はじめに
ノイズが発生したり消耗したファンを交換するにはこのガイドをご利用ください。
ビデオの概要
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。(再組み立ての前に、内部のほこりを落として、ワイプできれいに拭くことをお勧めします。)
123 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
19 件のコメント
Hi I did this and now my Mac won't turn on. When connecting the power supply the green light is on but absolutely nothing firing up. No fan no screen nada! HELP!
I'm having the same problem!! Anyone know how to fix this?? I put the old fan back in and it still wont turn on
Reopen the MacBook Pro and disconnect the battery cable, after 30 secs reconnect it.
This solution worked for me.
I have the same problem too. Reconnecting the battery cable doesn't worked... Any other idea?
Anyone found a solution here?
If not my guess would be the replaced fan is causing a short circuit. Try to remove it and mount the original one back. If at this point the MacBook will boot, the guess was correct.
