はじめに
Use this guide to replace a broken AirPort/Bluetooth cable.
必要な工具と部品
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth connector up from its socket on the logic board.
24 の人々がこのガイドを完成させました。
3 件のコメント
My Wifi failed, "no hardware found", but the Bluetooth still worked. I replaced the board, but still no dice. Turns out it was the cable!
This specific cable or the one that goes up to the screen?
Yes, this cable.
