はじめに
Use this guide to replace a broken microphone.
必要な工具と部品
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the tip of a spudger to pull the right speaker/subwoofer cable out from under the retaining finger molded into the upper case.
Pull the right speaker/subwoofer cable upward to lift the connector out of its socket on the logic board.
De-route the microphone cable from the channel molded into the left speaker housing.
14 の人々がこのガイドを完成させました。
コメント 1 件
Wonderful and very easy guide to follow these steps. Keep it up with more and more solutions!
