メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Pro 13" Touch Bar 2018 Right fan Replacement
必要な工具と部品
    1. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disable Auto Boot: 手順 1、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disable Auto Boot: 手順 1、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disable Auto Boot: 手順 1、 3の画像 3
      • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
      • Power on your Mac and launch Terminal.
      • Copy and paste the following command (or type it exactly) into Terminal:
      • 'sudo nvram AutoBoot=%00
      • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
      • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
      • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command (typed into Terminal, as shown above):
      • sudo nvram AutoBoot=%03
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Remove the pentalobe screws: 手順 2、 1の画像 1
      • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
      • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
      • Two 6.2 mm screws
      • Four 3.4 mm screws
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Open a gap using a suction cup: 手順 3、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Open a gap using a suction cup: 手順 3、 2の画像 2
      • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
      • Lift the suction handle to create a slight gap between the lower case and the chassis.
      FixBotに聞いてみる
      コメントを追加
    4. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Separate the clips: 手順 4、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Separate the clips: 手順 4、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Separate the clips: 手順 4、 3の画像 3
      • Insert one corner of an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the nearest corner and halfway up the side of the case.
      • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
      FixBotに聞いてみる
      コメントを追加
    5. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 5、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 5、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 5、 3の画像 3
      • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
      FixBotに聞いてみる
      コメントを追加
    6. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 6、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 6、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 6、 3の画像 3
      • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
      • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
      • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
      FixBotに聞いてみる
      コメントを追加
    7. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 7、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 7、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 7、 3の画像 3
      • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
      • Pull first at one corner, then the other.
      • Pull to the side—not up.
      • This can require a lot of force.
      FixBotに聞いてみる
      コメントを追加
    8. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Remove the lower case: 手順 8、 1の画像 1
      • Remove the lower case.
      FixBotに聞いてみる
      コメントを追加
    9. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Uncover the battery connector: 手順 9、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Uncover the battery connector: 手順 9、 2の画像 2
      • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
      • Remove the tape.
      FixBotに聞いてみる
      コメントを追加
    10. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 10、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 10、 2の画像 2
      • Gently peel back the small piece of tape covering the battery board data cable connector.
      • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
      FixBotに聞いてみる
      コメントを追加
    11. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 11、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 11、 2の画像 2
      • Disconnect the battery board data cable by sliding it out from its socket.
      • Slide parallel to the logic board, in the direction of the cable.
      FixBotに聞いてみる
      コメントを追加
    12. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 12、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 12、 2の画像 2
      • Fold the battery board data cable to the side and out of the way.
      FixBotに聞いてみる
      コメントを追加
    13. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 13、 1の画像 1
      • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
      FixBotに聞いてみる
      コメントを追加
    14. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnect the battery: 手順 14、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnect the battery: 手順 14、 2の画像 2
      • Use a spudger to gently lift the battery power connector, disconnecting the battery.
      • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
      FixBotに聞いてみる
      コメントを追加
    15. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Remove the trackpad connector screws: 手順 15、 1の画像 1
      • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
      FixBotに聞いてみる
      コメントを追加
    16. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 16、 1の画像 1
      この手順で使用する道具:
      • Remove the trackpad cable connector bracket with a pair of tweezers.
      FixBotに聞いてみる
      コメントを追加
    17. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 17、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 17、 2の画像 2
      • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
      FixBotに聞いてみる
      コメントを追加
    18. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnect keyboard connector: 手順 18、 1の画像 1
      • Use a T3 Torx driver to remove the two screws.
      • Two T3 Torx Screws.
      FixBotに聞いてみる
      コメントを追加
    19. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug Left speaker cables: 手順 19、 1の画像 1
      • Carefully peel back the black tape to reveal the ZIF connector.
      • Unlatch the ZIF connector by flicking the arm on the connector upwards and carefully remove the cable from the connector by sliding it out.
      • Repeat this process with the newly revealed connector.
      • The two screws that are outlined in yellow are not relevant to this step and are marked on the board itself. For this step, yellow corresponds to the yellow rectangle in the image.
      FixBotに聞いてみる
      コメントを追加
    20. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug left Thunderbolt ports: 手順 20、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug left Thunderbolt ports: 手順 20、 2の画像 2
      • Once the screw have been removed carefully remove the metal shield.
      • Under the metal shield there is a connector, carefully unplug it.
      FixBotに聞いてみる
      コメントを追加
    21. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug Touch ID and Auxiliary port: 手順 21、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug Touch ID and Auxiliary port: 手順 21、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug Touch ID and Auxiliary port: 手順 21、 3の画像 3
      • Use a T4 Torx driver to remove the two screws.
      • Two T4 Torx screws.
      • Carefully remove the metal shield.
      • Under the metal shield you will find two connectors, carefully unclip them.
      • The second cable you will disconnect will be lightly adhered so carefully slide a plastic spudger under it and finally unplug it.
      • The adhered cable is very thin and delicate so don't rush it and take your time.
      FixBotに聞いてみる
      コメントを追加
    22. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnecting the display connector: 手順 22、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnecting the display connector: 手順 22、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnecting the display connector: 手順 22、 3の画像 3
      • Use a T3 Torx driver to remove the four screws.
      • 4 T3 Torx screws.
      • Once the screws are removed carefully remove the metal shields.
      • Carefully unclip the connector.
      FixBotに聞いてみる
      コメントを追加
    23. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Disconnect wifi and Bluetooth antennas: 手順 23、 1の画像 1
      • Disconnect the cables carefully with a plastic pry tool.
      • Be gentle, if too much force is applied it can take the board connector up with it.
      FixBotに聞いてみる
      コメントを追加
    24. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Touch Bar cable 1: 手順 24、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Touch Bar cable 1: 手順 24、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Touch Bar cable 1: 手順 24、 3の画像 3
      • Remove the metal shield carefully.
      • Carefully unplug the connector.
      FixBotに聞いてみる
      コメントを追加
    25. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Right speaker cable: 手順 25、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    26. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, ZIF connector: 手順 26、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    27. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug Right Thunderbolt ports: 手順 27、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Unplug Right Thunderbolt ports: 手順 27、 2の画像 2
      FixBotに聞いてみる
      コメントを追加
    28. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Touch bar bracket / Flex: 手順 28、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Touch bar bracket / Flex: 手順 28、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Touch bar bracket / Flex: 手順 28、 3の画像 3
      • Use a T4 Torx driver to remove the screw.
      • T4 Torx screw.
      FixBotに聞いてみる
      コメントを追加
    29. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Audio socket / Touch ID bracket: 手順 29、 2の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Audio socket / Touch ID bracket: 手順 29、 2の画像 2
      • Use a T3 Torx driver to remove the two 1.4mm screws securing the bracket.
      • Remove the bracket.
      FixBotに聞いてみる
      コメントを追加
    30. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 30、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 30、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 30、 3の画像 3
      • gently disconnect the audio socket flex cable with a spudger.
      • gently disconnect the Touch ID flex cable with a spudger.
      FixBotに聞いてみる
      コメントを追加
    31. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Display cable: 手順 31、 3の画像 1 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Display cable: 手順 31、 3の画像 2 MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Display cable: 手順 31、 3の画像 3
      • Use a T3 Torx driver to remove the two 2.4mm screws securing the display cable bracket.
      • Use a T3 Torx driver to remove the two 1.2mm screws securing the display cable bracket.
      • gently disconnect the flex cable with a spudger.
      FixBotに聞いてみる
      コメントを追加
    32. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 32、 1の画像 1
      • Use a T5 Torx driver to remove the six 2.2mm screws securing the logic board.
      • Use a T3 Torx driver to remove the three 1.9mm screws securing the logic board.
      • Use a T5 Torx driver to remove the two 2.3mm (3.7mm head) screws securing the heatsink.
      FixBotに聞いてみる
      コメントを追加
    33. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 33、 1の画像 1
      • Carefully lift up the logic board, make sure none of the connectors are connected, also make sure they aren't caught on the logic board.
      FixBotに聞いてみる
      コメントを追加
    34. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 34、 1の画像 1
      • Congratulations you have now removed your MacBook's LogicBoard
      FixBotに聞いてみる
      コメントを追加
    1. MacBook Pro 13" Touch Bar 2018 Right fan Replacement, Right fan: 手順 35、 1の画像 1
      • Use a T3 Torx driver to remove the four 2.1mm screws securing the left fan board.
      FixBotに聞いてみる
      コメントを追加
    2. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 36、 1の画像 1
      FixBotに聞いてみる
      コメントを追加
    3. MacBook Pro 13" Touch Bar 2018 Right fan Replacement: 手順 37、 1の画像 1
      • Remove the left fan.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
David Fear
メンバー登録日: 09/08/11
5,600 ポイント
16のガイドは作成済み
チーム
Pickle IT - Gadget Repair Pickle IT - Gadget Repair人のメンバー
Business
2 メンバー
148のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 50
過去 30 日: 146
今までの合計 3,839
