メインコンテンツにスキップ
MacBook Air 13" Early 2015 I/O Board Cable Replacement
必要な工具と部品
  1. MacBook Air 13" Early 2015 I/O Board Cable Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    購入する
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2015 I/O Board Cable Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2015 I/O Board Cable Replacement, Battery Connector: 手順 3、 2の画像 1 MacBook Air 13" Early 2015 I/O Board Cable Replacement, Battery Connector: 手順 3、 2の画像 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2015 I/O Board Cable Replacement, I/O Board Cable: 手順 4、 1の画像 1
    • Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
  5. MacBook Air 13" Early 2015 I/O Board Cable Replacement: 手順 5、 1の画像 1
    • Carefully peel the I/O board cable from the adhesive securing it to the top of the fan.
    • During reassembly, make sure this cable is in the correct orientation. It will fit if reversed, but the laptop will not boot.
  6. MacBook Air 13" Early 2015 I/O Board Cable Replacement: 手順 6、 2の画像 1 MacBook Air 13" Early 2015 I/O Board Cable Replacement: 手順 6、 2の画像 2
    • The following connector has an especially deep socket. Use care when disconnecting it.
    • While gently pulling the I/O board cable upward near its connection to the logic board, use the flat end of a spudger to pry up on alternating sides of the connector to help "walk" it out of its socket.
    • Remove the I/O board cable.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,762 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 56
今までの合計 7,938
