メインコンテンツにスキップ
MacBook Air 13" Late 2010 Primary Storage Replacement
必要な工具と部品
  1. MacBook Air 13" Late 2010 Primary Storage Replacement, MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 1、 1の画像 1
    • I have a Macbook Air, pretty early days. Late 2010. Got the JetDrive 500 in an attempt to increase drive space.
    • Coincidentally, I have no conflict of interest with the company Transcend. I'm just a customer.
    • Demographic / Skill level - I'm a software developer who primarily uses a windows machine.
  2. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 2、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 2、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 2、 3の画像 3
    • Comes with the tools that you need. Neat, I like it! Even if you are a home repair kind of guy, you are unlikely to have a magnetically charged screwdriver that can take out tiny Apple screws.
    • Also, packaging is nice. No clamshells. Stacks in a box with an eye toward efficiency.
    • Nice quality case which you could use to store the external drive case they provide.
  3. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 3、 1の画像 1
    • Terse instructions--but I've built 100's of computers over the years, so I think I'll just go for it.
    • Later, I will also take a photo of my finger in this most awkward "Option key" position. For the sole purpose of lighting and camera angle. Bring it on Kubrick.
  4. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 4、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 4、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 4、 3の画像 3
    • Take the new storage and put it in the external enclosure.
    • When inserting cards like this, hold one side of the connector with two fingers supporting it and gently wiggle the card into place with the other hand. Think, micro-wiggles.
    • Put the monstrosity of science you just assembled into the case, connector first. Make sure it seats comfortably and that you can plug the usb cable in.
  5. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 5、 1の画像 1
    • Button it up.
    • Only use one screw. This is the storage that we're going to put in the Macbook Air in a couple hours after we clone our internal drive to it.
  6. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 6、 2の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 6、 2の画像 2
    • Attach the Macbook Air to power and shut it down.
    • Plug in the new drive enclosure.
  7. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 7、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 7、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 7、 3の画像 3
    • Awkward option finger photo, in full effect.
    • Hold the "Option" button down the entire time that the system is restarting and you will get to the boot options screen.
    • Being someone more familiar with windows, here is the point where I start worrying about the ramifications of low level operations but, like, whatever, right?
    • I chose the "Recovery" drive. With the amount of information provided, I figured it was pretty much a crap shoot. Two sentences of text would have probably made it crystal clear. I'm glad I made "The Right Choice (c) 2014."
  8. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 8、 2の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 8、 2の画像 2
    • This is what happened next. Disk Utility seemed like the most logical choice.
  9. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 9、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 9、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 9、 3の画像 3
    • So, now we're going to clone this drive. We enter a weird UX. Must click to fill in the source but have to drag to add the destination.
    • Anyway, click the hardware old and drag the hardware new with great hope but in the interest of foreshadowing, I will let you know now that this will fail miserably.
  10. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 10、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 10、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 10、 3の画像 3
    • Let's erase it. (google translate: "format")
    • And then, let's try and clone it. This time though, we're going to choose what I believe is called a volume, rather than a device. The device being the stick of ram we just installed and a volume as the collection of files and metadata stored on it.
    • Chkdsk never hurt anyone. In Mac parlance, "Verify disk" under "First Aid"
  11. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 11、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 11、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 11、 3の画像 3
    • We have successfully reached the point where we can clone our volume.
    • It's going to take awhile. This is the perfect time to do something else for at least two hours. I decided to go to sleep. YMMV.
    • After the cloning process finished. I verified the disk and it reported that things were super-duper, you betcha.
  12. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 12、 1の画像 1
    • There are two long screws holding the back cover. Retain in your brain which ones they are.
  13. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 13、 1の画像 1
    • A long screw and three short screws with a size comparison.
  14. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 14、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 14、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 14、 3の画像 3
    • A look at the internals. We are concerned with that orderly looking circuit board...held by a set screw.
  15. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 15、 2の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 15、 2の画像 2
    • Put in your monocle and make sure you are respecting the gap when you introduce the new memory module.
    • Replace the black set screw.
  16. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 16、 1の画像 1
    • Gently re-introduce the rear plate. Add a screw to each location. It is recommended to fasten each screw a bit at a time, so that each screw can best contribute to the case's tensor integrity.
  17. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 17、 3の画像 1 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 17、 3の画像 2 MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 17、 3の画像 3
    • Let's put the old drive in this neat new case!
    • The purpose was unclear for the black rubber piece with an adhesive backing. I attached it to the top of drive case. It seems to hold the memory stick snug in the case.
  18. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 18、 1の画像 1
    • I guess you could use the case to hold on to the screwdriver set. You know, for the apocalypse.
  19. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 19、 1の画像 1
    • For whatever reason, making a clone seems to wipe out the index so it's going to churn on Spotlight for awhile.
  20. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 20、 1の画像 1
    • At the end though, you're likely to have a bit more disk space. 383 GB, in my case.
    • Good luck!
  21. MacBook Air 13" Late 2010 Primary Storage Replacement: 手順 21、 1の画像 1
    • Download the JetDrive Toolbox from Transcend's website.
    • Install it and make sure you turn TRIM on. This will make your drive harder, better, faster, stronger.
ゴール
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Timothy Lee Russell
メンバー登録日: 10/03/14
141 ポイント
1ガイドが承認済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 4,945
