メインコンテンツにスキップ
MacBook Air 13" Mid 2013 Solid-State Drive Replacement
必要な工具と部品
  1. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2013 Solid-State Drive Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Battery Connector: 手順 3、 2の画像 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Mid 2013 Solid-State Drive Replacement, Solid-State Drive: 手順 4、 1の画像 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 13" Mid 2013 Solid-State Drive Replacement: 手順 5、 2の画像 1 MacBook Air 13" Mid 2013 Solid-State Drive Replacement: 手順 5、 2の画像 2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
終わりに
Not sure what to do with your old SSD? Use this external SSD enclosure to turn it into a handy portable external drive!
143 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Walter Galan
694,573 ポイント
1,203のガイドは作成済み
30 件のコメント
May I upgrade it to a 256 GB Drive?
Ray - 返信
Where can I find the 256GB SSD to upgrade my 128GB macbook air (mid 2013)?
Josh - 返信
I'm also looking for a 256HB SSD because 128GB isn't enough?
rhattan503 -
At the moment, the only source for this part is on eBay, at UpgradeMonkey shop (UK)
Link : http://www.ebay.fr/itm/NEW-haswell-MacBo...
It's high priced, but I didn't find anywhere else.
Regards.
JMM -
http://www.alelua.com/es/31-almacenamien... SDD for MacBook Air 11" and 13" (Mid 2013/Early 2014) 256 GB Drive
alelua -
コメントを追加
統計データ:
過去 24時間: 64
過去 7 日: 384
過去 30 日: 1,666
今までの合計 345,556
