メインコンテンツにスキップ
MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement, AirPort Board Assembly: 手順 1、 1の画像 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  2. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 2、 3の画像 1 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 2、 3の画像 2 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 2、 3の画像 3
    • Use the flat end of a spudger to pry and disconnect the three antenna cable connectors from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  3. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 3、 2の画像 1 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 3、 2の画像 2
    • Move the antenna cables aside, clear of the AirPort board.
  4. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 4、 2の画像 1 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 4、 2の画像 2
    • Wedge a plastic opening tool between the AirPort board (side nearest the I/O ports) and the I/O board.
    • Gently pry the AirPort board upwards, but do not remove it.
    • Only lift the AirPort board as much as is necessary to get a grip on it. Lifting it too high above the I/O board may damage the board or the socket.
  5. MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 5、 2の画像 1 MacBook Pro 13" Retina Display Late 2012 AirPort Board Assembly Replacement: 手順 5、 2の画像 2
    • Pull the AirPort board straight out of its socket on the I/O board.
終わりに
作成者
3人の作成者と共同で作成されました。
Walter Galan
694,638 ポイント
1,203のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 72
