メインコンテンツにスキップ
はじめに
Use this guide to replace a blown microphone.
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  1. Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  2. Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board. Do not lift upward on the connector as you disconnect it.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  3. Remove the following five screws securing the battery to the upper case:
    • Remove the following five screws securing the battery to the upper case:
    • Three 6.3 mm T5 Torx screws
    • Two 2.4 mm T5 Torx screws
  4. When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • When handling the battery, avoid squeezing or touching the four exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • When installing the new battery, if there is a thin plastic film on your replacement battery, do not attempt to remove it. It is glued on and protects the battery pack while it is inside the MacBook.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  5. Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
  6. De-route the left speaker cable from its retaining clip on the I/O board.
    • De-route the left speaker cable from its retaining clip on the I/O board.
  7. Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case. Remove the left speaker from the upper case. Remove the left speaker from the upper case.
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
  8. Use the edge of a spudger to pry the microphone connector up and out of its socket on the I/O board.
    • Use the edge of a spudger to pry the microphone connector up and out of its socket on the I/O board.
  9. Use the tip of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case. Remove the microphone from the upper case.
    • Use the tip of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
    • Remove the microphone from the upper case.
終わりに
6 の人々がこのガイドを完成させました。
Andrew Optimus Goldheart
メンバー登録日: 2009年10月17日
475,866 ポイント
410のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Community
137 メンバー
16,780のガイドは作成済み
2 件のコメント
There is a not 2012 MBA entrails on the photos. Maybe a newer MBA (double mic).
Surgie - 返信
Agreed, that I/O board and the microphone connector are all wrong. Looks like they’ve reused a previous guide.
James Thorburn - 返信
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 41
今までの合計 6,006
