メインコンテンツにスキップ
MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement
必要な工具と部品
  1. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, Battery Connector: 手順 3、 2の画像 2
    • As a precaution against accidental discharge or shock, disconnect the battery connector from the logic board.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Be sure to pull the connector horizontally toward the battery, and not straight up from the Air, or you may damage the socket on the logic board.
  4. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 手順 4、 2の画像 1 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement, AirPort/Bluetooth Card: 手順 4、 2の画像 2
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card.
  5. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: 手順 5、 1の画像 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  6. MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: 手順 6、 2の画像 1 MacBook Air 13" Mid 2012 AirPort/Bluetooth Card Replacement: 手順 6、 2の画像 2
    • Slightly lift the free end of the AirPort/Bluetooth card and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
    • Remove the AirPort/Bluetooth card from the Air.
終わりに
31 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,656 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,718のガイドは作成済み
11 件のコメント
Is it possible to replace 2012 wireless card to newer ac card?
Manoj Biswas - 返信
^I have this same question
delgado1kevin - 返信
Hello I just ordered a early 2013 Wifi/Bluetooth Macbook Air card that I will use to replace my current mid 2012 MacAir wifi/Bluetooth. I will keep everyone posted here. The card should arrive next week.
filipemiranda - 返信
Did the 2013 AC airport card work on your 2012 macbook air?
Fritz Gamboa -
Yes it is. I got mine from WWW.QUICKERTEK.COM and it works perfectly. I can now use my Apple Watch to unlock my Mid 2012 MacBook Air 13"
Colin O'Neal - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 61
今までの合計 26,496
