メインコンテンツにスキップ
はじめに
このガイドを参照して、壊れたiSightカメラを交換しましょう。
  1. コインやスパッジャーを使って、バッテリーロックネジを時計回りに90度回します。
    • コインやスパッジャーを使って、バッテリーロックネジを時計回りに90度回します。
  2. コンピュータからバッテリーを持ち上げて外します。
    • コンピュータからバッテリーを持ち上げて外します。
  3. この手順は未翻訳です。 翻訳を手伝う。
    Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
  4. この手順は未翻訳です。 翻訳を手伝う。
    Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
    • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
  5. この手順は未翻訳です。 翻訳を手伝う。
    Remove the following 3 screws:
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. この手順は未翻訳です。 翻訳を手伝う。
    Take extra caution with these screws as they can strip easily!
    • Take extra caution with these screws as they can strip easily!
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  7. この手順は未翻訳です。 翻訳を手伝う。
    Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
  8. この手順は未翻訳です。 翻訳を手伝う。
    Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
  9. この手順は未翻訳です。 翻訳を手伝う。
    Remove the following 4 screws from the back of the computer:
    • Remove the following 4 screws from the back of the computer:
    • The longer screws go on the inside, shorter screws on the outside.
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
  10. この手順は未翻訳です。 翻訳を手伝う。
    Remove the two Phillips screws from the optical drive side of the computer.
    • Remove the two Phillips screws from the optical drive side of the computer.
    • Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. この手順は未翻訳です。 翻訳を手伝う。
    There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
    • The upper case is likely to stick at the connection above the optical drive. If this is the case, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening.
    • If you stand the base on end to get a better look you may displace the total of 4 grey plastic clips that hold the keyboard in place. Don't panic. They slide into slots at the top right-most edge near the CD drive.
  12. この手順は未翻訳です。 翻訳を手伝う。
    While holding up the upper case, pull up the black tab of the silver cable away from its connector. If there is no black tab, you can also use a spudger to gently pry the connector from its housing.  This connector is tall, so be sure to pry straight up. If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
    • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips on the optical drive side of the keyboard (refer to second picture). They must be installed in their slots for the keyboard to snap in properly.
    • To make the reassamble process easier, it's better to pull out the clips first by pulling it straight up gently. Be careful not to put too much strength because it will break.
  13. この手順は未翻訳です。 翻訳を手伝う。
    Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
  14. この手順は未翻訳です。 翻訳を手伝う。
    Remove the two Phillips screws from the front edge of the optical drive.
    • Remove the two Phillips screws from the front edge of the optical drive.
    • Two 3.25 mm Phillips #000, (Head: 4 mm. dia. x .3 mm thick)
  15. この手順は未翻訳です。 翻訳を手伝う。
    Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
    • Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
  16. この手順は未翻訳です。 翻訳を手伝う。
    Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    • Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
  17. この手順は未翻訳です。 翻訳を手伝う。
    Disconnect the (once again) newly-revealed hard drive cable.
    • Disconnect the (once again) newly-revealed hard drive cable.
  18. この手順は未翻訳です。 翻訳を手伝う。
    Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
    • Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
    • During reassembly, be sure to route the cables beneath the tape before reattaching it.
  19. この手順は未翻訳です。 翻訳を手伝う。
    Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
  20. この手順は未翻訳です。 翻訳を手伝う。
    Remove the 2 mm Phillips #00 screw securing the optical drive.
    • Remove the 2 mm Phillips #00 screw securing the optical drive.
    • The Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to unscrew the cable clip to free the cable enough.
  21. この手順は未翻訳です。 翻訳を手伝う。
    Lift the Bluetooth antenna board from the right side of the optical drive.
    • Lift the Bluetooth antenna board from the right side of the optical drive.
  22. この手順は未翻訳です。 翻訳を手伝う。
    Deroute the hard drive cable from along the front of the optical drive.
    • Deroute the hard drive cable from along the front of the optical drive.
  23. この手順は未翻訳です。 翻訳を手伝う。
    Lift the front edge of the optical drive and slide it up and out of the computer.
    • Lift the front edge of the optical drive and slide it up and out of the computer.
  24. この手順は未翻訳です。 翻訳を手伝う。
    • Two 3 mm Phillips near the right speaker.
    • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
    • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
    • Santa Rosa and Penryn MacBooks do not have a c-channel. If you are disassembling either of these models, remove only the single 3 mm Phillips screw from the right speaker and skip step 26.
  25. この手順は未翻訳です。 翻訳を手伝う。
    Lift the right speaker out of its housing and set it to the side.
    • Lift the right speaker out of its housing and set it to the side.
  26. この手順は未翻訳です。 翻訳を手伝う。
    If you have a Santa Rosa/Penryn model, skip this step.
    • If you have a Santa Rosa/Penryn model, skip this step.
    • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
  27. この手順は未翻訳です。 翻訳を手伝う。
    Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
    • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
  28. この手順は未翻訳です。 翻訳を手伝う。
    Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
    • Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
    • This metal clip may not be present in all models. Be sure that the cable is free from any hold downs around this area before proceeding.
  29. この手順は未翻訳です。 翻訳を手伝う。
    If you didn't remove the ground loop screw in step 20 above, remove it now.  It's a 7 mm (may be 4.2 mm in Santa Rosa/Penryn models) Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
    • If you didn't remove the ground loop screw in step 20 above, remove it now. It's a 7 mm (may be 4.2 mm in Santa Rosa/Penryn models) Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
  30. この手順は未翻訳です。 翻訳を手伝う。
    Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
    • Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
  31. この手順は未翻訳です。 翻訳を手伝う。
    Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
    • Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
  32. この手順は未翻訳です。 翻訳を手伝う。
    Disconnect the three antenna cables from the Airport card.  There may be a square foam piece over the logic board connector. Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.)  The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
    • Disconnect the three antenna cables from the Airport card. There may be a square foam piece over the logic board connector.
    • Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.) The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
    • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, there are only two antenna cables and the black inverter cable is in a different location.
  33. この手順は未翻訳です。 翻訳を手伝う。
    Remove the following 2 screws from the right hinge mount: One 6 mm Phillips on the left side of the hinge mount.
    • Remove the following 2 screws from the right hinge mount:
    • One 6 mm Phillips on the left side of the hinge mount.
    • One 10 mm Phillips on the right side of the hinge mount.
    • For Santa Rosa/Penryn models, see second picture and remove:
    • One 3 mm smalller diameter Phillips on the far left.
    • One 5.2 mm larger diameter 4.2 mm head Phillips in the middle.
    • One 10 mm Phillips from the far right.
    • Lift the right hinge mount with the small plastic piece out of the computer.
  34. この手順は未翻訳です。 翻訳を手伝う。
    Hold the display with one hand while removing the screws from the left hinge mount.
    • Hold the display with one hand while removing the screws from the left hinge mount.
    • Remove the following 3 screws from the left hinge mount:
    • One 7.2 mm smaller diameter Phillips from the right side.
    • One 5.2 mm larger diameter Phillips from the middle.
    • One 10 mm Phillips from the left side.
    • Lift the left hinge mount with plastic piece out of the computer.
    • Check that the cables on the right are not trapped under other cables.
    • Before completely disassembling, take care to see how the left hing mount fits together. When you remove the display in later steps, the hinge will pop both the left and right hinge mounts out, along with two small plastic pieces. Knowing how the mount fits together will help with reassembly.
  35. この手順は未翻訳です。 翻訳を手伝う。
    Grasp the display assembly on either side, and lift it up and out of the computer.
    • Grasp the display assembly on either side, and lift it up and out of the computer.
  36. The following steps should be identical for both white and black MacBooks.
    • The following steps should be identical for both white and black MacBooks.
    • Use a thin plastic card to release the tabs holding the front display bezel to the display assembly. There are five tabs along the left side of the display bezel.
    • 損傷した場合に交換できないカードは使用しないでください。 クリップは取り外すのが難しい場合があり、カードが曲がり破損する可能性があります。
  37. この手順は未翻訳です。 翻訳を手伝う。
    Continue to free the tabs along the the top edge of the display assembly.
    • Continue to free the tabs along the the top edge of the display assembly.
    • Be careful when working near the iSight camera.
  38. この手順は未翻訳です。 翻訳を手伝う。
    Next, free the five tabs securing the display bezel on the right side.
    • Next, free the five tabs securing the display bezel on the right side.
  39. この手順は未翻訳です。 翻訳を手伝う。
    Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel. Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
    • Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
    • Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
    • After freeing all holding tabs, lift the front display bezel away from the display assembly.
  40. この手順は未翻訳です。 翻訳を手伝う。
    Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket. Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel. A 0.8mm flat screwdriver may be useful for this step.
    • Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket.
    • Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel. A 0.8mm flat screwdriver may be useful for this step.
    • Be careful, as the clips are made of thin plastic and are inherently delicate.
  41. この手順は未翻訳です。 翻訳を手伝う。
    Insert the longer end of the retaining clip beneath the edge of its recess cut into the LCD bracket. Use the edge of a metal spudger to push the shorter tab on the other side of the retaining clip into the recess cut into the LCD bracket.
    • Insert the longer end of the retaining clip beneath the edge of its recess cut into the LCD bracket.
    • Use the edge of a metal spudger to push the shorter tab on the other side of the retaining clip into the recess cut into the LCD bracket.
    • The second picture shows the LCD bracket properly installed.
  42. クラッチカバーに留められた4.2mmプラスネジを3本外します。
    • クラッチカバーに留められた4.2mmプラスネジを3本外します。
  43. この手順は未翻訳です。 翻訳を手伝う。
    While holding the display down with one hand, use your other hand to lift the clutch cover off the clutch hinges.
    • While holding the display down with one hand, use your other hand to lift the clutch cover off the clutch hinges.
    • It may help to wiggle the clutch cover as you pull it up from the display.
  44. この手順は未翻訳です。 翻訳を手伝う。
    Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
    • Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
    • Lift the clutch cover out of the display assembly.
    • During reassembly, make sure not to pinch the backlight cable (with the white connector on the right side) when snapping the clutch cover back into place. This cable has two visible wires leading into the lower right section of the LCD display to the backlight. (The models with pink and white wires are usually longer and easier to pinch.)
  45. この手順は未翻訳です。 翻訳を手伝う。
    Remove the small piece of foam tape stuck down above each of the bezel covers. Remove the small piece of foam tape stuck down above each of the bezel covers.
    • Remove the small piece of foam tape stuck down above each of the bezel covers.
  46. この手順は未翻訳です。 翻訳を手伝う。
    Use a spudger to slide the left bezel cover towards the LCD panel. Do not lift up vertically on the cover! Unlike the large display bezel, this one has horizontal hooks to keep it in place. These will break easily.
    • Use a spudger to slide the left bezel cover towards the LCD panel.
    • Do not lift up vertically on the cover! Unlike the large display bezel, this one has horizontal hooks to keep it in place. These will break easily.
    • Lift the left bezel cover off the display assembly.
  47. スパッジャーを使って、LCDパネル側に向けて右側ベゼルカバーをスライドします。 ディスプレイアセンブリから右側ベゼルカバーを持ち上げます。
    • スパッジャーを使って、LCDパネル側に向けて右側ベゼルカバーをスライドします。
    • ディスプレイアセンブリから右側ベゼルカバーを持ち上げます。
  48. この手順は未翻訳です。 翻訳を手伝う。
    Lift the inverter out of the display slightly and disconnect the backlight cable from its right side. Place the inverter back down in its recess.
    • Lift the inverter out of the display slightly and disconnect the backlight cable from its right side.
    • Place the inverter back down in its recess.
  49. ディスプレイデータケーブルを右側クラッチヒンジを固定している3.2mmプラスネジを1本外します。
    • ディスプレイデータケーブルを右側クラッチヒンジを固定している3.2mmプラスネジを1本外します。
  50. この手順は未翻訳です。 翻訳を手伝う。
    Move the display data cable out from under the mounting arm of the right clutch hinge.
    • Move the display data cable out from under the mounting arm of the right clutch hinge.
  51. この手順は未翻訳です。 翻訳を手伝う。
    Remove the twelve 4.2 mm Phillips screws securing the LCD assembly to the rear display bezel.
    • Remove the twelve 4.2 mm Phillips screws securing the LCD assembly to the rear display bezel.
    • Make sure you pay attention to how the microphone cable (and antenna cable on some models) are routed around the outside of the two screws nearest to the bottom of the screen (on both left and right). It's easy to damage the cables if not routed properly when putting these screws back on.
  52. ケーブルが巻き込まれないよう注意しながら、リアディスプレイベゼルからLCDアセンブリを持ち上げます。
    • ケーブルが巻き込まれないよう注意しながら、リアディスプレイベゼルからLCDアセンブリを持ち上げます。
  53. この手順は未翻訳です。 翻訳を手伝う。
    Be sure to keep track of the small magnet along the left side of the display. It may be stuck to the LCD frames or to the rear display bezel. When installing it, be sure short side is facing upward.
    • Be sure to keep track of the small magnet along the left side of the display. It may be stuck to the LCD frames or to the rear display bezel. When installing it, be sure short side is facing upward.
  54. この手順は未翻訳です。 翻訳を手伝う。
    Remove the two pieces of yellow tape covering the camera cable near the top edge of the LCD assembly.
    • Remove the two pieces of yellow tape covering the camera cable near the top edge of the LCD assembly.
  55. iSightボードからカメラケーブルの接続を外します。
    • iSightボードからカメラケーブルの接続を外します。
  56. iSightボードをブラケットに固定している4.1mm肩ツキプラスネジを2本外します。
    • iSightボードをブラケットに固定している4.1mm肩ツキプラスネジを2本外します。
  57. スパッジャーの平面側先端を使って、奥からカメラを注意深く持ち上げます。
    • スパッジャーの平面側先端を使って、奥からカメラを注意深く持ち上げます。
    • LCDアセンブリからiSightを取り外します。
  58. この手順は未翻訳です。 翻訳を手伝う。
    Only use the following steps if your black plastic front iSight bezel is damaged. If is it still usable, simply transfer the iSight electronics to your existing iSight bezel.
    • Only use the following steps if your black plastic front iSight bezel is damaged. If is it still usable, simply transfer the iSight electronics to your existing iSight bezel.
    • Use the tip of a spudger to gently push the microphone out of the front iSight bezel.
    • Only push around the outer edge of the microphone.
  59. iSightベゼルをブラケットに固定している2.2mmプラスネジを2本外します。
    • iSightベゼルをブラケットに固定している2.2mmプラスネジを2本外します。
    • iSightベゼルを取り外します。
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
11 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
Andrew Bookholt
563,394 ポイント
618のガイドは作成済み
コメント1件
The easier way to replace the iSight is to remove the screen bezel, take out the LCD screws, disconnect the iSight from the ribbon cable, unscrew and remove isight, replace it. Put it back together. I don't know why they told us to do all of this extra junk, unless you know that the cables are (part of) the problem.
Daniel - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 12,928
