メインコンテンツにスキップ
MacBook Air 13" Late 2010 Heat Sink Replacement
必要な工具と部品
  1. MacBook Air 13" Late 2010 Heat Sink Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Before proceeding, power off the device, close the lid and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Late 2010 Heat Sink Replacement, Battery: 手順 3、 1の画像 1
    • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
    • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
    • Do not lift upward on the connector as you disconnect it.
  4. MacBook Air 13" Late 2010 Heat Sink Replacement, I/O Board Cable: 手順 4、 1の画像 1
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  5. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 5、 2の画像 1 MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 5、 2の画像 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • Carefully peel the I/O board cable from the top of the fan.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the tip of a spudger to pry upward on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
  6. MacBook Air 13" Late 2010 Heat Sink Replacement, Fan: 手順 6、 1の画像 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  7. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 7、 1の画像 1
    • Peel the rubber gasket off the adhesive on the top of the fan.
  8. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 8、 1の画像 1
    • Remove the following three screws securing the fan to the upper case:
    • One 3.6 mm T5 Torx screw
    • One 2.7 mm T5 Torx screw
    • One 3.6 mm T5 Torx screw with a short head
  9. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 9、 1の画像 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
  10. MacBook Air 13" Late 2010 Heat Sink Replacement, I/O Board: 手順 10、 1の画像 1
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
  11. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 11、 1の画像 1
    • Pull the camera cable parallel to the face of the I/O board toward the corner of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
  12. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 12、 2の画像 1 MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 12、 2の画像 2
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    • De-route the left speaker cable from its retainer on the I/O board.
  13. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 13、 1の画像 1
    • Use the flat end of a spudger to pry the microphone cable connector up and out of its socket on the I/O board.
  14. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 14、 1の画像 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  15. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 15、 1の画像 1
    • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
  16. MacBook Air 13" Late 2010 Heat Sink Replacement, Heat Sink: 手順 16、 1の画像 1
    • Remove the eight 2.5 mm T5 Torx screws securing the heat sink to the logic board.
  17. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 17、 1の画像 1
    • Remove the two 4.9 mm T8 Torx screw securing the antenna cable retainer on the left display hinge to the upper case.
  18. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 18、 1の画像 1
    • Push the antenna cable retainer out of the way and remove the 3 mm T5 Torx screw securing the end of the heat sink to the upper case.
  19. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 19、 2の画像 1 MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 19、 2の画像 2
    • If the heat sink seems to be stuck to the logic board after removing all eight screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
    • Remove the heat sink from the logic board.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  20. MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 20、 2の画像 1 MacBook Air 13" Late 2010 Heat Sink Replacement: 手順 20、 2の画像 2
    • These shots show how the rubber fan gasket should be installed during reassembly. Be sure not to install the gasket underneath the ear where the end of the heatsink is screwed down to the upper case.
    • Additionally, be sure the small post molded into the rubber gasket mates with the hole cut into the upper right corner of the logic board.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Andrew Bookholt
585,793 ポイント
619のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 21
今までの合計 14,127
