信
Thanks for the straightforward and excellent guide!
Melissa Smith - 返信
I followed instructions & pushed power button. My screen is dark & computer is beeping at me. Suggestions on what I did wrong?
mjsinkc - 返信
if its a black screen and 3 beeps it sounds like your RAM did not get seated all the way. I would take them out and reinstall them.
Matthew -
Can i installed 1600mhz Ram in my macbook pro 13’ early 2011 model. Can u suggest any specific model in Amazon so that i can order the same.
rawat.ravi - 返信
Do you know if you can you upgrade a mid-2010 17" MacBook Pro (2.53 GHz Intel Core i5) from 8 GB of RAM to 16 GB?
Dave - 返信
Para sacar el segundo modulo de memoria es necesario sacar toda la board.
Jose Orlando Mora - 返信
Between the hard drive and memory upgrade, my early 2011 Macbook Pro runs like it did when brand new (maybe even faster).
Nathan - 返信
the official support page states a maximum of 8 GB of RAM for this notebook, this page instead sets the maximum to 16, who is right? :-D
thebandicootcove - 返信
Officially, the memory speed of a early 2011 MBP is 1333MHz (cas latency 9) because the that’s the CPU:s highest supported memory speed. Memory voltage is 1.5V.
And, officially, the max memory is 8GB (2x4GB).
So, if you would follow that, the best you could do would be 2x4GB 1333MHz.
It will however work perfectly fine with 16GB (2x8GB).
It is also possible to run 1600MHz (a.k.a. PC3-12800) memory, even though that’s not officially supported.
The thing is, most 1600MHz modules run at CL11, which will mostly negate any gains from the higher frequency. So, what do you do?
You go for 2x8GB 1600MHz CL9. Nowadays, these can be found, even the DDR3L type, at decent prices.
Suggestions? Kingston HX316LS9IBK2/16 or G.Skill F3-1600C9D-16GRSL, which is just that: 2x8GB 1600MHz CL9 DDR3L. Works perfect in a early 2011 MBP.
This will have a performance gain: My benchmarks showed a +25% increase in memory bandwidth with 2x8GB 1600MHz CL9 over the stock 2x2GB 1333MHz CL9. Kinda cool :)
Rick Lind - 返信
Anleitung perfekt!
Hat alles genauso geklappt.
1A mit *
Z-City - 返信
@Nasim. mbp 8.1 early runs at 1600mhz. ;)
Oscar Sanchez - 返信
ottima guida
aggiornamento a 16gb riuscito
grazie
davide artisan - 返信
コメントを追加
統計データを表示:
過去 24時間: 20
過去 7 日: 165
過去 30 日: 741
今までの合計 298,469
