はじめに
Have your MacBook Pro feet seen better days? Use this guide to give your early 2015 MacBook Pro a fresh set of feet.
      • Two 2.3 mm P5 Pentalobe screws
      • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Wedge your fingers between the upper case and the lower case.
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  2. The lower case is connected to the upper case at the center, with two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips. During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace. Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
    • Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
      • Any stickers you remove will most likely be unsalvageable for re-use. That's okay! Your MacBook does not need them to function.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Remove any broken or damaged feet. If the foot you are replacing is still intact, you can use your tweezers  push it out from the inside.
    • Remove any broken or damaged feet.
      • If the foot you are replacing is still intact, you can use your tweezers push it out from the inside.
    • If the old foot is difficult to remove, use a hair dryer or a heat gun to apply some heat to the area and loosen the adhesive.
  6. Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
    • Scrub the foot cavity with adhesive remover to remove any remaining adhesive.
  7. Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
    • Wipe the foot cavity with an isopropyl alcohol prep pad to remove any cleaner residue and prep the area for the adhesive on the new foot.
  8. Peel a replacement foot from the plastic backing.
    • Peel a replacement foot from the plastic backing.
      • The adhesive is fairly strong—make sure that you are peeling the foot up, not tearing the plastic backing.
  9. Align the new foot inside the cavity. Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad. Lay the foot down while keeping it properly aligned.
    • Align the new foot inside the cavity.
      • Make sure the alignment nub on the foot is lined up with the small hole near the perimeter of the pad.
    • Lay the foot down while keeping it properly aligned.
    • Check for proper alignment from the inside of the case. The alignment nub should be slightly visible through the alignment hole.
  10. Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb. Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
    • Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
    • Repeat the last seven steps for any remaining broken or worn feet.
まとめ
Taylor Dixon
メンバー登録日: 2018年06月26日
5,897 ポイント
22のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
109 メンバー
7,717のガイドは作成済み
コメント1件
On the inside of the cover of my A1502 Early 2015 MBP, two of the four feet are covered by large black stickers. So, how do we remove the little piece left behind when we remove any foot that is damaged? Do we just cut through the large black sticker or remove it?
Jason Protzman - 返信
統計データを表示:
過去 24時間: 16
過去 7 日: 91
過去 30 日: 353
今までの合計 844
