メインコンテンツにスキップ
はじめに
Prereq for Display Assembly.
パーツ
パーツは指定されていません。
  1. Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board. The three cables are coded with black sleeves of different lengths. During reassembly: Connect the long-sleeved cable to the socket closest to the ports.
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the socket closest to the ports.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  2. Move the antenna cables aside, clear of the AirPort board.
    • Move the antenna cables aside, clear of the AirPort board.
終わりに
Walter Galan
661,938 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 45
