この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Regain the function of your speakers by replacing the audio board.
必要な工具と部品
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the following two screws securing the speaker assembly to the upper case.
One 3 mm Phillips.
One 5.8 mm Phillips.
Use the pointed end of a spudger to pry the speaker connector up off the audio board.
9 の人々がこのガイドを完成させました。
