メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Replace a warped optical drive bezel to allow your MacBook's optical drive to accept disks again.
  1. Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. Lift the battery out of the computer.
    • Lift the battery out of the computer.
  3. Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
  4. Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
    • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
  5. Remove the following 3 screws:
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. Take extra caution with these screws as they can strip easily!
    • Take extra caution with these screws as they can strip easily!
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  7. Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
  8. Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
  9. Remove the following 4 screws from the back of the computer:
    • Remove the following 4 screws from the back of the computer:
    • The longer screws go on the inside, shorter screws on the outside.
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
  10. Remove the two Phillips screws from the optical drive side of the computer.
    • Remove the two Phillips screws from the optical drive side of the computer.
    • Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
    • The upper case is likely to stick at the connection above the optical drive. If this is the case, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening.
    • If you stand the base on end to get a better look you may displace the total of 4 grey plastic clips that hold the keyboard in place. Don't panic. They slide into slots at the top right-most edge near the CD drive.
  12. While holding up the upper case, pull up the black tab of the silver cable away from its connector. If there is no black tab, you can also use a spudger to gently pry the connector from its housing.  This connector is tall, so be sure to pry straight up. If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
    • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips on the optical drive side of the keyboard (refer to second picture). They must be installed in their slots for the keyboard to snap in properly.
    • To make the reassamble process easier, it's better to pull out the clips first by pulling it straight up gently. Be careful not to put too much strength because it will break.
  13. Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
    • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
  14. Remove the two Phillips screws from the front edge of the optical drive.
    • Remove the two Phillips screws from the front edge of the optical drive.
    • Two 3.25 mm Phillips #000, (Head: 4 mm. dia. x .3 mm thick)
  15. Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
    • Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
  16. Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
    • Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
  17. Disconnect the (once again) newly-revealed hard drive cable.
    • Disconnect the (once again) newly-revealed hard drive cable.
  18. Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
    • Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
    • During reassembly, be sure to route the cables beneath the tape before reattaching it.
  19. Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
    • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
  20. Remove the 2 mm Phillips #00 screw securing the optical drive.
    • Remove the 2 mm Phillips #00 screw securing the optical drive.
    • The Bluetooth cable may be covering the screw. If so, carefully push it aside. You may need to unscrew the cable clip to free the cable enough.
  21. Lift the Bluetooth antenna board from the right side of the optical drive.
    • Lift the Bluetooth antenna board from the right side of the optical drive.
  22. Deroute the hard drive cable from along the front of the optical drive.
    • Deroute the hard drive cable from along the front of the optical drive.
  23. Lift the front edge of the optical drive and slide it up and out of the computer.
    • Lift the front edge of the optical drive and slide it up and out of the computer.
  24. There are four plastic upper case clips installed in the aluminum framework above the optical drive opening. It is recommended to remove these clips before attempting to remove the optical drive bezel. To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
    • There are four plastic upper case clips installed in the aluminum framework above the optical drive opening. It is recommended to remove these clips before attempting to remove the optical drive bezel.
    • To remove the clips, simply slide them out of the aluminum framework away from the side of the lower case.
  25. Remove the following three #00 screws:
    • Remove the following three #00 screws:
    • One 5.7 mm Phillips screw
    • Two 3.1 mm Phillips screws
  26. Remove the single 3.1 mm Phillips screw below the inside of the optical drive opening.
    • Remove the single 3.1 mm Phillips screw below the inside of the optical drive opening.
  27. Insert the flat end of a spudger between the optical drive bezel and the plastic lower case. Gently pry the optical drive bezel away from the adhesive securing it to the lower case enough to lift the mounting ear near the hard drive connector above the metal framework.
    • Insert the flat end of a spudger between the optical drive bezel and the plastic lower case.
    • Gently pry the optical drive bezel away from the adhesive securing it to the lower case enough to lift the mounting ear near the hard drive connector above the metal framework.
    • Lift the optical drive bezel enough to clear the metal framework and continue separating it from the lower case with your spudger.
  28. Remove the optical drive bezel from the lower case.
    • Remove the optical drive bezel from the lower case.
終わりに
19 の人々がこのガイドを完成させました。
Andrew Bookholt
558,075 ポイント
618のガイドは作成済み
コメント1件
For re-assembly, I do have 1 tip. When re-inserting the optical drive, there is a small moveable bracket on the bottom of the drive that can cause some confusion as to, it doesn't line up. push the bracket with a spudger and you should be fine.
Ikfixda - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 23
今までの合計 20,596
