メインコンテンツにスキップ
MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: 手順 1、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement, Trackpad Cable: 手順 1、 2の画像 2
    • Use the flat end of a spudger to pop the trackpad connector straight up off its socket on the logic board.
  2. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 2、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 2、 2の画像 2
    • Lift the trackpad cable up off the battery to separate it from the adhesive securing it.
    • Be careful not to damage the cable. If it doesn't peel up easily, apply a little heat from an iOpener, heat gun, or hair dryer to soften the adhesive, and try again.
    • If you are installing a new trackpad cable, be sure to fold the new cable to match the shape of the old cable. The new cable will appear to be too long if it is not folded.
  3. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 3、 3の画像 1 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 3、 3の画像 2 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 3、 3の画像 3
    • If necessary, peel back any tape covering the trackpad cable connector.
    • Use the end of a spudger to flip the retaining tab on the ZIF connector.
  4. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 4、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 4、 2の画像 2
    • Pull the trackpad cable straight out of its ZIF socket on the trackpad control board.
    • During reassembly, make sure that the retaining tab is in the up, "unlocked" position before you insert the cable into the socket.
  5. MacBook Pro 13" Retina Display Early 2015 Trackpad Cable Replacement: 手順 5、 1の画像 1
    • Remove the single 3.7 mm T5 Torx screw securing the battery board to the upper case.
終わりに
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,762 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
3 件のコメント
Why remove the screw in step 5?
Ari Cooper - Davis - 返信
Yes @sam , why should you remove the screw in step 5? Is this a mistake?
lmdehaas - 返信
Step 5: Remove the single 3.7 mm T5 Torx screw.
Step 6: Re-screw single 3.7 mm T5 Torx screw.
David Grabowski - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,782
