メインコンテンツにスキップ
MacBook Air 13” Retina Display Late 2018 Display Replacement
必要な工具と部品
  1. MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the screws securing the lower case: 手順 1、 1の画像 1
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
  2. MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the lower case: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • After reassembly, your MacBook might not turn on until it's connected to a power source (a low power phone charger may work). To test your repair, plug in your charger, allow two minutes for your MacBook to turn on, and check that everything works as expected.
  3. MacBook Air 13” Retina Display Late 2018 Display Replacement, Disconnect the battery: 手順 3、 1の画像 1
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 4、 2の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 4、 2の画像 2
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13” Retina Display Late 2018 Display Replacement, Disconnect the antenna bar: 手順 5、 2の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement, Disconnect the antenna bar: 手順 5、 2の画像 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  6. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 6、 3の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 6、 3の画像 2 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 6、 3の画像 3
    • Insert the point of a spudger under one of the antenna cables close to the connector.
    • Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  7. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 7、 2の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 7、 2の画像 2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  8. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 8、 2の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to pry up the display cable connector.
  9. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 9、 1の画像 1
    • Use a T5 Torx driver to remove the following screws:
    • Four 7.4 mm screws
    • Two 4.5 mm screws
  10. MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the antenna bar: 手順 10、 3の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the antenna bar: 手順 10、 3の画像 2 MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the antenna bar: 手順 10、 3の画像 3
    • Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
    • You may encounter resistance from the clips in the middle of the antenna bar holding it in the case. You may pull hard without damaging anything as long as you pull straight up, perpendicular to the case.
    • Remove the antenna bar.
  11. MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the display: 手順 11、 2の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement, Remove the display: 手順 11、 2の画像 2
    • Use a T9 Torx driver to remove the six 4.9 mm screws securing the display hinges to the upper case.
  12. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 12、 2の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 12、 2の画像 2
    • With the MacBook still screen-side down, carefully lift the upper case to open the MacBook as far as possible.
  13. MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 13、 3の画像 1 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 13、 3の画像 2 MacBook Air 13” Retina Display Late 2018 Display Replacement: 手順 13、 3の画像 3
    • Lift the MacBook and carefully rotate the display to a 90 degree angle with the upper case.
    • The hinges should not move in relation to the display, and should rotate out of the case slightly.
    • Keeping the display at a 90 degree angle with the case, move the display straight down while holding the case still, so that the hinges slide out the bottom of the case.
終わりに
25 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,194 ポイント
416のガイドは作成済み
11 件のコメント
So…….. Which one of those flexes is the camera flex? It seems you skipped over a lot of the connectors in your guide.
Aksel Barnes - 返信
I would like to know this as well same issue with Camera not detected as other comments.
David Thomas -
I’m also interested in this. After a LCD swap, de iSight camera / webcam isn’t working.
Jochem -
Y’all need to give bonus points for putting it all back together again. Those T3 screws in steps 5 and 7 are awful hard to get back into place while holding the brackets in place. Not to mention the replacement display I purchased (from a third party) didn’t have the other two brackets in place, so I had to move those over from the original display as well.
The high res images in this guide are very helpful, and the guide is very well written and straightforward. Thanks.
larwood - 返信
I have replaced the complete screen on my macbook air and followed these repair instructions to the letter, but for some reason the camera is not detected, I have double checked the connectors but still no camera detected when opening any app s like facetime, photo booth etc.
colin - 返信
コメントを追加
統計データ:
過去 24時間: 17
過去 7 日: 113
過去 30 日: 584
今までの合計 29,085
