メインコンテンツにスキップ
MacBook Pro 13" Retina Display Late 2013 SSD Replacement
必要な工具と部品
  1. MacBook Pro 13" Retina Display Late 2013 SSD Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 3、 2の画像 1 MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 3、 2の画像 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2013 SSD Replacement, Battery Connector: 手順 4、 1の画像 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 5、 2の画像 1 MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 5、 2の画像 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 6、 1の画像 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Late 2013 SSD Replacement, SSD: 手順 7、 1の画像 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  8. MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 8、 3の画像 1 MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 8、 3の画像 2 MacBook Pro 13" Retina Display Late 2013 SSD Replacement: 手順 8、 3の画像 3
    • Lift the free end of the SSD up slightly and pull the SSD straight out of its socket on the logic board.
    • Only lift the end of the SSD enough to allow you to pull it out—about 1/4".
終わりに
151 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,659 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,757のガイドは作成済み
24 件のコメント
So… can I just buy the new PCIe SSDs and use it in the 2013 rMBP? I'm very confused about these PCIe SSDs.
Timothy Brown - 返信
My retina 15" got the logic board damage and fix it is just stupid. Now in the mean time the new ones come up next quarter, I'm using my macbook pro 2011. Now, because the 2011 is no Retina, SSD and all the other good stuff in it (crying in silence) I did some research to make the 2011 better and I found out I can upgrade to 16 ram and a SSD. Now I check and is not that expensive at least for a SSD 128. BUT this morning it hit me, and I want to ask and make research about this idea. Guys I was wondering, can I take the SSD from my Retina that is actually SSD 256 and put it in my 2011? And save in the SSD? I mean, if possible of curse, if not I would go to buy it how I plan in the first place. Anyway guys any suggestions, ideas or advice are all welcome. I want to know whats best to improve the 2011 meanwhile the new ones get the upgrade. Thanks in advance! :)
tane883 - 返信
Can I use an Intel SSD 540s SSD M.2? Intel says it doesn't support NVMe. Does it need to or would that just add extra performance?
3PL - 返信
You can put an NVMe drive (with an adapter) in a late 2013 MBP, but you must have updated the OS to the latest version because the original, native OS does not support NVMe. Use Clonezilla to make a bare metal backup and use Clonezilla to restore it once NVMe is installed. Clonezilla wont work going down in size ie from a 1TB to 500GB drive.
Eric Andersen -
Can you also please put a link how to reinstall mac os after installing a new hardrive? thanks
Joseph Grigoletti - 返信
コメントを追加
統計データ:
過去 24時間: 64
過去 7 日: 422
過去 30 日: 1,676
今までの合計 410,737
