はじめに
Use this guide to replace the trackpad.
必要な工具と部品
この手順で使用する道具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 9 mm 5-point Pentalobe screws
Eight 2.6 mm 5-point Pentalobe screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
Pull the trackpad ribbon cable straight out of its socket toward the rear edge of the Air.
19 の人々がこのガイドを完成させました。
3 件のコメント
The screws are not Philips 00. They are smaller than Philips 000. I am looking for a screwdriver in that size.
I have the iFixit toolkit, and the PH000 tip simply did not fit into the head. The J000 tip could remove a couple screws, but started to strip the head of two others before I stopped. The tip almost stripped the two I removed on reinsertion.
The replacement trackpad comes with a set of these screws.
No pictures : impossible to use
Hey Pierre! There was an Amazon service outage that affected the images on this page. Take another look, you should be able to follow this guide now! =)
