メインコンテンツにスキップ
MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement
必要な工具と部品
  1. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 3、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 3、 2の画像 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Battery Connector: 手順 4、 1の画像 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 5、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 5、 2の画像 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 6、 1の画像 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Right Speaker: 手順 7、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement, Right Speaker: 手順 7、 2の画像 2
    • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
    • Remove the I/O board cable bracket.
  8. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 8、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  9. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 9、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 9、 2の画像 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  10. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 10、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 10、 2の画像 2
    • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
  11. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 11、 3の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 11、 3の画像 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 11、 3の画像 3
    • Carefully peel the right speaker cable off the upper case.
  12. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 12、 1の画像 1
    • Remove the following screws securing the right speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  13. MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 13、 3の画像 1 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 13、 3の画像 2 MacBook Pro 13" Retina Display Early 2015 Right Speaker Replacement: 手順 13、 3の画像 3
    • Lift the right speaker from the cable end and pull it free from the case.
終わりに
66 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,810 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
5 件のコメント
my Speaker tone … can i stitch it ?
Mr Jay - 返信
Il ne faut surement pas plier la nappe de la carte E/S mais dévisser son support afin de ne pas l’endommager. Une fois pliée, elle ne reviendra jamais parfaitement droite. Il y a deux petites vis qui maintiennent le support qu’il faut dévisser, à moins qu’il y ait encore quelque chose de caché !
Yves Cirotteau - 返信
why do I need to disconnect the battery in order to replace the speaker?
Ohad S - 返信
It is best to always disconnect power from any device you’re working on. Worst case scenario you lay a screw driver down on the device or drop a conductive piece of metal somewhere into the case and it shorts out the board you’re working on. This is the safest way to do repairs.
Elliott Fix -
Will this be back in stock in the UK anytime soon?
Itamar Mor - 返信
コメントを追加
統計データ:
過去 24時間: 26
過去 7 日: 171
過去 30 日: 772
今までの合計 72,699
