はじめに
上部ケースの交換のための必須条件です。
必要な工具と部品
スパッジャーの平面側先端を使って、上部ケースの左側にマイクロフォンを固定している接着剤を剥がします。
必要に応じて、iOpenerもしくはヘアドライヤーを使って、接着剤を若干温めると作業がしやすくなります。
上部ケースからマイクロフォンを取り出します。
If you’re replacing a top case with one provided by Apple, you won’t need to transfer the microphone to the new top case.
Hot air really helps here.
I really sweated over removing the microphone, but as Carroll mentioned, it’s not necessary since it was supplied with the iFixit upper case. Thanks, because it was a b*tch to remove and I probably damaged it in the process. Even with heat.
I did not have a mic in my Ifixit. Am I assuming I need to put it back? with adhesive
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
Not necessary to remove this. I was replacing a top case that included the speakers.
Same as the speaker in Step 29, which seems like it can also be left in place.
Tito Jankowski - 返信
This step is required only if also replacing the keyboard.
airshack - 返信
Replacing the entire top case is not necessary with the common spilled beverage situations. You can purchase a trackpad as well as keyboard for much less than the cost of an entirely new top case. Why replace the expensive aluminum top case unless it is itself broken which is unlikely.
airshack - 返信
Airshack, this is not true for all models of the MacBook Air or the MacBook Pro
phil3 - 返信
If it is difficult to remove the speakers you can use Isopropyl Alcohol to loosen the adhesive holding the speakers in place. Make sure to keep the Isopropyl Alcohol away from the speaker itself.
BluRepairs - 返信
