メインコンテンツにスキップ
MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement
必要な工具と部品
  1. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 3、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 3、 2の画像 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, Battery Connector: 手順 4、 1の画像 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 5、 2の画像 1 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 5、 2の画像 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 6、 1の画像 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, AirPort Board: 手順 7、 3の画像 1 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, AirPort Board: 手順 7、 3の画像 2 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, AirPort Board: 手順 7、 3の画像 3
    • Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  8. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 8、 1の画像 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  9. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 9、 3の画像 1 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 9、 3の画像 2 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: 手順 9、 3の画像 3
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
終わりに
29 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,855 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
10 件のコメント
Is this responsible for wifi? I re-did my screen and fixed it from blackening, but the wifi icon says "Wi-Fi: No hardware installed". Is this part responsible? If I replace it will I get wifi back?
Howard Lin - 返信
I changed the card and the wifi keep disabling itself after few minutes of use. Only reboot reactivate it.. Someone have an idea ?
Phil - 返信
Hey! have you found a solution? I have been having the same problem!
juiquebec -
I am having the same exact problem as described by Phil - 04/25/2017
I replaced the card but the wifi and bluetooth keeps disabling itself after few minutes of use , only reboot reactivate it.
I am thinking of changing the antenna ? any ideas? suggestion ?
your help will be very much appreciated .
Lio - 返信
This isn’t the solution you are looking for, but what I did to my 2015 mbp when the wifi card started failing was getting an external wifi adapter. It’s cheaper, small enough, and works. I got this type: https://www.tp-link.com/us/support/downl... but any type works, this one is just small enough to be unassuming.
stefanikid - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 53
過去 30 日: 291
今までの合計 48,578
