メインコンテンツにスキップ
MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement
必要な工具と部品
  1. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: 手順 3、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 Lower Case Replacement: 手順 3、 2の画像 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
終わりに
27 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,656 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,722のガイドは作成済み
5 件のコメント
Nice………………..!
Fred Starbuck - 返信
The bottom left-middle screw on my case is jammed and won’t come out—the more I try, the more I’m stripping it. Every other screw has been removed successfully, several times, with no problems. I wonder if I put in the wrong screw from somewhere else? Any ideas for removing it?
Jordan - 返信
do i get a laptop cover for mac book pro retina a 1502 model
naga usha - 返信
do i get a macbook pro retina A 1502 MODEL laptop cover (hard or soft shell)
naga usha - 返信
I’m trying to install my lower case back but it’s refusing to clip back in. Any way I can fix it?
Jorge Ramirez-Centeno - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 73
過去 30 日: 320
今までの合計 50,569
